Drivetrain Bavarian Powerflow Kit...
Old Jun 1, 2003 | 09:13 AM
EliteCooperS's Avatar
EliteCooperS
Want more power out of your Cooper S? Let more air in! Our Power Flow intake kit allows more air to enter the engine than the factory air filter. You'll get stepped-up performance you can both feel and hear power is increased by nearly 13hp and torque goes up by a whopping 12lbft. Polished aluminum housing prevents the filter from sucking in power-robbing, hot air created by the engine. (Plus it looks really sharp in the engine compartment!) Installation is a simple, bolt-on procedure detailed instructions included.
Bavarian Auto
does anyone have this kit?? are the claims of 13 hp and 12 lbft of torque reliable??? that is really high, i think the highest, and it is only 180 dollars?!? anyone have any info on this? randy?
Old Jun 1, 2003 | 09:33 AM
jwhcars's Avatar
jwhcars
Looks nice , I wonder how well it performs ?
Old Jun 1, 2003 | 10:39 AM
macncheese's Avatar
macncheese
Looks like an upside down PROMINI/BMP.
Cheese
Old Jun 1, 2003 | 10:40 AM
EliteCooperS
it says it adds 13 hp!!!
Old Jun 1, 2003 | 10:58 AM
jdw5155's Avatar
jdw5155
I find that pretty unlilkely, but if you believe it go get one, dyno it and let us all know. I have been wrong may times before and I'm not about to quit being wrong now.
Even if it doesn't put out 13 hp it at least looks nice.
Jim
Old Jun 1, 2003 | 11:04 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Cheese
"Inverting of vehicle may be necessary for installation."
Old Jun 1, 2003 | 11:41 AM
EliteCooperS
anyone on MCO own one??
Old Jun 1, 2003 | 12:56 PM
weaverpsu's Avatar
weaverpsu
BMP said it gave about 12hp, in actuallity it gave closer to 7 (without airbox mod.)
I really doubt the claims of 13. My 2 cents
Old Jun 2, 2003 | 06:06 AM
Davbret's Avatar
Davbret
I only saw about 4hp when I dyno'd my BMP intake vs the 7-9 I got on the same day with the Rogue.
And that's definitely a rebadged BMP intake heat shield. No doubt about it. Well, if it isn't BMP, I should say it's quite the knock off. Appears to have a different filter element though.
R
Old Jun 2, 2003 | 07:05 AM
Strad's Avatar
Strad
I emaied them and asked for dyno results. Let's see what happens.....
Old Jun 2, 2003 | 07:22 AM
Strad's Avatar
Strad
I got a response already -
Geoff,
Unfortunately, we do not have any dyno results for this unit as yet.
Patrick Dowling
Who'll be the first?
Old Jun 2, 2003 | 08:08 AM
sanity29's Avatar
sanity29
first i would like to say that that looks just like the bmp one i put in just last week. even the air filter looks the same. so does the bmp one have a k & n air filter or something else. mine isn't k & n and i want to be sure i didn't get something diferent.
also, can someone please tell me more about the air box mod? as my search didn't pull up anything. maybea link to it, or the how-to if someone feels like writing that up.
Old Jun 2, 2003 | 08:14 AM
Nuvolari's Avatar
Nuvolari
>>Geoff,
>>Patrick Dowling
So they claim 13hp gain without dyno testing. What source of data did they use as a basis for the claim? A Medicine Man reading goat entrails?
_________________
Old Jun 2, 2003 | 09:34 AM
friedduck's Avatar
friedduck
See This for information. It's found under the How-To post, which is the first or second post in the forum.
Old Jun 2, 2003 | 12:01 PM
Davbret's Avatar
Davbret
Naw, a mechanic threw bolts on the floor and interpreted them.
R
Old Jun 2, 2003 | 12:50 PM
Strad's Avatar
Strad
Ah, I can see it now -
Tea Leaf and Bolt Pattern Reader
Airboxes Installed While You Wait
Here's tha latest:
>>Geoff,
I'll let you know if/when we get some dyno information on the intakes.
Patrick Dowling
Bavarian Autosport<<
if.......... when.............
OK
Old Jun 2, 2003 | 05:03 PM
EliteCooperS
thanks for the help, keep us updated!
Old Jun 4, 2003 | 03:25 PM
orbhot's Avatar
orbhot
I'm with you all, I highly doubt that it gives a 13 hp increase, but you all should not be so stuck on Dyno results. As many have said, if someone wants to fudge numbers they can get a Dyno to read just about whatever they want. Instead, I would look at the filter and see that it is similar in size and material to the madness, but for a much lower price. The heat shield is an intersting design too.
_________________
[img]albums/album25/agv.gif[/img] VinceAndJessica.com
Einstein said E=MC2, I say S = MC2
Old Jun 4, 2003 | 04:00 PM
Nuvolari's Avatar
Nuvolari
Orbhot said:
>>I'm with you all, I highly doubt that it gives a 13 hp increase, but you all should not be so stuck on Dyno results. As many have said, if someone wants to fudge numbers they can get a Dyno to read just about whatever they want....
Are you trying to tell me that Trippy DIDN'T get a 5hp increase by sawing his ignition key in half? You mean those dyno graphs lied? I'm so disillusioned.
________________
Old Jun 5, 2003 | 01:59 PM
Strad's Avatar
Strad
>>I'm with you all, I highly doubt that it gives a 13 hp increase, but you all should not be so stuck on Dyno results. <<
Understood, but given the results seen on other apparently comparable intakes, 13hp seemed a BIT hard to believe. If it's not 13hp, then it's false advertiving - no? Or, mayby just wishful thinking.
Geoff
rlp
Sep 11, 2015 03:28 PM
mikes603
Sep 11, 2015 11:00 AM
xxTHIR13ENxx
May 30, 2006 09:53 AM
Wookie
Jan 3, 2006 08:43 AM
