Drivetrain NEW ALTA R56 Plug-n-Play ECU Q&A Thread
Old Jan 23, 2008 | 08:16 AM
  #51
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Originally Posted by 4Azdmunky
Hey Adam
I looked a little closer at the coating, now that you pointed it out, yea there is a lot more of it than I thought. I sprayed it with electronics cleaner, it didn't loosen up any, i tried scraping it with a screw driver, it doesn't come off very easily. What can we use to clean this, or should we just return them instead of risking damage to the harness?
Methanol seems to work really well. Hard to damage the unit by doing that. Also, scraping the big pins a bit with an exacto may also help.
Sorry for the inconvenience!
Old Jan 23, 2008 | 08:17 AM
  #52
ADAMSALTAMINI
Originally Posted by Chris56S
I just got my car back and haven't installed the ECU PnP yet. Adam, what does the coating look like on the pins? I'm not sure what I'm looking for. Thanks!
Kind of a milky, yellowy stuff. It appears likely that you do have it. Try a bit of methanol, or alcohol on it to clean it. Won't damage the harness. Certainly better to try first, then install.
Thanks again!
Old Jan 23, 2008 | 05:14 PM
  #53
4Azdmunky's Avatar
4Azdmunky
Hi Adam
So the electronics cleaner didn't do squat. So I tried the MEK and that did the trick, I think. No CEL, however i do have a warning triangle on the tach dash. That could be from the freeze warning though, i need to hook up to OBDII to confirm. Tomorrow Jen will run it to work, and we will see. As for tonights butt dyno run....WOW that was worth the wait.
Next step is to go to MAC Auto Sports and get it dyno'd. Unfortunately, i don't have a stock Dyno run, but oh well. I dont race it,and neither does the wife, so I really only care about the end output, and then only just to know.
Old Jan 23, 2008 | 05:29 PM
  #54
snkbte's Avatar
snkbte
Looks like FedEx has lost my Unichip. It was on its way back to me after being reprogrammed by Jeff......
Old Jan 23, 2008 | 05:37 PM
  #55
scott48's Avatar
scott48
........very sucky
Old Jan 23, 2008 | 07:33 PM
  #56
4Azdmunky's Avatar
4Azdmunky
MEK
For those that are wondering, MEK is available at HomeDepot it was around $7 (might be around $13) i think. Blue and red can, look in the paint thinner section.
Old Jan 23, 2008 | 08:09 PM
  #57
Chris56S's Avatar
Chris56S
Thanks 4Azdmunky. I was going to post that very question.
Old Jan 23, 2008 | 08:21 PM
  #58
MotorMouth's Avatar
MotorMouth
don't forget rubber gloves, respirator, goggles, and rubber apron! The MSDS on that stuff is scary
Old Jan 24, 2008 | 12:46 AM
  #59
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
Originally Posted by ADAMSALTAMINI
My Clubman will be here any day. Once it is, I will go put a quick 250-500 miles then strap it to the dyno bone stock. I can then show the gains accurately with just the ALTA PnP ECU! WE are out of stock cars in teh bldg.
Sorry for the delay!
If you are in any need of a bone stock R56S for testing...give me a shout out, I live in the Portland area and I'm SERIOUSLY considering the ecu as my first performance mod to the car, so natuarally I'm curious about results.
Randy
Old Jan 24, 2008 | 08:11 AM
  #60
ADAMSALTAMINI
That stinks! Call our offices or e-mail Christina.Barlow@altaminiperformance.com
They will get on it ASAP!
Old Jan 24, 2008 | 08:12 AM
  #61
ADAMSALTAMINI
Randy
Hit me up in a PM with contact information! We will be in touch!
Old Jan 24, 2008 | 08:15 AM
  #62
unsalada's Avatar
unsalada
Any updates on the new harness?
Old Jan 24, 2008 | 08:27 AM
  #63
ADAMSALTAMINI
Updates will go in my first post as they arrive. Today I added a few Q's and A's. February is the next batch of harnesses to arrive.
All will include some form of improvements. We appreciate all the feedback.
Old Jan 24, 2008 | 11:24 AM
  #64
amazingrando
Just did! talk to ya soon.
Randy.
Old Jan 24, 2008 | 03:56 PM
  #65
Msteadman's Avatar
Msteadman
Okay, this is getting way too tempting so now I just have to pose the question:
As you guys know, I'm planning to get the ALTA turbo back exhaust installed next weekend. However, that plan was made before the ECU became available for the auto trans. I can't do the TBE and ECU right now as I'm getting new wheels/tires put on this weekend, so my budget (college student) is already hell of stretched as it is... So which option would you pick?
1. ALTA cat-back exhaust and ECU
2. ALTA turbo-back exhaust
It seems option 1 would give more power and I could always add the downpipe later, but I'm unsure.
Old Jan 24, 2008 | 04:12 PM
  #66
snkbte's Avatar
snkbte
# 1 is what I have done to mine. Plenty of power, sounds great and,like you, I can always add the downpipe later
(Probably this spring... )
Old Jan 24, 2008 | 04:28 PM
  #67
ADAMSALTAMINI
Do #2. Then later on get the PnP ECU from ALTA. The sound is better and then the HP gain later down the road will be above what it is with #1 choice.
Just my two cents!
Old Jan 24, 2008 | 05:11 PM
  #68
4Azdmunky's Avatar
4Azdmunky
I would go with #2. Both will give you noticeable gains, however when your ready for the Unichip they might have a Flux package and Alta will include all the programming for your supported mods at time of Unichip purchase, which will also make the unichip costs cheaper because you wont have to pay for repeat flash updates....you know your going to mod it more,....we know your going to mod it more....so while the individual updates would be cheap in comparison, after a couple the cost will really add up.
Also the turbo down pipe is a PITA to install. Not because of the Alta design, but because of the Mini heat shields. So if your going to have someone there anyways, and they can install that pipe for the same cost, then you would save same more money that way ( as opposed to going back and having then install that later). The unichip is real easy to install, less than 20 min even if you follow the directions exactly and actually run the harness into the cab.
Old Jan 24, 2008 | 07:01 PM
  #69
Candyman's Avatar
Candyman
I'd go w/ option 2 -- I ran the TBE for a long time with very good results (just under 200whp).
Old Jan 24, 2008 | 07:09 PM
  #70
DyeLooper's Avatar
DyeLooper
Take a student loan, DO IT ALL!!
Old Jan 24, 2008 | 07:19 PM
  #71
ADAMSALTAMINI
LOVE IT!
Old Jan 25, 2008 | 03:07 PM
  #72
Msteadman's Avatar
Msteadman
Well for better or worse, looks like the decision has been made for me - no one has any downpipes! Call to ALTA says the next batch won't be shipping out until the first week in March.
So more than likely I'll be purchasing the PnP ECU soon.
Picked up the catback from JSC Speed today and will be getting it installed tomorrow over at CBRD. Unrelated, but I also picked up a set of Eibach springs and will be getting those installed ASAP.
That is not one of the options I listed
Old Jan 25, 2008 | 03:53 PM
  #73
old81's Avatar
old81
M6
M, looks like you have a plan, pictures of the R56 when you get the Eibach springs installed and the Alta cat-back.
What is the drop with the Eibach? Are you doing a shock change too?
Old Jan 25, 2008 | 05:48 PM
  #74
ENGINE 58's Avatar
ENGINE 58
adam i got my pnp on the way back to you guys, send me a nice brand new winner when they are in buddy , thanks you have been great . alta is a good company and the people are really nice too. holly said you guys were gigging her about something . some fireman thing? oh well sounded funny. i will have pnp power!
Old Jan 25, 2008 | 06:50 PM
  #75
flaco's Avatar
flaco
Give me a break. This is a self serving thread by a vendor selling a product where most of the buyers send it back, can't get it to work or obviously are so happy that they can't be believed. Meanwhile the only guy who can fix it is on vacation in Hawaii. How much does it cost and are you willing to warranty extending to engine damage?
