Drivetrain ALTA's GT2560R Turbo Kit... breaking 220WHP!
Old Nov 29, 2007 | 01:27 PM
  #26
mikeg4572's Avatar
mikeg4572
I want one!
Old Nov 29, 2007 | 01:33 PM
  #27
scott48's Avatar
scott48
Originally Posted by mikeg4572
I want one!
hey, you already got the ecu...you can wait...at least for me
Old Nov 29, 2007 | 01:59 PM
  #28
Mad TKD's Avatar
Mad TKD
lol well that narrows it down. Prolly 22-25psi then. The stock injectors have no problem keeping up i guess? Thats pretty awesome if adding the turbo works out. about 7% per lb of boost is what you can expect for power gain then.
cant wait to see the graphs on it overlayed with the stock turbo to see the responsiveness of the new turbo. should be close to stock in some respects because of the higher CR.
my guess ..... 280whp to 310whp Talk about tq steer!!!!!
Old Nov 29, 2007 | 02:02 PM
  #29
mikeg4572's Avatar
mikeg4572
LOL, since I already have the ECU. I can have it tuned for the new turbo....actually I have run out of money for mods, at least until after the new year
Old Nov 29, 2007 | 02:07 PM
  #30
junior1459's Avatar
junior1459
I just have to say..when I got that e-mail this morning.. I had a smile on my face the whole day.. I had to practically run home and jump on the computer to watch the teaser video because my phone would play the video.. I had to rig up a wireless adapter to my computer at work to get the outside internet just to watch this!!! can't wait to see what it comes with and what it's going to make
Old Nov 29, 2007 | 02:08 PM
  #31
byhsu's Avatar
byhsu
Can this be installed on a stock R56 MCS car without having to put in all the other parts (CAI, BOOST TUBE, Down Pipe, Cat back, Turbo Inlet Hose) + ECU?
Old Nov 29, 2007 | 02:13 PM
  #32
Mad TKD's Avatar
Mad TKD
byhsu:
In order to get all the benefits you prolly need everything you listed. I imagine ALTA will come out with a kit tho including most of the parts listed.
you will need ecu, turbo, piping, FMIC at least.
Old Nov 29, 2007 | 02:26 PM
  #33
KNTRKTOR's Avatar
KNTRKTOR
Good Job guys
Now, when can I place my order?:impatient Hopefully before you ship the ECU so we get all the mods nicely tuned at once
Old Nov 29, 2007 | 03:11 PM
  #34
minipete07's Avatar
minipete07
i say you guys are running 28 psi and are hitting 300whp...??..but it's time for a new clutch...?? I'm i getting warmer??
Old Nov 29, 2007 | 04:01 PM
  #35
ALTA2's Avatar
ALTA2
Manufacturer
Well in a couple of hours, i think you'll want to hard wire a wireless card to your brain!
Yes, but i don't think that is the way we will sell it. Meaning, it can be done, but up to a certain level of HP, the stock turbo is going to be recommended.
Originally Posted by Mad TKD
byhsu:
Originally Posted by KNTRKTOR
Good Job guys
When, that is a good question, i would say by the end of the year, we will have the kit ready to order, and ship a few weeks later.
28psi (if the turbo could do it) would get us to way beyond 350WHP!
Old Nov 29, 2007 | 04:09 PM
  #36
minipete07's Avatar
minipete07
ok then...22 psi and 300whp...warmer yet?
Old Nov 29, 2007 | 05:12 PM
  #37
ALTA2's Avatar
ALTA2
Manufacturer
I kept my word of a couple hours...............
ALTA R56 GT2560R TEST AND TUNE RESULTS
Click Here for the compete write on our site
Finally we have the tools to tune it, and finally we can install the kit on the car and make some power! With our kit we have the ability to throw on 4 main turbos. The Garrett GT2554R GT2560R, a GT2854R and GT2860R. There is even a crazy GT2871R, which is good to 450 engine HP, but we won’t be using that for a little while.
We are starting out with the Gt2560R turbo because we feel this is the best-matched turbo for the Mini. This turbo should be pretty responsive, and still be able to make about 300HP at the engine. We expect this turbo to spool about 1000 RPM later than the stock turbo, but make about 50 extra WHP up top. But this is all just a guess until we start tuning the car.
The other turbos that fit this kit will be a good option for those who are looking to get a few extra HP beyond this. But the reason why we didn’t start with this is because of lag. We think these other turbos are not going to build boost until way after 3000 RPM. While this may not sound that bad, when you compare that your R56 builds boost at 1500 RPM, this not the best option.
The above charts are Compressor maps for the GT2554R and GT2560R turbos. The plotted lines represent engine airflow at different pressure levels starting with 2000 RPM and stopping at 6500 RPM.
Before we even started to build the turbo kits, you can see that these are the best choices that fit the 1.6L. While the charts start at 2000 RPM, neither of these turbos will build 14psi at 2000 RPM. So keep that in mind. The GT2554R map fits the 1.6L best given the engines 6500 RPM redline and the reasonable boost levels we would be running. But as it gets to 6500, the efficiency really drops off. The larger GT2560R would give us the best power, because of how much more efficient it is toward redline. That extra 5-10% points in effiecency is free HP! Also this turbo will not have the surge issues the smaller one will have running 20psi at low RPM. The only down fall is a little bit more lag. But given the same turbine wheel and AR, it will be pretty minor. Plus the GT2560R would be the best choice when it comes time to raise the redline!
For those who hadn’t seen the R56 turbo kit we have brought to a few shows, here are some other pics for you.
These are the pics we showed a few months back before our trip to the Dragon. Until now, this kit was just pics waiting for some Engine Management. Hmmm, where can we get that??? Unichip!!
Here is the turbo kit installed on the car. Besides the huge turbo, its not too much different than the stock setup, as things are laid out very similar.
Engine bay shot. Everything looks like its supposed to be there! The only thing missing from the pictures is the heatshield.
Nice shot of the Garrett GT2560R turbine wheel and wastegate.
I think Mini needs to build a bulge in the hood for our turbo!
So what comes in the kit? Lots of things but rather simple things. The big part of the kit is a Garrett Ball Bearing Gt2560R turbo. This is an off the shelf Garrett turbo, we do not modify it in anyway to work on the Mini. This is important, as if anything ever happened (out of warranty) you can get the parts from tons of different places. Also this is important, as there are some other turbo options for going bigger (or smaller) down the road. The rest of the parts include the Turbo Adapter flange, oil line, coolant lines, oil drain hoses and flange, ALTA Pyroshield hose cover, Turbo inlet hose with adapter for intake system, Turbo outlet adapter, boost tube coupler, Turbo heat shield, ALTA Manual Boost controller, ALTA recirc BOV, ALTA UNIchip and last but not least is a catted shorty downpipe. So what do you need to complete the kit from there? You need to have at Alta Turbo back Exhaust, ALTA intake and ALTA Front Mounted intercooler, along with a boost gauge. This is how our car is setup currently with the turbo kit to show everyone what they can expect from their mini.
DYNO TIME!!
We tried to run the least amount of boost possible to get a good starting point……but that’s no fun!
A couple things to clear up first. We used our last published runs did on the stock turbo to compare the turbo kit against. At the time we published those numbers, they were the highest numbers we had ever gotten, and the highest anyone else had ever gotten. These runs showed 265ft-lbs and 220 WHP. These runs are with our Turboback Exhaust, Front Mounted Intercooler, Cold Air Intake, Turbo inlet hose, and boost tube kit.
This is the boost we started out with. The blue line represents the boost we run on the Stage 3 Unichip tune. The 21psi-14psi boost curve happens because of the turbo starting to run out of air, and the efficiency of the turbo dropping off. From the first few runs we could tell that the turbo wasn’t going to build full boost until just after 3000 RPM. Not bad compared to other turbo cars out there. Or for a turbo kit.
The HP results were better than we expect. Looking at peak numbers, we were still hitting 220 WHP, but at a later RPM. The turbo builds full boost about 1000 RPM later, which driving on the road is hardly noticeable. With some initial runs showing a loss in peak torque, it looks like it time to work our magic.
Before we go nuts with trying to blow up the engine with 25psi, we needed to test the waters a bit. So after we got the ECU dialed in at 16psi, it was time to turn it up a bit to 18psi. The one thing we really discovered is how smart the ECU is. The entire time we have been playing with this car, we haven’t heard a single bit of knock. But we see evidence that the ECU pulls timing, and adds fuel when it gets a bit noisy. I think that it’s a bit sensitive, but that is a good thing. After a couple of hours of tweaking and learning, we came to what you see below!
If you look at peak torque numbers, we actually beat our previous numbers with the Unichip, stock turbo and all the other bolt-on parts. Its not a lot but we beat it. But from 3500RPM on up, the ALTA turbo kit wins everywhere! Instead of a bunch of low-end power and a huge loss above 4500, you now have a steadily increasing power curve all the way to redline! 60WHP and 45ft-lbs of torque at 6400!! The graph shows exactly what the car feels like, nice smooth linear power across the RPM band.
This is a safe tune with safe numbers, and safe boost levels, safe AFR’s, and best of all your traction control still works, cause you will need it!
Comparisons of ALTA Turbo Kit to Other Cars
So what does all that mean? Well here are some other dynos of cars to give you an idea what to expect.
This was our runs on our R56 with all of our bolt ons, but NO Unichip tune. So stock boost levels (kind of), and a rather tame 200WHP. If you compare our turbo kit to this setup (which is still beyond what most people have), it wins everywhere beyond 3000rpm. This might look bad on a graph, but who drives below 3000 RPM!
This is my favorite one. Not that the SC R53 is not a fun and fast car, but check this out! 60-70WHP gain from 4000rpm on up, and nearly 100ft-lbs of torque that might be noticeable! The only thing that the R56 needs is a little RPM! Then it will really compare.
Ok, this one isn’t a Mini, but it is a car that people mod and a car you see a lot of. This is a 2002 WRX with a catback exhaust and a custom tune. So which car would be faster in the 1/4mile?? Tuff to say, but its an interesting comparison.
Conclusion!!
Yes, the turbo works, and makes power! Yes, it looses some low end power in trade for some top end power. At least with the way I drive, as long as I am at 2500RPM or later, the car is just as snappy as the OEM, and way snappier after 4000RPM. I think the one think I really like is the car is way more drivable. Meaning that instant switch type power is gone. While the instant switch type power sounds good, its not the smoothest power delivery. When feathering the throttle. With the added lag of turbo at lower RPM it feels like I could drive my wife to dinner, and she would have no idea that something was done to the car (which is a good feature for some). But then when I put my foot into above 3000, the car really comes to life. Track guys will like this setup much more, as there is more predictable power, and better application of the power. All this power is still with (2) 49 state legal cats, which means the tail pipe emissions are going good, and still nice and quiet!
Whats next?
Well, that is easy Water injection, and more boost! The water injection tests are done but we are going to give you all a little while to digest the info presented above. We feel that 18psi is perfect for the street and perfect for our base kit. Can we go more? Sure with water injection, we can surely turn the boost up a bit to 20psi to make some glory runs, but this is not where we will leave it for customers. In the next few days you might see 300WHP, but only with the water/meth injection turned on.
SO 250WHP IS THE NUMBER TO BEAT! Or better yet, an 80WHP and a 70ft-lb gain over stock!
Old Nov 29, 2007 | 05:28 PM
  #38
thlaxx's Avatar
thlaxx
damn.
would you like a cookie? haha
Old Nov 29, 2007 | 05:31 PM
  #39
scott48's Avatar
scott48
very cool stuff!!!!!.....is that turbo still a twin scroll turbo like the oem one?
Old Nov 29, 2007 | 05:41 PM
  #40
PGT's Avatar
PGT
heat shield?? what's the scoop there. I don't see one listed and surely you are running one.
Old Nov 29, 2007 | 06:00 PM
  #41
07 MCS's Avatar
07 MCS
oooo yea not the biggie... how much?
Old Nov 29, 2007 | 06:05 PM
  #42
scott48's Avatar
scott48
I'm curious to see the results with the GT2554R turbo cause I'm not really a fan of the lower torque and hp numbers than the oem turbo with ecu tune, until the bigger turbo finally builds up boost at like 4500rpm.
Old Nov 29, 2007 | 06:34 PM
  #43
Mad TKD's Avatar
Mad TKD
do you guys plan on tuning with race fuel? I know in my supra the limit for me was 16-18 psi on pump.
Now with race fuel its a whole different story. Timing can be tweeked a bit more and no knock. I know thats why you using the meth too.
That dyno curve reminds me alot of some turbos i had on my supra. I started with a 63mm which had the turbo come on about 3000rpm and you are right once you get used to driving in the power band lag really isnt a issue. The car will be more predictable with power and as the dynos show its still gaining till redline. Next really what is needed is a raised rev limit to extract every bit of power.
Old Nov 29, 2007 | 06:56 PM
  #44
ALTA2's Avatar
ALTA2
Manufacturer
Originally Posted by thlaxx
damn.
I do like cookies
Nope, single scroll.
Pics do not have the Heat shield, but there is one that comes in the kit. We didn't want to hide everything
Well, like we tried to explain, the Gt2554R is not going to spool a lot different. Both turbos have the same AR, and the same Exhaust wheel size. So the turbos will spool about the same, but one will flow a bit more air. The bigger turbo will only spool a little slower because of the heavier setup. So maybe 100RPM sooner? Not enough to get back the low end power.
Going to a smaller turbo will just be more of a trade off. Less top end potential, for a little gain down low.
Don't forget, compared to your car now (no ECU flash) the turbo kit will just make more power from 3000 RPM on, and if you had the flash 3500RPM on.
The water injection tune is done, those results will be posted somewhere else, on a different day. Maybe tomorrow. We did go quite a ways beyond 250WHP with this setup. On the same boost!
Race fuel tune, sure, but not important as the Water/MEth injection is a better solution for the daily driver guy. I think you will surprised what we can do with the WI setup.
Old Nov 29, 2007 | 11:54 PM
  #45
JohnTurbo's Avatar
JohnTurbo
Let me be the first to say... "I'M IN."
Seriously, put me down for one as soon as they're ready. You guys have my CC info.
-John
Old Nov 29, 2007 | 11:57 PM
  #46
danielo's Avatar
danielo
Can i see the AFR for the setups?
Old Nov 30, 2007 | 12:15 AM
  #47
chuntington101's Avatar
chuntington101
very nice piece of kit there alta! big thumbs up to you guys!
any chance of making it twin scroll?? im pretty sure you can get twinscrol housings for that turbos (might be worng).
Cheers
Chris.
PS what the maximum quoted BHP for this turbo????
Old Nov 30, 2007 | 01:00 AM
  #48
msh441's Avatar
msh441
Adam, you guys never fail to amaze!
A+
Old Nov 30, 2007 | 07:37 AM
  #49
ALTA2's Avatar
ALTA2
Manufacturer
This is the graph most people should compare to. THis shows every single bolt on part we make, with a stock ECU tune. Then compares it to the Turbo kit. Who can complain about 3000RPM!
Old Nov 30, 2007 | 07:50 AM
  #50
ALTA2's Avatar
ALTA2
Manufacturer
Cheers
Chris.
No, Garrett doens't have a twinscroll housing for the small turbos. IMHO, Twin scroll is not that big of a deal for small turbos. I know Mini goes on and on about how its way better, and better efficiency, and quicker spooling. On a smaller turbo, i think its more of a "Feature". Mini gets more efficiency from the turbo, by leaving the Wastegate door open while idle and cruising. But that is a whole other Thread to start.
Maximum Engine HP for this turbo is rated at 330HP. On a couple of applications, we have gotten very close to the maximum rated HP, but at the wheels. Depending on the setup, and how much you want to push it, i think it can do over 300 easy.
-John
You got it!
