Drivetrain WHY B&M SHORT SHIFTERS SUCK!
Old Aug 21, 2007 | 08:46 AM
  #26
obehave's Avatar
obehave
Really? What's the part number for this kit? What year is the car in question?
Old Aug 21, 2007 | 09:21 AM
  #27
MiniStupidfun's Avatar
MiniStupidfun
This can be found under site guidelines
#2 RESPECT
When posting, both members and vendors must ALWAYS be respectful of fellow members and vendors. Personal attacks, trolling/baiting, deliberate antagonizing, and flaming will not be tolerated. If you feel you are being attacked, report the post or private message rather than replying or flaming back. However, do not use the report bad post feature to "cry wolf" when you are in fact the instigator of the demise of a discussion. Doing so will result in a warning or strike.
Old Aug 21, 2007 | 11:24 AM
  #28
COOPT UP's Avatar
COOPT UP
Jay, I read from an older NAM post that it would. Check the link:
https://www.northamericanmotoring.co...p/t-42372.html
I was looking for a shorter throw and shifter. I've had other B&M shifters in the past and usually you'd get both...a shorter shifter and shorter throw with the design. This one is almost the same height as stock, maybe like a quarter inch lower or something. But yeah, for me it hits the JCW resonator big time. Sounds awful.
Originally Posted by JustJAY
+4 I have a Miltek and don't have any problems. COOPT UP, were you looking for a shorter throw and shorter shifter or just a shorter throw?
B & M and Helix are the only ones I know of that just have a shorter throw.
BTW I am using the newer model
Old Aug 21, 2007 | 11:27 AM
  #29
COOPT UP's Avatar
COOPT UP
Noted. Thank you. I will consider this option in the future.
#2 RESPECT
Old Dec 11, 2007 | 01:34 PM
  #30
agranger's Avatar
agranger
I just installed an Alta Sportone 2.5 and a B&M Short Shifter yesterday. I have the exact same piece as is pictured on page 1 of this thread. I've got a heat-shield sandwitch right now... It's firmly pinned between the top of the resonator and the bottom of the new B&M short shifter housing plate.
I may try and add some spacers to the exhaust bracket to bring it down a bit, but my car is already fairly low and that resonator seems to stick down a bit too far already.
It was also spotless up under the heat shield, so I might just remove the new B&M cover and run without it.
Old Dec 11, 2007 | 01:56 PM
  #31
Beecher's Avatar
Beecher
isnt the b&m shifter adjustable height anyway?
I would also like to stick up for obe, since no one else is. I can understand where he is comming from. He has been around here for a long time, which means he gets annoyed when someone comes on asking question about things that have been asked a hundred times over before (ie pully and swaybar issues i see constantly annoy me even). There is a search option, use it (i know it was used in the case to a certain extent, but ive never been interested in a short shifter and i knew it wouldnt clear most exhausts, i would have learned it from here, cause its the only place i go...) I mean, i dont mean to be rude, but the info is out there.
Plus there is this is some sellers websites
Direct bolt on installation - Some Modification may be required with Borla Race and other Exhausts with Resonator forward of Middle Exhaust Hangers.
its not like this issue is brand new.
I on the other hand am having an issue with a very expensive piece that does not fit my car because my car is at stock heigt, there is no warning it doesnt fit and the manu says they didnt know either. It is being resolved. I didnt come on here right away and say the product is crap.
Im not directing this at the guy who started the thread, im just saying....
Beecher
Old Dec 11, 2007 | 02:19 PM
  #32
agranger's Avatar
agranger
The B&M is fixed height. The new kit includes a cover that drops down about 1" from where the original cover is... this puts it into the space where the heat shield was and into the same space that the resonator on my Alta Sportone is.
Old Dec 11, 2007 | 02:20 PM
  #33
agranger's Avatar
agranger
The cover is underneath the shifter in this pic... black metal with a few holes.
Old Dec 13, 2007 | 11:41 AM
  #34
mach schnell's Avatar
mach schnell
which ssk decrease both height and shift throw
i know that craven is adjustable, but what other ssk's decrease both the height and the throw of the shifter? I really like the shortest, stiffest throw possible (is that B&M - cuz it wasn't in my VW) only other ssk i have experience with is Schnell for Porsche and it was absolute heaven!!!!
02miniSguy
Nov 17, 2015 10:29 PM
vetsvette
Oct 1, 2015 12:59 PM
ToroPerro
Oct 1, 2015 12:54 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Samhillrocks
Sep 29, 2015 12:55 PM
