Prima Hydro Seal Question
Old Sep 6, 2011 | 09:40 PM
JMH_Show's Avatar
JMH_Show
Are there any benefits of using Hydro Seal after every wash in conjunction with Hydro? Hydro Wash > Dry car > Hydro Seal using Hydro as a wet agent > toping it off with Prima Slick.
Old Sep 7, 2011 | 12:15 AM
OctaneGuy's Avatar
OctaneGuy
Hydro Seal claims to have 6+ months of durability. I'm not sure why you would be using HS so often. Personally I would Hydro Wash, Hydro Seal, then maintain with Hydro. I wouldn't top it off with Slick until the polymers were cured...i.e. until the next day. Slick has some cleaners in it that can negate some of the benefits of Hydro.
Old Sep 7, 2011 | 06:05 AM
JMH_Show's Avatar
JMH_Show
Thank you for your wisdom. I sent an email to Prima Care with the same question so I'll post their response as well.
Old Sep 7, 2011 | 05:42 PM
JMH_Show's Avatar
JMH_Show
Here is the email I got from Prima Care.
"Thanks for using Prima. We appreciate your support.
Yes, you can Hydro Seal as often as you like. It will actually layer quite well.
Your plan looks good. I would skip the Slick step. It will change the final appearance. Unless, of course, that is what you are after. There will be no durability benefit of a final wipe with Slick. If anything, you can final wipe with a light spray of Hydro. You can even you Hydro as a quick detailer going forward"
Old Sep 7, 2011 | 05:47 PM
OctaneGuy's Avatar
OctaneGuy
Glad to know we are on the same page, lol.
Richard
Old Sep 7, 2011 | 05:52 PM
JMH_Show's Avatar
JMH_Show
Hydro as a quick detailer. Interesting. I guess I misunderstood the use of Slick. I guess I will use it as a clay lube and for the exterior windows.
Old Sep 7, 2011 | 06:06 PM
OctaneGuy's Avatar
OctaneGuy
Hydro is fine as a quick detailer...consider it as a QD with protective qualities but it's not as slippery as Slick which has no protective qualities.
Slick has some cleaning ability, Hydro has less.
I use Hydro on door jambs and wheels as a cleaner and protectant.
Slick isn't a good clay lube...dilute it 50/50 with water..Slick tends to be too slippery as a lube when full strength. Now you have something like Glide.
Richard
Old Sep 7, 2011 | 06:15 PM
JMH_Show's Avatar
JMH_Show
Richard
Thank you again for sharing your wisdom!
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
potterstein
Sep 4, 2015 01:30 PM
Lex2008
Aug 16, 2015 08:33 PM
