Decal Residue
Old Aug 5, 2012 | 02:24 PM
joe_706's Avatar
joe_706
Decal Residue
Hi, I recently brought a 2005 Mini Cooper S R53. The previous owner was a lady and she had stuck a betty boop decal under the Cooper S badge. I removed the decal today with a hairdryer and the image is imprinted onto the paintwork. What can I do to remove stain?
Old Aug 5, 2012 | 03:08 PM
Capt_bj's Avatar
Capt_bj
I'd try - in this order (clean one item off well b4 trying next)
WD-40 on a rag (don't scrub, if it is commin' off it won't take much work) {wd-40 is basically dry cleaning fluid}
Goo-gone on a rag (ditto)
3M adhesive remover which you should be able to find at Home Despots or WalMart
a cleaning wax like Mothers (cleaning wax was has a little rubbing compound in it) this one will take time but the very little bit of rubbing compound would eventually get the dye off
Clay Bar (follow instructions on the box)
if none of this works I'd look for someone with experience - any decent detailer should be able to get this off
I'd be moving to mild rubbing compunds next. Some of the pigment has bonded to the clear. You remove clear when you polish - seceret is to remove only 'that much'
tooth paste might do it, but you'll need to get the shine back on the paint after . . .
Once it is off you will need to re-wax this area of course.
good luck, let us know what works for you
of course you could also cover it with something else
Old Aug 6, 2012 | 02:13 PM
BayStateDetailing's Avatar
BayStateDetailing
3m or Tarminator work great.
I used only Tarminator and a plastic blade to do this whole van. Even after using it for months it blew me away. Very safe for paint too. And doesn't smell bad.
Advanced auto usually has it on the shelf.
USA-RET
Oct 10, 2015 09:52 PM
silence2-38554
Sep 28, 2015 12:19 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
kjd186
Sep 9, 2015 10:02 AM
broncobuddha
Sep 1, 2015 06:32 PM
