Drivetrain RMW tune for my Mini....
Old Jan 4, 2008 | 12:29 AM
RECOOP's Avatar
RECOOP
Today Jan from RMW tuned my highly modified 2003 MCS, and I must say that the results were most impressive, indeed!! I have previously mentioned on this Forum some of the many modifications that have been made to my car over the past 4 years. The ones relevant to the tune are:
WMS Ram Airflow CAI with 65-to-62mm throttle body
17% reduction pulley with 2006 OEM crank pulley
M45 ported/polished supercharger
Gintani custom intake manifold with integral air-water intercooler
JCW 380cc injectors, changed to Bosch 440cc injectors after baseline run and before tune
NGK iridium IX spark plugs and Nology wires
FB Racing Stage II head, valves and springs
CP Racing custom pistons (78mm)
Schrick racing camshaft
Burns Stainless custom 4-1 header (3"), collector and exhaust
The tuning was done on a Dynapak load control dynamometer at Church Automotive Testing in Wilmington, CA. Ambient temperature was about 65 deg F, relative humidity about 42%, and fuel was 91 octane Chevron.
A baseline run was made (stock software), then the injectors were changed from 380cc to 440cc. The change was made because the car was running "too lean for comfort" with a negligible safety zone, especially since it was planned to raise the rev limiter. Jan then tuned the ECU to optimize the equipment combination that was on my car, as well as to provide a substantial margin of safety with respect to the air:fuel ratios. A very brief summary of the results are as follows:
Baseline (stock software; 380 cc injectors)-peak values:
Power 234 hp
Torque 183 lb-ft
After the RMW tune (440 cc injectors)-peak values:
Power 251 hp
Torque 193 lb-ft
Of note, the power and torque increases were made while having a "richer" and safer air:fuel. Furthermore, there was a marked increase in torque at lower rpm's. The torque values from 3500 to 7200 rpm were above 180 lb-ft!
Since the proof of the pudding is in the tasting, I can tell you that the good ole' butt dyno confirmed the observations above. The car is a very strong puller and it's a challenge to keep from spinning the wheels in 2nd and 3d gear (forget about 1st!). On the way home from the tune, I again had a real grin on my face . I'll try to get files from Church Automotive, and, hopefully, I can post some of the graphs.
All in all, it was a fun and very productive day --- thanks Jan .
Old Jan 4, 2008 | 01:50 AM
glnr13's Avatar
glnr13
glad to hear youre happy with it bob
-glen
Old Jan 4, 2008 | 03:04 AM
SpiderX's Avatar
SpiderX
congrats...... I have 380s and Jan has suggested the 440s..... your experience has convinced me......again congrats that is a big number
btw......it has been in the 20s in Atlanta and the streets are dry...... the Mini is running strongest ever
Old Jan 4, 2008 | 03:22 AM
Larry Clemens's Avatar
Larry Clemens
Bob, My car was totally changed by Jan's tune. I only have basic mods (no cam or head) and Jan was able to get almost 220 peak whp and 190 ft-lbs of torque. The area under the torque curve increased significantly and the car pulls like all hell at low rpms and doesn't seem to quit. Congrats on your tune and I hope to see you at Santa Anita next Saturday.
Old Jan 4, 2008 | 03:54 AM
PGT's Avatar
PGT
250+whp is stock Subaru STI territory. Sub 5 second 0-60 times for that car (which benefits from AWD and super sticky tires).
congrats on some nice numbers (even before the tune!). I'm looking forward to Jan touching my car this month.
Old Jan 4, 2008 | 05:18 AM
sprp85's Avatar
sprp85
now you can play with evos and stis.., e46 Ms maybe droollllllllllllll
Old Jan 4, 2008 | 05:19 AM
Maxicooper's Avatar
Maxicooper
Very impressive. Great number indeed.
Old Jan 4, 2008 | 06:28 AM
Jahmills's Avatar
Jahmills
Nice! 250whp is where I hope to be someday, sounds like one badass MINI. Congrats to you & Jan.
Old Jan 4, 2008 | 07:23 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I am glad to see more 250+ Minis!!!
Old Jan 4, 2008 | 07:25 AM
limster's Avatar
limster
If you guys want Jan to tune your cars, you better get in line early. I spoke to Jan this week and he was telling me that he is getting super busy. People from around the world are inviting he tune their cars. I'm just glad that he has time this coming week to work on my car.
Old Jan 4, 2008 | 07:35 AM
Revolution Mini Works's Avatar
we attained these values at 1 to 1.5 richer a/f ratios!
Bob's car is running safe now on pump gas. Bob's car is probably the most CUSTOM modified Mini on the planet still running the M45
It was great fun finally getting it all tied together ..... it's been a long time coming! Have fun with it Bob and start saving for your tire fund!
Old Jan 4, 2008 | 08:09 AM
RECOOP's Avatar
RECOOP
[...Have fun with it Bob and start saving for your tire fund!]
After all the mods to my car, I forgot about tyres . Well, I'll just have to put some kind of limiter under the throttle pedal so that I don't get the car into wheel-spin range .
BTW, if anyone wants to buy a nice set of JCW 380cc injectors, send me a pm and make an offer.
Old Jan 4, 2008 | 09:35 AM
fishbulb's Avatar
fishbulb
PM sent!
..and - wow! that is an awesome tune - congrats!
Old Jan 4, 2008 | 10:29 AM
kalbone's Avatar
kalbone
congratz on the #s!!!
Old Jan 4, 2008 | 10:53 AM
sprp85's Avatar
sprp85
o wait a min, Church Automotive? aren't they well known for higher dyno readings??
thats what I have been seeing in bmw forums.
well its the delta thats important tho
Old Jan 4, 2008 | 11:13 AM
pberry51mini's Avatar
pberry51mini
No Fear Gear
AND - doesn't the Subaru weigh in at more than 1000 pounds heavier (stock) than a stock MCS?
That's got to make even more of a difference!
The 250+ arena is where I'd like to be as well someday, or I may buy the new 2008 STI - that's a nice car and without that 6 foot tall wing.
Old Jan 4, 2008 | 12:15 PM
PGT's Avatar
PGT
not that much, but, yes it's heavier....bigger motor, more doors, AWD system etc.
Old Jan 4, 2008 | 12:21 PM
RECOOP's Avatar
RECOOP
Addendum...
I just returned from a 20' "drive" in the Mini. After letting the oil temp get to about 180 deg F, I began pushing the car, and winding it out to 7500 rpm in 1st through 4th. At that point I got a bit nervous because the gendarmes often have hidden spots. Of course my Escort 8500 could give me an alert, but why chance it?
Well, this car really rocks --- . It's not like my bi-turbo Audi RS6, but this Mini is one very serious automobile. As an analogy to the ole' Timex commercial, "This Mini just keeps on pulling!" While the engine has been made much more efficient, I do think my fuel "economy" will worsen because of the tendency/inclination/desire to "put the pedal to the metal" . As said by a famous British philosopher --- Booyakasha (or something like that).
BTW, the injectors have been sold. Many thanks for all the inquiries....
Old Jan 4, 2008 | 02:52 PM
pberry51mini
No Fear Gear
Man, Hp is quite addicting!
Some is never enough!
Old Jan 5, 2008 | 06:01 AM
Bahamabart's Avatar
Bahamabart
congrats, bravo jan.
Old Jan 5, 2008 | 07:37 AM
TheWrks's Avatar
TheWrks
Coordinator :: Michigan MINI Motor Club
Colt45Magnus
Aug 27, 2024 05:03 AM
W0TM8
Dec 19, 2019 07:50 AM
blackie
Sep 2, 2015 09:16 PM
M7Speed
Sep 2, 2015 01:04 PM
Sep 2, 2015 12:57 PM
