Glass cleaner opinions/recommendations/preferences?
Old Apr 2, 2013 | 07:14 PM
CHMhead's Avatar
CHMhead
Just curious ...
1. what the general opinions out there are on the glass cleaner products? Prima Clarity? Adam's Glass Cleaner? SprayWay?
2. Exterior surface of the glass sunroof? Do folks use glass cleaner before/after waxing (e.g. With wax as you dry products like Prima Hydro)...
Old Apr 2, 2013 | 09:22 PM
astroBlackMetallic_Mini's Avatar
I've tried tons of stuff now, and I have to say, NOTHING works like CLAY!
Buy a clay kit, and you can use windex or the supplied lube on the exterior, and just plain old water works fine for the interior windshield
Old Apr 2, 2013 | 09:32 PM
psichick's Avatar
psichick
invisible glass and a microfiber and i'm good to go. been using it for years.
i was always told that if you have tints not to use windex as the ammonia will harm the tint. not sure if it's true or just an internet rumor.
Old Apr 3, 2013 | 05:21 AM
jcauseyfd's Avatar
jcauseyfd
I periodically clay the windshield, usually when I am waxing the rest of the MINI.
During washes, all the glass (sunroof too), gets hit with Hydro just like the rest of the car.
In between and on the inside, if I need a cleaning, I use Stoner's Invisible Glass. I have also used SprayWay and thought it was very good. If I had an easy place to get it locally, I'd probably opt for it over the Stoner's. I tried Prima Clarity, but did not like it - there are a lot of people that do like it though.
Old Apr 3, 2013 | 06:47 AM
NJ Mini's Avatar
NJ Mini
When doing a full cleaning/polishing/waxing, I clay the windows after I clay the car and will clean the windows after waxing. This is to remove any dusting that may have been kicked up after polishing.
During quick cleanings, I'll wash the car and clean the windows and spray hydro afterwards over all surfaces.
I would stay away from windex for the car though. It ruins tints due to the ammonia and it can really dry out the rubber seals around the windows. Clarity isn't bad, but it doesn't need I be anything fancy. Just not contain ammonia.
Old Apr 3, 2013 | 08:57 AM
fkelly5's Avatar
fkelly5
Stoners Invis Cleaner and a microfiber- no pesky streaks
Old Apr 3, 2013 | 09:14 AM
BRGPA's Avatar
BRGPA
I personally do like Clarity. The glass sparkles and it repels rain, too. Stoners is OK, but using newspaper as suggested can leave lots of ink where you don't want it.
Old Apr 3, 2013 | 09:21 AM
Coop-a-Loop's Avatar
Coop-a-Loop
Instead of buying pre-formulated window cleaner for $6 or $7, I mix my own w/ 1 part rubbing alcohol w/ 4 parts water......works great and only cost about 50 cents per squirt bottle.
Yes, I am a cheep screw.
Old Apr 3, 2013 | 11:43 AM
JimW's Avatar
JimW
Recently purchased Prima Clarity and I am very impressed. I did just clay the windows, but I thought Clarity produced great looking windows.
Old Apr 3, 2013 | 02:57 PM
Capt_bj's Avatar
Capt_bj
a couple of times a year I run over all my outside glass with a single edge razor blade aka window scraper. You'll be amazed what comes up if you've never done this before.
I clay as well. Don't buy special new clay for your glass, save the stuff you used on the paint and rotate this to your glass hunk. next time you buy new clay for the paint, hand down etc etc.
also important: clean your wiper blades when you clean your glass. The crud they remove from the windows often sticks to the blades. When you wash the car be sure to wash the blades checking for stuck on bug guts chunks and the like
Old Apr 3, 2013 | 05:13 PM
Tarbot's Avatar
Tarbot
Clay all the way
Old Apr 3, 2013 | 09:06 PM
CHMhead's Avatar
CHMhead
Very helpful! thnx!
Old Apr 5, 2013 | 05:15 AM
phil@detailersdomain's Avatar
any of these glass cleaners will work great.
glass cleaner and sealants
take a look here for some tips.
Old May 12, 2013 | 07:01 PM
afadeev's Avatar
afadeev
Originally Posted by CHMhead
Just curious ...
For #1: http://www.griotsgarage.com/search.d...Descend&pp=100
For #2 same as #1 + a small ladder.
a
Old May 12, 2013 | 07:56 PM
RJKimbell's Avatar
RJKimbell
Here's what I use, this stuff...
or
This stuff...
Griot's now has this stuff too...
All great window cleaners, it's a personal preference on which one to use!!
Old Jul 27, 2013 | 09:20 PM
JBC4317's Avatar
JBC4317
Stoner!
Old Jul 27, 2013 | 09:39 PM
mattkosem's Avatar
mattkosem
My favorite is stoner's invisible glass.
--Matt
Old Jul 28, 2013 | 04:26 AM
Camthewookie's Avatar
Camthewookie
I like the Invisible Glass for quick cleanings, but I agree that clay and/or a razor blade (obviously for exterior only) are great every once in a while for getting all the really stuck-on crud.
Old Jul 28, 2013 | 06:05 AM
danjreed's Avatar
danjreed
Know what works amazing on glass?
Wash car.. Dry car..
Cerama-brite. The same stuff used for glass cooktops!
Gets it clean... Super clean.. Leaves a nice polished coating as well.. Been using it for years.. Put it in, let it haze.. Wipe it off, it's amazing at the gunk it strips off.
Try it,
For side glass and interiors I use Stoners.
Old Jul 28, 2013 | 06:28 AM
JBC4317's Avatar
JBC4317
I love it when I can take something out of the kitchen and into my garage!
Old Jul 28, 2013 | 10:19 AM
cristo's Avatar
cristo
Alliance Member
I usually use either Clarity or Stoner's and am happy with either.
Old Jul 28, 2013 | 10:23 AM
SuperGreg's Avatar
SuperGreg
Make your own. 50% distilled water, 50% isopropyl alcohol and a tablespoon of white vinegar.
No streaks :P
Old Aug 1, 2013 | 01:22 PM
matt922's Avatar
matt922
I must be in the minority... i very rarely use a cleaner on windows.
Wash with car soap, rinse, dry the glass first before drying the rest of the car, and my windows are sparkling clean.
I do apply aquapel every 6-8 months though, keeps those pesky hard water spots from forming on the glass.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
OutMotoring
Mar 3, 2017 06:29 AM
daidaibi
Mar 21, 2016 08:25 AM
gnhovis
Sep 28, 2015 04:07 AM
Mini ni
Sep 24, 2015 05:42 AM
