Drivetrain 911!!
Old Jul 8, 2007 | 04:42 PM
herbie hind's Avatar
herbie hind
911!!
what's the hands down ... best place to plug my boost / vacuum tube into for my cooling mist boost switch .? i'm tee'ed into the big black line that runs parellel to the fuel rail . is this a good sorce ? source? or should i buy some more fittings and tap into the ic ?
Old Jul 8, 2007 | 05:26 PM
StoopidGirl's Avatar
StoopidGirl
Here's a message from Tüls:
there is a line that comes off the manifold right under the charge pipe on the right side... also, the fuel pressure regulator has a line as well you can use... in either case you will prolly need a Tee and extra line...
Old Jul 8, 2007 | 06:50 PM
herbie hind
gotcha thx . longboard suggested the fpr also . thx . gonna haveta shrink my meat hooks a bit .
Old Jul 8, 2007 | 06:53 PM
gokartride's Avatar
gokartride
Wow...I understood nothing at all in this thread. Nothing!!! Fascinating!
Old Jul 8, 2007 | 06:58 PM
herbie hind
**** could you call my theripist ...cause that's the best analogy for my day to day life i've ever heard .
Old Jul 8, 2007 | 07:05 PM
gokartride's Avatar
gokartride
Hmmmmm........now that you mention it, mine, too!!!! :impatient
Old Jul 10, 2007 | 06:16 PM
latte hiatus's Avatar
latte hiatus
There's no way my hands fit into the space between the IM and FPR, so I usually disconnect the hose from the FPR and pull it out from the intake runners. The hose plugs back into the FPR easily.
Old Jul 10, 2007 | 07:37 PM
herbie hind
this is what i did thx . good ol' needle nose . got 15lbs. at idle of vac. then it went up until i presume the bypass started to shut at about 3000.
Old Jul 12, 2007 | 06:14 PM
TampaMCS's Avatar
TampaMCS
Herbie, that is 15 in.Hg not psi. Boost guages usually read in Hg on vacuum and PSI on Boost.
Old Jul 12, 2007 | 09:58 PM
herbie hind
okay!!!!! gosh!!!!
Old Jul 12, 2007 | 11:12 PM
911Fan's Avatar
911Fan
I was all set for yet another Mini beats Porsche thread!
Jtrem
Off-Topic :: Autos
Oct 20, 2006 04:47 PM
clarkdr81
Off-Topic :: Autos
29
Aug 20, 2006 04:53 PM
DarkMiniCooperS
May 16, 2006 08:26 PM
airmini
51
Nov 7, 2005 11:29 AM
adame
Off-Topic :: Autos
Aug 3, 2005 04:31 PM
