A good tip to remove wax on plastic trims?
Old Jul 7, 2006 | 06:37 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Hi motorers!
Does anyone knows a good tip to remove wax that is stuck on plastic trims? (lower bumper, side skirts, ...)
I've tried Goo-Gone, and every single time I wash my MINI, I try to remove it.
Any tips are welcome!
Old Jul 7, 2006 | 06:42 PM
chows4us's Avatar
chows4us
Peanut oil
Old Jul 7, 2006 | 07:02 PM
DarkMiniCooperS
Originally Posted by chows4us
Peanut oil
Really?
Just rub some peanut oil on it and it will go away?
Old Jul 7, 2006 | 07:45 PM
moreorless's Avatar
moreorless
Really?
Peanut oil......get it at WalMart.....works perfect.......Les
Old Jul 7, 2006 | 08:04 PM
DarkMiniCooperS
Good! Two votes for peanut oil. I'll get some tomorrow!!!
thanks to both of you
Old Jul 7, 2006 | 08:05 PM
bolus's Avatar
bolus
It looks cooler if you use peanut butter though. Whip out a bottle of peanut butter in front of your friends and take off the white marks on the plastic trip and watch their eyes bug out of their heads.
Real mess though. But very satisfying for the show-off
( see the wheel arch sticky at the top of the detailing forum for more info on a bunch of different options)
Old Jul 7, 2006 | 08:27 PM
bolus's Avatar
bolus
Here's a quick peanut butter demo:
white spot from polisher on license plate frame
Smear on a little PB (no jam)
Wipe off and all done!
Old Jul 7, 2006 | 08:28 PM
schulzmc's Avatar
schulzmc
Yep - I used peanut butter and an old tooth brush. Worked great!
After a few coats of ICE on the black trim it looks fantastic.
Old Jul 8, 2006 | 04:04 PM
hugh's Avatar
hugh
Does the white come back after it rains a few times?
Old Jul 8, 2006 | 04:11 PM
bolus's Avatar
bolus
I notice a little of the white coming back after a few washes. I haven't needed to re-peanutbutter though. Just use some trim detailer like usual and it looks fine.
Old Jul 8, 2006 | 06:32 PM
Motor On's Avatar
Motor On
As long as you remember not to let the dealer wash your car you're in the clear.
Whats all this toothbrush q-tip nonsense I use peanut butter and my fingers and lick the butter off my fingers when I'm done; no worries I have a special jar just for Pearl. I've found using peanut better let sit for a few minutes then garden hose on highest pressure to get it all off then follow up with a liquid NXT or ICE wax, and the white goes away. Remember tape your trim before you paste (there is always a little left to clean up but it saves loads of time).
Old Jul 9, 2006 | 03:18 PM
mcdbrendan's Avatar
mcdbrendan
peanut butter is a lifesaver. my jeep cherokee has white marks on it for weeks until i worked up the courage to use peanut butter. couldnt believe it.
Old Jul 9, 2006 | 04:00 PM
KC MCS's Avatar
KC MCS
I've tried taping off my trim, but the tape just won't stick to it. I typically use Meguiar's trim detailer which looks awesome, but it, as I would assume many other trim conditioners, prevents the tape from adhering.
So, I just have to be very careful when I apply polish and wax with my PC. I usually just run my finger along the edge and let the pad rub my finger instead of the trim.
Old Jul 9, 2006 | 04:08 PM
gokartride's Avatar
gokartride
Just to mention that there are some excellent products that don't leave any white residue on black trim. Might be worth investigating if dealing w/ residue is too much trouble or if you have allergic reactions to peanut butter.
Old Jul 9, 2006 | 04:17 PM
Motor On's Avatar
Motor On
Are there paste options?
I use the NxT for general protection and then a paste once in a while for times when I want I little extra shine/rflection/depth from the JB.
Old Jul 10, 2006 | 06:45 AM
Mr. Pep'r's Avatar
Mr. Pep'r
What are some of these products?
We use Zaino and Mothers Pure Carb(sp). I find with Mothers if I do slip just wipe it up right away with Simple Green on a damp rag. Zaino we have only used once(thanks BradB ) so I do not know.
Althought I have never used this produce the company is top notch and may garage looks like a Griot's store. You can not go wrong with anything they sell. Just bring your credit card.
http://www.griotsgarage.com/search.j...x=0&search.y=0
Old Jul 10, 2006 | 07:00 AM
gokartride's Avatar
gokartride
I use the Klasse twins (All-In-One and High Gloss Sealant)....but I can't imagine there aren't others. I have never had white residue and I apply right on the trim and everything else (except the windshield).
Old Jul 10, 2006 | 01:40 PM
jwardell's Avatar
jwardell
peanut oil will remove some, but when it washes away after a while, you'll still have some white left.
I've carefully used a mr. clean sponge, and it also removed most white, permanently.
But I think the only real answer are cleansers made specifically for the task. I'll be trying forever black in another week or so, which includes the cleanser in its kit, so I'll let you know just how well that works.
Old Jul 10, 2006 | 08:38 PM
cmiller18's Avatar
cmiller18
wax residue removers...
My choices, in order of preference...
1. Pink wedge pencil eraser
2. Mr Clean Magic Eraser
3. Creamy peanut butter
To avoid getting the residue on there to begin with, simply tape off the trim areas before waxing, or just use products that don't leave residue (i.e Zaino, etc.).
Old Jul 15, 2006 | 06:46 PM
DarkMiniCooperS
Thanks guys!
I'll try peanut butter and a pink eraser to get rid of those wax spots.
Thanks again
Old Jul 15, 2006 | 09:05 PM
SSRJIM's Avatar
SSRJIM
I've had good luck with simplegreen on a rag.
Old Jul 16, 2006 | 06:01 PM
DarkMiniCooperS
I've bought a pink eraser this morning and successfully removed the wax spots on the plastic trims!!
Thanks for the help and keep motoring!!
Old Sep 9, 2008 | 04:34 PM
GeorgeG's Avatar
GeorgeG
Peanut butter was a bust for me
I tried creamy peanut butter (Jiffy) on the trim and it looked good at the time. However, the next morning it actually looked worse. Purchased Back-to-Black (Autozone or Wal Mart) and put about seven coats on the trim. Looks good for now.
Old Sep 9, 2008 | 05:16 PM
MLPearson79's Avatar
MLPearson79
Huh, a pink eraser. That's a new one for me. Interesting!
Old Sep 9, 2008 | 05:42 PM
Apple's Avatar
Apple
Mr clean sponges, work great
