Drivetrain 5:50 mobil1
Old Oct 21, 2007 | 10:55 AM
gooner's Avatar
gooner
5:50 mobil1
My 2002 Cooper S has 60000 miles and want to know if I can use 5:50 mobil 1 oil
Old Oct 21, 2007 | 11:54 AM
kapps's Avatar
kapps
5w-50? That's some thick stuff. I'd go for 0w-40 if you want M1.
Old Oct 21, 2007 | 12:46 PM
Rich.Wolfson's Avatar
Rich.Wolfson
What is your change interval? Artoo (2003 stock Cooper S) gets his oil changed every 5000 miles with Mobil 1 5-30 since the beginning. He burns not a drop of oil between changes now with about 75000 miles and I am not considering changing.
Rich
Old Oct 21, 2007 | 03:36 PM
Maxicooper's Avatar
Maxicooper
Rich
+1.
Mobil 1, 5W-30.
Old Oct 21, 2007 | 05:35 PM
MINICHEF's Avatar
MINICHEF
A 5W oil is a 5W oil. the 30 or 50 is the breakdown level of the oil and the W stands for winter.
So, a 5W- 30 is a 5 weight winter grade oil with a 30 weight breakdown level, ect.
Old Oct 21, 2007 | 06:52 PM
90STX's Avatar
90STX
I think you might want to research that again. 5W30 and 5W50 should both behave approximately the same at cold temperatures (say engine startup), but the 5W30 will be thinner at normal operating temps.
I'd recommend against using the 5W50 in the MINI.
If the OP is concerned with the miles on your engine, I'm still using 5W30 in mine at 113K with no issues or change in oil consumption for what that's worth.
Scott
90SM
Old Oct 21, 2007 | 08:41 PM
MINICHEF's Avatar
MINICHEF
http://www.mobiloil.com/USA-English/...s/Mobil_1.aspx
Old Oct 22, 2007 | 01:17 AM
UKSUV's Avatar
UKSUV
I was told BY Mobil to run 0w-40 in all my vehicles (here in AZ)
cccplus
Feb 19, 2018 07:20 PM
oeklm
Feb 17, 2016 01:00 PM
GPToyz
Nov 27, 2014 12:10 AM
spell
36
Dec 11, 2011 02:11 AM
MINIotaple
Mar 17, 2006 04:48 AM
