Drivetrain Hey jlm. Any plans of making a larger diameter crank pulley?
Old May 21, 2003 | 10:19 PM
timcuculic's Avatar
timcuculic
I would love to have a matching set!
Old May 21, 2003 | 10:41 PM
Casey's Avatar
Casey
no you wouldn't. The crank pulley is a vibration damper...you want to leave that stock. I wouldn't trust replacing it. Do the supercharger pulley and lighten the flywheel...don't touch the crank pulley.
_________________
Cheerio
Casey Swenson
Old May 21, 2003 | 10:54 PM
MCSHP's Avatar
MCSHP
I totally agree, unless somone is going to come out with a larger diameter harmonic balancer this is out.
Old May 22, 2003 | 06:36 AM
Grinder's Avatar
Grinder
Aren't there at least a few companies who have already done this (or are planning to)? I agree, it sounds like a bad idea, but maybe just a small 5-10% enlargement might be alright ...possibly with a stock or even lowered rev limiter to prevent other components from going over design specs? I suppose by lowering the rev limiter you'd loose some potential power, but you still probably get a net.
*disclaimer* I know nothing about the internals and workings of an engine!
Old May 22, 2003 | 08:09 AM
jlm's Avatar
jlm
not sure what the intention is, but, if I was going to re-engineer the pulley system, I would want the alternator, AC pump, power steering to all rotate slower, the blower to rotate faster. Also you want the pulleys to not get too small as that is hard on the belt. So...15% larger crank pulley, stock size blower pulley gets more boost, then you need 30% larger alt, AC pump pulleys to compensate for the faster belt travel and achieve slower than stock rotation to reduce power drag. a lot of trouble.
Old May 22, 2003 | 09:58 AM
Grinder's Avatar
Grinder
jlm, wouldn't you only need to ensure that the different components (alternator, AC pump, power steering) didn't exceed the equivalent of stock redline? I also assume that like the S/C, the components can individually be spun a bit faster than they are at stock redline. Wouldn't that allow you to do a small increase in pulley diamater? I don't know if, say a 5% increase would improve performance by much, but i doubt it would cause many problems...Especially since almost every ECU out there ups the factory redline (meaning the components are already spinning faster than originially intended by MINI).
Old May 22, 2003 | 12:22 PM
jlm's Avatar
jlm
i was intending to reduce the speed of the stock components...old hotrodding trick.
Old May 22, 2003 | 04:16 PM
macncheese's Avatar
macncheese
Homies.
PS is electric.
Cheese
Old May 22, 2003 | 04:17 PM
'*Ace*''s Avatar
'*Ace*'
AC pulley, forget that completely. My AC doesn't work fro crap anyways.
Old May 22, 2003 | 05:25 PM
caddman's Avatar
caddman
i personally dont think you couls oversize the crank pulley as it would hit the tensioner not enought room idea great real world not possible
Old May 22, 2003 | 08:36 PM
orbhot's Avatar
orbhot
I was told that 15% is pretty safe, but also as high as you want to go. Some are doing a 17% pulley, but that's asking for trouble. If you increase the diam of the crank pulley, I think it will push it beyond reliablity.
chrisx18240
26
Mar 16, 2022 09:56 AM
Toolman
Jan 20, 2016 06:50 AM
theblackfalcon
Oct 11, 2015 09:49 AM
keck.j
Aug 18, 2015 08:18 PM
Lt. Dan
Aug 10, 2015 12:46 PM
