Drivetrain Radiator fan
Old Jun 27, 2007 | 07:08 PM
ThumperMCS's Avatar
ThumperMCS
Radiator fan
Does anyone know at what coolant temperature the radiator fan will kick on and stay on after the car shuts off? I don't think I have EVER heard my fan stay on or come on after the car is off, even when its 110+ and have driven hard. Does anyone else find the same thing?
Old Jun 27, 2007 | 07:32 PM
kapps's Avatar
kapps
Yeah, unless you've driven real hard and immediately shut down, it shouldn't stay on. The only time mine's done it was after a botched coolant bleed.
Old Jun 27, 2007 | 09:00 PM
SayGoodbye's Avatar
SayGoodbye
Old Jun 29, 2007 | 02:12 AM
Guest's Avatar
Guest
Mine kicks in quite a bit while the car's running (Mostly when the AC is on as well) i've had it come on 7-8 times after driving, but mostly after leaving the car idling for a while or something. It's done it more after my head install, but it's also making 30 more HP now so i'd imagine that equates to more heat generated. I may have a bubble in my cooling system, to be honest i've never had any overheat issues so I don't really care.
Old Jun 29, 2007 | 05:59 AM
obehave's Avatar
obehave
It may not overheat but if you have a bubble you'll have a localized hot spot. Bad for a number of reasons. Also you could be pulling timing and not know it. Losing hp possibly.
I also wouldn't depend on the OEM temp gauge. In your locale a real temp gauge is almost a must.
Old Jun 29, 2007 | 07:40 AM
RigseyUK's Avatar
RigseyUK
According to my Scanguage 2 my MCS fan kicks in at 110c (230f); normal operating water temp around 90c (194f).
The water temp usually only rises when I'm stuck in traffic.
Old Jun 29, 2007 | 07:42 AM
Loony2N's Avatar
Loony2N
My fan almost always runs for a minute or two after I shut down. I consider that a good thing. My scangauge shows my water temp is in the proper range and consistent.
Old Jun 29, 2007 | 07:57 AM
latte hiatus's Avatar
latte hiatus
I am under the impression that most TC cars do that in order to vent the exhaust fumes and prevent corrosion of the turbines. I don't know anything about TC, though, except that they go zoom!
Old Jun 29, 2007 | 08:07 AM
Loony2N's Avatar
Loony2N
I don't see how the radiator fan can do that. The turbo has an oil cooler that also runs after shut down. But it is much quieter.
Old Jul 9, 2007 | 06:41 AM
Ryephile's Avatar
Ryephile
Actually it's an aux. coolant pump for the built-in turbo timer for the R56.
On the R53, the high speed fan kicks on when the coolant temp is about 220F. The Bentley manual says the exact temp.
Old Jul 9, 2007 | 07:59 AM
norm03s's Avatar
norm03s
Gezzy, this is first gen. MINI CooperS we ain't got no turbo's
Old Jul 9, 2007 | 11:02 PM
4wheels's Avatar
4wheels
I didn't know the fans on these cars would run after shutdown. Mine never has, even after tracking, although I do usually open the hood after a session. I only notice the high speed fan kicking in when stuck in slow traffic after pushing it a bit.
OutMotoring
Mar 3, 2017 06:29 AM
JAB 67
Sep 29, 2015 01:34 PM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
