Removing Tree Sap
Old Sep 4, 2012 | 09:52 PM
SMR05's Avatar
SMR05
Removing Tree Sap
Who has the best solution to remove tree sap off the paint?
Old Sep 5, 2012 | 06:56 AM
Fly'n Brick's Avatar
Fly'n Brick
PM Octaneguy. If he can't lead you thru the process, it can't be done.
Old Sep 5, 2012 | 08:48 AM
MattMatt's Avatar
MattMatt
Meguires Scratch X, followed by a good wax. The hood on my 3 Series (Jet Black) had marks that would not come out with anything else. I can't believe how good it looks. Be sure to follow the Scratch X with a high quality wax using a RO buffer because the Scratch X is abrasive and will cause micro scratching itself that will buff out.
Old Sep 6, 2012 | 04:16 AM
BayStateDetailing's Avatar
BayStateDetailing
I don't think Scratch-x will remove a chunk of sap as that is what I think they mean by this.
If you have an advanced auto in your area go there and get http://www.detailersdomain.com/Stone...tor_p_550.html
It will work really good if it is a fresh blob.
If it is rock hard and has been sitting there for awhile might need to be a little more aggressive with it. And I don't recommend attempting to be more aggressive if you don't know what you are doing. Might want to call a detailer.
Old Sep 6, 2012 | 04:51 AM
daflake's Avatar
daflake
Simple... Pantyhose and Sprite. It will remove the tar and then you can wash and wax the area you were working on.
Old Sep 6, 2012 | 08:38 AM
NJ Mini's Avatar
NJ Mini
Bug & Tar remover should loosen it up. You can use a medium grade clay as well, but it could possibly mar the surface and need some decent polishing afterward.
Old Sep 6, 2012 | 01:53 PM
Capt_bj's Avatar
Capt_bj
if just a few spots, WD-40 on a rag will probably disolve it then re-wax the area.
But if 'all over' ...
Spousal Unit took car on a week vacation once and the car sat parked under a very leaking tree for 6 days. When it came home the entire car was a sticky mess. BTW this was an NA (first model) Miata - no clear coat on the paint for those (most).
I ended up needing two DAWN washes with hot water, then a clay - changing clay 3 times more frequently than normal and some spots STILL needed rubbing compound and a reclay, then a cleaner wax . . . ugh. But it SHOULD be easier to clean a clear coat.
The_Kid
Nov 3, 2016 06:30 PM
BRracing
Oct 24, 2015 10:07 PM
Crimguy
Sep 10, 2015 01:07 PM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
