Drivetrain What kind of numbers should I expect?
Old Sep 25, 2007 | 05:06 PM
iscruz7769's Avatar
iscruz7769
I'm about to start modding my R53's motor. I already ordered a Dinan exhaust, Alta 15% pulley, Alta CAI, Screaming Demon coil with Nology Wires and Alta air diverter. What kind of spark plugs should I use? What numbers should I expect (torque-HP)?
Old Sep 25, 2007 | 05:21 PM
MRmidge's Avatar
MRmidge
Denso iridium plugs are some of the best plugs you will find. But, be prepared to spend for them.
Old Sep 25, 2007 | 05:23 PM
mbcoops's Avatar
mbcoops
HP - 160ish at the wheels. TQ - no idea. Just my guess.
mb
Old Sep 25, 2007 | 05:34 PM
pauliekeys's Avatar
pauliekeys
Just Dyno'd my car last weekend. I ran 173.39hp and 165.62 torque. You can see my mods in my sig. Temp was 67 F and humidity was at 57%. They were using a Dynojet machine but even with all this info you will find that numbers are all over the place even with the same mod's. For me, it's just a base line to see what improvements there might be with other mod's. Oh wait, my wife just told me that there will be no other mod's. I will add softwear and injectors some day.
Old Sep 25, 2007 | 06:11 PM
Some Guy's Avatar
Some Guy
mb
Sounds low to me. Doesnt the MCS start around about 155whp or something? I really dont remember but i would expect better gains with what you have planned.
Old Sep 25, 2007 | 06:23 PM
iscruz7769's Avatar
iscruz7769
My goal is 170 - 180 hp for now... What else should I do to reach this goal?
Old Sep 25, 2007 | 06:29 PM
Mach V Dan's Avatar
Mach V Dan
Here's a comprehensive dyno test of stock MINIs that we did last weekend.
--Dan
Mach V
FastMINI.net
Old Sep 25, 2007 | 07:07 PM
pauliekeys's Avatar
pauliekeys
I ran the car in 4th. I see that you ran the cars in 5th. I had read from many people that we should dyno our cars in 4th. ? When I went to this shop they were asking me what gear and what read line and so on of course I had no idea. I would have loved to have been at a shop that really had experiance with our cars. I'll have a chance to run the car again in two weeks. Is it your opion that I should run again in 5th ? and if so, what kind of gains should I see (of course it will depend on weather conditions).
--Dan
Mach V
FastMINI.net
Old Sep 25, 2007 | 07:48 PM
HighSchoolzMINI's Avatar
HighSchoolzMINI
MOD MOD MOD MOD and MOOOOOD some more
Old Sep 25, 2007 | 07:53 PM
bluesmini's Avatar
bluesmini
I'd stick with the stock plugs for now. I've seen aftermarket plugs blow out and take the head threads with them. unless of course you want to replace the head. there's lots of power to be had there. how much money do you have?????
Old Sep 25, 2007 | 08:24 PM
polizei's Avatar
polizei
mb
That might be a little low, but my MINI dyno'd at 141whp stock... I have not dyno'd it since the mods, but I do want to. I've been told I should be ~185ish (whp).
-Cody
Old Sep 25, 2007 | 09:59 PM
Some Guy's Avatar
Some Guy
--Dan
Mach V
FastMINI.net
Sweet job man.
Old Sep 27, 2007 | 06:02 PM
Mach V Dan's Avatar
Mach V Dan
Dynojet recommends running the car in the closest gear to a 1:1 gear ratio. In most cases, that's one gear from the top. Fifth gear on six-speed cars, fourth on five-speed cars. That applies for 2WD cars. For AWD, we run them one gear lower because the load is twice as much.
--Dan
Mach V
FastMINI.net
Old Sep 27, 2007 | 06:36 PM
Deviant's Avatar
Deviant
--Dan
Mach V
FastMINI.net
Interesting, is this a common practice with AWD tuning or just something unique to your shop and perhaps a few others?
Old Sep 27, 2007 | 09:36 PM
Mach V Dan's Avatar
Mach V Dan
Which, the lower gear for AWD? Common practice. Otherwise, your dyno run will be really really LOOOOOONG, since the car is trying to spin up the equivalent of TWO car's worth of load.
--Dan
Mach V
FastMINI.net
Old Sep 28, 2007 | 04:10 AM
dmh's Avatar
dmh
--Dan
Mach V
FastMINI.net
...and that gear for the MINI is 4th.
Apr 7, 2020 06:49 PM
Supertractor3
Apr 7, 2017 11:16 AM
xpunisherx
Nov 27, 2015 03:32 PM
Sep 4, 2015 11:43 AM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
