Another question about QD sprays
Old Apr 24, 2007 | 07:49 AM
modernist's Avatar
modernist
Just wanted some input about, which QD to consider. I plan on using a sealant such as Klasse or Epic, then follow up with a top coat of carnuba such as P21s. My question is, since the carnuba doesn't last, should I use a carnuba based QD or a non-carnuba like Slick or similar? Would the polymer based QD be compatible with the P21s wax? I realize that the carnuba coating will diminish as the weeks go by exposing more of the sealant base. Also, what are the merits of one over the other?
Old Apr 24, 2007 | 07:57 AM
MiniMaybee's Avatar
MiniMaybee
Slick is fine for use over natural waxes, though a Carnauba based QD would probably help your top coat last longer. If you are set on top coating the synthetic wax with Carnauba, perhaps you should look at a spray on wax to help your top coat last longer. Once it stops adhering, you know it is time to either switch to Hydro or re-apply your Carnauba again.
Merits - some say they like the looks of the natural waxes better, while some (like myself) prefer the long lasting qualities of the synthetic waxes.
Old Apr 24, 2007 | 08:59 AM
kenchan's Avatar
kenchan
+1 on Hydro especially on commuter cars.
Old Apr 24, 2007 | 10:11 AM
spykdpunch's Avatar
spykdpunch
I'm contemplating purchasing either Slick or Hydro now to keep my Mini sparkling until it needs it's first major detailing job. I plan on using synthetic wax (Epic) when the time comes. Which one would be best? Also, what's recommended on the exterior plastic bits (i.e. wheel arches, etc)?
Old Apr 24, 2007 | 10:24 AM
jwardell's Avatar
jwardell
Typically the recommendation is to use the same-branded QD, as it is chemically designed to bond with your wax and compliment its looks.
But I don't think there is one for Klasse. If you are QDing over carnuba then I would use a carnuba QD. If you are going over the klasse itself then probably any product will do.
Old Apr 24, 2007 | 10:28 AM
MiniMaybee's Avatar
MiniMaybee
I suppose I would recommend the Hydro. It will give you some wax protection until you do a real wax job with Epic, it will give your paint some nice shine and it is safe for your trim (won't cause white marks). If you are looking for trim dressing I would suggest Wizard's Black Renew (available at www.DetailersParadise.com ) over anything else.
Old Apr 24, 2007 | 10:31 AM
spykdpunch's Avatar
spykdpunch
Thanks, MiniMaybee. It seems Hydro is some sort of miracle product, haha.
Old Apr 24, 2007 | 10:37 AM
Mark C.'s Avatar
Mark C.
For QD on carnuaba, I would recommend the Pinnacle Crystal Mist. I use it when I have a Soveran top coat on the car.
http://www.properautocare.com/pin-320.html
Over Klasse, I use the Sonus Acrylic Sprtiz.
Old Apr 24, 2007 | 11:43 AM
kenchan's Avatar
kenchan
carnauba based spray wax is Griot's Spray On wax. it is good stuff.
patsum
26
May 29, 2021 06:29 PM
iclancy82
Jan 2, 2021 08:59 PM
donniedarko
Oct 21, 2015 01:15 PM
rob&JCW
Sep 10, 2015 12:06 PM
