Best way to remove wax from plastic wheel trim?
Old Dec 30, 2003 | 06:50 AM
UKNUT's Avatar
UKNUT
Gave Lynnen his first wax job but got a little on the black plastic wheel trim. I rubbed like crazy but it keeps coming back. Thanks for any input.
Old Dec 30, 2003 | 06:58 AM
ZAKdog's Avatar
ZAKdog
I'ave heard that a plastic polish or enhancer rubbed with a toothbrush and wiped will remove it...in fact, I'm about to try it myself!
Old Dec 30, 2003 | 07:02 AM
BuckeyeMCS's Avatar
BuckeyeMCS
I know someone here mentioned peanut butter and a toothbrush. I tried it and it worked like a charm.
Old Dec 30, 2003 | 07:04 AM
Marcomini's Avatar
Marcomini
Peanut butter is a dandy product, you can water it down with a little warm water, toothbrush it in, voila, but don't use chunky.
Old Dec 30, 2003 | 07:05 AM
Autopia Car Care's Avatar
Autopia Car Care
I don't recommend using any type of polish on your wheel arches, as it will change the finish.
There are a number of common household products that will remove wax from plastic/rubber trim. If you have mineral spirits, use a small amount on a soft rag. Also, as strange as it sounds, a small amount of smooth peanut butter on a soft towel works. The oil in the peanut butter strips the wax.
In all cases, follow with a treatment of vinyl/rubber dressing.
db
Old Jan 1, 2004 | 02:42 PM
KiLO's Avatar
KiLO
I second the peanut butter notion.
Ryephile told me about it after I made the mistake of getting wax on the trim. It worked great.
Old Jan 1, 2004 | 03:24 PM
Ryephile's Avatar
Ryephile
Yep, the smoove peanut buttah is the ticket - available in just about every kitchen
You're welcome KiLO
Another tip - don't use Silicone-based waxes, the silicone is what the white residue is. Use high quality waxes like Zymol Carbon or Concours (not the Cleaner Wax), Zaino, Pinnacle, P21S, Klasse, et cetera.
Motor-On,
Ryan
Old Jan 1, 2004 | 03:31 PM
Autopia Car Care
>>You're welcome KiLO
>>Motor-On,
>>Ryan
Ryan,
Actually, silicons are clear and do not dry white. If they did, our tires would be white from tire dressing. The white residue is normally created by cleaners (polish) in the wax. The reason the waxes you mentioned don't turn your trim white is because they do not contain cleaners.
~ David
Old Jan 22, 2004 | 10:31 AM
UKNUT's Avatar
UKNUT
I ended up trying the mineral spirits. Worked well. Just don't leave it on too long. Thanks for the info.
kazyn
Oct 25, 2019 02:34 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
