Major wax removal
Major wax removal
Finally getting around to removing Basil's tacky graphics, and am finding quite a large wax buildup along the edges. I've managed to clear one small section using QD and MF, but major elbow-grease required! Any suggestions for a more agressive chemical to cut through this stuff? I'm thinking lacquer thinner, but not sure if that is too agressive.
From my bodyshop days, we used 3M wax/grease remover, but I can't find anyone locally who carries the stuff.
Any suggestions? (something universally available, please. I want to get this done this weekend).
ps: tried Goo-Gone, no help.
yeah paintprep is good. it slightly messes with glass though, I believe and somewhere it says not to use on glass.... so dont spray it on it. I think it did something to mine but wore off eventually with claybarring. You need very little to get this stuff to work. I washed with carsoap, dried it off, claybarred, then paintprep from Griot's, then carnauba paste waxed. That stuff stuck on there like cement with that procedure.
For the graphic removal I've used Undo with great success, and it takes glue residue of easily. You'll find it at JoAnn's craft store or most other craft/scrapbooking stores (but not Michael's). It's used to remove glue from the back of photos with no harm to the photo at all, so figured it would be safe to use on paint and it worked great!
For those that have a PC, this is another place that the PC works great for. Some M80 and a PC cleans up those lines as well as polishes out the swirls. Glad you found a fix!
F55/F56 Latest Mini Connected App . . .
Crimguy
Sep 10, 2015 01:07 PM
ltjpunk7
Sep 6, 2015 07:32 AM
