Drivetrain ALTA's GT2560R Turbo Kit... breaking 220WHP!
It is the adapter, but it is what makes the kit so simple, durable, and easy to install. When we were trying to figure out where the turbo goes, it truly fit best about where the OEM turbo sits. So instead of an expensive manifold being made, this simple adapter was what we did. Because of the space constraints, we didn't feel it was worth trying to make fabbed manifold. Or add alot more cost to the kit.
I know you probably dont want to over complicate things but if I were interested I would like to know the compressor wheel type(Q,R,S) and ar. Also would like to know if you would interchange them.
D
D
4.1 is what we have always used on our Yellow R56. The other numbers are from when we dynoed the GP and the WRX. With the Dynapack software, it loads in parameters from the cars, everytime you load in a new car it plops that in there. Its kind of a pain because it doesn't say what Gear ratio is for which car. At least on the screen we use for the internet.
We were finding that we were off about 25-50RPM at redline, and we were going to redo the calibration for RPM. BUt we didn't want people to think we were pulling a fast one. So we kept the 4.1 ratio.
The Adapter I assume. Well, i would like to say its made of a custom formulated Stainless steel with special amounts iron, carbon, chromium, nickel, niobium, molybdenum, and titanium. But that's whats in 304SS already. The adapter is a machined 304SS piece.
Nice, I have your WI/meth kit on my legacy with tmic. Though I wish it could flow a tad more for my application.
http://sutternow.com/pics/lgt/dynos/...mp_vs_meth.jpg
Did you actually make 20WHP with just water or 50/50?
Roughly next year, before summer. We could have them ready to roll right away, but we want to do some more testing.
We do have pics, but the transition is kind of special. As is some of the small features of the flange. When we start selling the kits we disclose all aspects of the kit, but until then..............
CLICK HERE TO VIEW ON GARRETT'S SITE
The compressor wheel is a 60trim, 60mm Exducer wheel. The turbine AR is .64, which is the only size they have. The compressor AR is not important, but it is a .6AR. Hope that answers some of the basic questions!
But thanks for the info!
OK, two questions that I asked via e-mail... but might be more appropriate to put here in case someone else was wondering as well:
Heat. Does the larger turbo put out more heat than the allready-really-hot stock turbo? If so, how do you deal with that? Heavier shielding planned? Some type of additional cooler? I understand the larger intercooler is recommended... but anything else, considering the stock turbo has melted a few hood scoops out there?
Also, I understand the GT turbo won't play nice with the stock ECU set-up... but how about the JCW ECU? Or would your aftermarket ECU be an absolute necessity in addition to the turbo kit itself?
Here is the heatshield i whipped up. Its a prototype, and not final by anymeans, but if the Air temps stay nice and cool, the final version will not be too much different!
And another one from another angle.
Actually lets look at the Compressor maps i posted previously.
If you see the smaller turbo is less efficient at higher flow rates and pressures compared to the bigger turbo. At red line, the small turbo is in the 60% efficiency range where the bigger one is 74% range. The higher efficiency means cooler denser charged air, and means more power!
Small turbos always have a falling boost curve because of the efficiency dropping off. With the bigger turbos being able to flow more air, efficiently, they can hold boost better through the RPM range. Which is why you see a solid 18psi on gt2560R turbo kit, and a 20psi, falling to 13psi on the stock turbo.
But that is all about the Compressor side of the turbo. On the turbine side of things, they too run cooler. This because they are less restrictive. Generally the more back pressure the more heat, and with a turbine wheel that is larger than the OEM turbo, that mean less backpressure.
And example is, we have a cool pic of the stock turbo glowing red hot. On the dyno, the GT2560R didn't hardly glow red at all.
But a larger intercooler is an important item for this setup because cool charged air is very important for keeping things working consitantly and safe. At the air flow levels this turbo can push, the stock Intercooler is going to be a restriction!
The GT turbo will not work with the stock ECU because of it seeing too much boost too much air flow, and some other things. The JCW ECU will have the same problems. So yes, the Unichip is 100% needed to run the car at any level of boost over stock boost settings.
300 is knocking on the door, but with the water/meth injection. Results posted in a day or so.
Will getting rid of one make more power? Yes, but not as much as one might think. Will it make the turbo spool quicker? YEs but i bet not even 100RPM. As time passes, we might try removing one, but this not something we would sell. We would just do this to prove that 2 high flow cats make similar HP as 1 high flow.
With the water injection, we are seeing..........
Our downpipe has a high flow cat in it, and so does the midpipe. This is just like the OEM parts, and to be legal, you have to keep 2 cats, and keep them in the stock locations. Its not a matter of emissions passing(because one cat should be just fine for that) its a matter of being legal. Its illegal to remove or move a fully functioning catalytic converter or any emissions control device.
Is there an advantage using the polished boost tubes vs. the silicone tubes? Are the polished tubes necessary for the turbo setup, or would the silicone tubes still be usable they were already installed prior to having this turbo kit installed?
