Dent Removal
Old Feb 22, 2007 | 09:42 PM
MiniSuperCooper's Avatar
MiniSuperCooper
Dent Removal
I posted this someplace else, but I thought I would check the detailing section to see if some of you guys can help. Does anyone know how hard it would be to get this dent removed? How much does this kind of thing cost? ...and these last questions may be dumb, but I've never used my insurance before. Can this kind of thing be applied toward the deductible? If so, will it effect the cost of my insurance? Thank you.
-Seth
https://www.northamericanmotoring.co...ad.php?t=91995
Old Feb 23, 2007 | 05:50 AM
WannaMini_'s Avatar
WannaMini_
Kenchan? He does dent removal and should be able to answer the question. Like I said in your other post, I have almost a nearly identical dent...
Old Feb 23, 2007 | 06:00 AM
kenchan's Avatar
kenchan
hi wannamini!
that needs to be heated up REAL well before pushing out. the access
point is from the front side, remove a couple of screws.
if that's a stress crease you need to get the root cause taken care
first before you fix it. metal has memory and even if it cosmetically
looks repaired, it's going to crease (fold!) again.
it looks repairable, but will need to be careful not to crack the
paint near the bends.
Old Feb 23, 2007 | 06:46 AM
WannaMini_'s Avatar
WannaMini_
Could you go with just about any dent repair shop you think? Or would it be best to have a body shop look at it? And how do you know if it's a pressure dent or some careless twit soccer mom or an oblivious 80 year old with a walker who let their door slam into your car? Would a pro be able to tell a difference? Would the dealer?
Sorry for so many questions, Ken!
ETA - I also noticed that on his, his dent stretches across two panels. My dent is confined to the lower panel. I think a door DEFINITELY hit his.
Old Feb 23, 2007 | 08:20 AM
kenchan's Avatar
kenchan
wannamini- (dang it, im getting bombarded by customers and issues right
now preventing me from finishing my post! ...yah, im at work. )
The quality of the repair depends on the tech. most bodyshops have
a contractor come in. you can check www.dentwizard.com for your
nearest PDR tech to start off, or your MINI dealer will also have PDR
techs come in on usually a daily basis so check there too as the
tech will be more familiar with MINI's.
hard to tell from that picture. i would have to see it in person
and see if there is any stress coming from other panels pushing
against it. also the way the metal is bent at the mounting points, etc.
Yep. your dealer will have a PDR tech that can usually tell the
difference.
Old Feb 23, 2007 | 09:34 AM
WannaMini_'s Avatar
WannaMini_
Thanks, thanks, and more thanks!!!!!
Old Feb 25, 2007 | 01:37 PM
MLPearson79's Avatar
MLPearson79
Ok, those pictures frightened me into running out to check Clara for mysterious creases.
*whew*
Old Feb 25, 2007 | 06:09 PM
kenchan's Avatar
kenchan
was there a TSB on these creases for 06's?
Old Feb 26, 2007 | 09:06 AM
MLPearson79
Not as far as I know. I'm just paranoid
Old Feb 26, 2007 | 09:12 AM
kenchan's Avatar
kenchan
^^ oh, you better check the fracture issue by the front a-pillar on the 06's
then.
j/k j/k just teasing ya.
Old Feb 26, 2007 | 11:00 AM
MLPearson79
*cries*
Stop messing with my head!!
The_Kid
Nov 3, 2016 06:30 PM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
