Drag Racing 1/8 and 1/4 Mile MINI Runs
Launch Tips?
Old Apr 27, 2007 | 09:01 AM
DrkSilver163's Avatar
DrkSilver163
Launch Tips?
Hey everybody, im Participating in the Winged Warrior III event which entails not only an autocross, but a Drag as well...which poses a problem....I dont exactly know the best way to do this. It seems simple enough, floor it when the light turns green. But are there any launch tips for a FWD car that i would benefit from? thanks
Old May 29, 2007 | 08:01 AM
HighSchoolzMINI's Avatar
HighSchoolzMINI
hold a rev at around 4500rpm where the peak torque is and when you drop the clutch put the pedal trhough the floor until you hit redline
Old May 31, 2007 | 07:53 AM
Paul Webster's Avatar
Paul Webster
What tires are you allowed to use??
Old May 31, 2007 | 08:05 AM
Motor On's Avatar
Motor On
ASC DSC off.
Old May 31, 2007 | 02:05 PM
HighSchoolzMINI
it depends on what class you run, if you find out at your local track you could probably run the street class with stock rims and tires or mostly anything else except slicks
Old Jun 3, 2007 | 08:29 PM
justintime's Avatar
justintime
dumping the clutch at 4500 rpms will give you alot of wheel spin
Old Jun 3, 2007 | 08:33 PM
justintime's Avatar
justintime
id say rev around 3400 dont dump the clutch to hard cause you want to keep some traction and shift at 7100 mark.
make sure you dcs or asc is off. Id also get some good tires (not sure but I think you should run alittle less tire pressure in the front)
Old Jun 3, 2007 | 09:28 PM
DrkSilver163
The event passed a couple weeks ago. I figured out that its the same basic launch as an autocross, i launched at about 3000, little wheelspin, but mainting traction. I pulled a 15.4 on street tires.
Old Jun 3, 2007 | 09:34 PM
justintime's Avatar
justintime
not bad, is that stock?
Old Jun 3, 2007 | 09:37 PM
DrkSilver163
I have the Alta Intake, but thats it.
Old Jun 3, 2007 | 10:54 PM
billie_morini's Avatar
billie_morini
As stated, you hold the RPM constant while waiting for the flag or light. You hold the clutch just shy of engagment. You may have to practice holding the engine at a constant RPM. Sometimes the flag or light don't go right away and the time always varies. The variation is part of the racing challenge. You have to be used to hearing the held RPM without it getting on your nerves or letting it drop. Guaranteed, the moment you let it drop is when the flag or light will go and you'll be left stone cold. You might practice holding the clutch just shy of engagement, too. I can't speak for all racers, but most of us do/have done many practice starts.
Old Jun 4, 2007 | 02:36 PM
HighSchoolzMINI
Oh yea! makes my friends angry when they get a perfect launch and i still beat em out with the wheel spin
Old Sep 23, 2007 | 07:49 AM
polizei's Avatar
polizei
So you can hold the clutch shy of the engagement point and it won't hurt the clutch at all?
-Cody
Old Sep 23, 2007 | 03:52 PM
isellem's Avatar
isellem
no... but its a good way to burn up the clutch for the beginner...
seriously i would just concentrate on moving to the engagement point as fast as possible as apposed to slipping the clutch lightly with revs...
but thats just my opinon on the matter
do what works for you
Old Oct 7, 2007 | 07:36 PM
nallen00's Avatar
nallen00
Winged Warrior IV...
...maybe you'd be interested in this. Didn't see you at WWIII - you competed? Of course, I was ogling the Noble and Loti most of the day =P If you'd like to help us represent in 2008, PM or email me. They'll be accepting entries in January.
Looking forward...
Old Oct 7, 2007 | 09:03 PM
DrkSilver163
Yup i competed. Took third in autocross and ended up with third overall. Check out the pictures taken by the professional photographer in class E.
I would love to go back next year, it was a great time.
Old Mar 13, 2010 | 02:27 PM
johnpickard79's Avatar
johnpickard79
1. stage deep in the mini
2. hold rpm around 35-3600
3. using one hand on the e brake, hold the clutch just below engagement point
4. as soon as you see the third light on the tree go on, drop the e brake and slip the clutch out.
5. DONT wait until you see green, that is too late
6. make sure to use all available rpm, and lower front tire pressures will help. also if you are running coilovers it is helpful to set them all the way to their stiffest setting on a front wheel drive car, it helps keep the weight on the front wheels.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Costa_D
Oct 24, 2015 08:30 PM
Joeygonz
Oct 4, 2015 09:25 PM
BossyR56
Sep 28, 2015 11:33 AM
whowantstorace
Sep 27, 2015 06:16 PM
