Drivetrain Three weeks to break in a belt, to stop slipping?
Old Oct 9, 2007 | 05:47 PM
MarioKart's Avatar
MarioKart
Vendor
I have had many broken belts and tensiors in my one year (I think about 8). I have noticed each time I get a new belt I lose about 1.5psi for about 3 weeks or 1500 miles. Once I hit 1500 miles, I gain the 2psi back. It seems like there is some sort of coating on a new belt that makes the belt slip until it is broken in. Is this just me?
M
Old Oct 9, 2007 | 06:35 PM
El_Griton's Avatar
El_Griton
what kind of belts have you been using. 8 seems rediculous to me!
btw: i have 15,000 miles on ONE belt with my 19% and have yet to replace a tensioner.
Old Oct 9, 2007 | 06:39 PM
MarioKart's Avatar
MarioKart
Vendor
I have had, napa, gates, JCW, OEM. I have gone through 3 lighten pulley, 1 05 pulley and an 04 pulley. Not to mention 5 tensiors. I'm nervous to drive my car out of town.
Old Oct 10, 2007 | 01:50 PM
ceo51378's Avatar
ceo51378
Thats insane. I just replaced my belt after 40K miles (which I wouldn't recommend waiting that long). Did you install your pulley yourself? Did you check to see if everything is lined up right while the car is running?
Old Oct 10, 2007 | 03:04 PM
PenelopeG3's Avatar
PenelopeG3
That doesn't sound good. I would suspect that either there is something consistently wrong with the installations, the bolts are screwed up or the pulley shaft or SC is screwed up somehow.
Old Oct 10, 2007 | 04:28 PM
minimusprime's Avatar
minimusprime
Wow. 8?
I tend to beat on my car when I can. I'm on my 2nd napa after my oem. 40k on the odo. I haven't noticed any real difference when i put a new belt on.
Old Oct 10, 2007 | 04:49 PM
omnivector's Avatar
omnivector
Along the same lines, I'm curious if I should be concerned: I got my 15% pulley at 16k miles, and I'm just about to hit 30k. Should I get my belt replaced before a do a track day in a couple weeks or will I be fine? The guy who installed it said I should replace the belt every 16k miles with the new pulley and it's already close.
Old Oct 10, 2007 | 04:56 PM
MarioKart's Avatar
MarioKart
Vendor
I have had everything looked at multiple times by 3 different mechanics. Now I have added the Detroit Tuned Tensioner Stop, so if the belt does break again at least it won't distroy my pulley and tensioner. It has been 3 weeks of hard driving and so far so good.
Old Oct 11, 2007 | 08:27 AM
ALTAPerformance's Avatar
ALTAPerformance
I agree that seems VERY extreme, especially after replacing the tensioner. We would all agree that checking the tension, and condition of the belt (along with a plethora of other things) prior to a track event is an EXCELLENT idea. No fun being stuck with a busted belt at the track!
Belts should last longer than 16K and closer to 50K. Earlier models 2002-03 were more prone to belt breakage and wear. Also, when replacing a tensioner, order one for a later model to be sure to get the latest revision.
Good luck!
adam@altaminiperformance.com
Old Oct 11, 2007 | 09:23 AM
thulchatt's Avatar
thulchatt
Good luck!
So are the tensioners the same for all years?
Can I put an 06 on my 04 MCS? Is it really much different?
Old Oct 11, 2007 | 10:08 AM
ALTAPerformance
I belive that early cars have a tensioner that was more prone to issues. I believe all years are interchangable. If you can get the newest one. I would ASSUME that MINI puts the latest variant in the replacement parts bin, but can't always be sure.
12magnum
Aug 31, 2015 08:22 PM
PhoenixR61
Aug 19, 2015 10:27 PM
minipopkart
Aug 13, 2015 05:22 AM
