Best way to clean inside of wheels?
Old Oct 23, 2010 | 09:43 PM
devicemanager's Avatar
devicemanager
I have the JCW challenge spokes, and after 2 months the front wheels are filthy on the inside where it is tough to reach. Short of pulling each wheel off, what method do you guys use? I tried some simple green to loosen the dirt/brake dust and it had little effect.
Old Oct 23, 2010 | 10:48 PM
Oxybluecoop's Avatar
Oxybluecoop
You'll need to take them off to effectively clean the insides. Then throw a coat of wax on the entire wheel to make it easier the next time.
Old Oct 24, 2010 | 05:55 AM
matthew-w's Avatar
matthew-w
You might consider the PowerStick. It's designed for exactly your application: cleaning the inside of a wheel while it's still mounted on the MINI.
You'll need to do some footwork to figure out _which_ PowerStick you need for your specific wheel:
http://www.google.com/search?client=...9faa430ac3503f
Old Oct 24, 2010 | 06:14 AM
MI MINI S's Avatar
MI MINI S
Harbor Freight has a nice wheel cleaning brush for less then $3.00. I have several and they work great.
http://www.harborfreight.com/15-1-4-...ush-93160.html
Old Oct 24, 2010 | 09:55 AM
Minidrivr's Avatar
Minidrivr
I use these.
http://www.griotsgarage.com/product/...rrivals&page=1
Obviously the best way is to remove the wheels. If you keep the insides waxed with something like Wheel Wax it makes cleaning a breeze.
Old Oct 24, 2010 | 03:01 PM
Hawkeye's Avatar
Hawkeye
Another method is to use RAIN X on the back of the wheels when you have them off (of course, after cleaning them first).
Old Oct 24, 2010 | 04:12 PM
ronnie948's Avatar
ronnie948
Mine come off every 5,000 miles
I rotate my tires front to back every 5,000 miles so when they are off I wash them inside and outside. I have yet to find a brush that will wash the inside of the challenger wheels that came on my 2009 JCW. I do have a good couple of brushes that will do the outside of the wheels. One is a micro cloth covered brush that I got at Pep-Boys about two years ago.
I think if I had a lift I could really keep the insides clean but I don't have one and I'm not about to lay under the car to clean the inside of my wheels while the car is on jack stands.
**** Not much room for anything between these spokes*****
Old Oct 24, 2010 | 06:08 PM
thewebgeek's Avatar
thewebgeek
I have tried a ton of different brushes on my 09 JCW. As everyone else has said, removing the wheels is the best, but of all the brushes I have tried, this one works best for getting the back barrel.
http://www.amazon.com/gp/product/B00...18H806ZTMV02WD
Old Oct 25, 2010 | 11:44 AM
mario@adams's Avatar
mario@adams
Power Stick is the only way to go!
We sell them here:
http://www.adamspolishes.com/p-405-a...wer-stick.aspx
Old Nov 22, 2010 | 10:15 AM
nikmeister's Avatar
nikmeister
what cleaning solution do you use with Power Stick?
Old Nov 22, 2010 | 11:11 AM
mario@adams
Adam's Green Wheel Cleaner works wonders with the power stick!
http://www.adamspolishes.com/p-436-a...l-cleaner.aspx
Old Nov 22, 2010 | 11:14 AM
yetti96's Avatar
yetti96
https://www.northamericanmotoring.co...w-15-95-a.html
Old Nov 22, 2010 | 12:14 PM
jnoll's Avatar
jnoll
I was amazed at how well Westleys Bleche White worked on the back of my wheels. You remember, the stuff you used to use for whitewall tires. Granted this was with the wheels off, but if you have found a brush to get in there this should work great on the car, too. I thought I had them cleaned with wheel cleaner and I grabbed a bottle of this by mistake. Really made a difference.
John
Old Nov 22, 2010 | 01:06 PM
ellcapitan's Avatar
ellcapitan
Whoa, $30 for a brush?! Could you be more specific on just how much better this thing is than other brushes? I was looking at those Griots sponge/brushes too, but they look kind of flimsy and ...disposable.
W0TM8
Dec 19, 2019 07:50 AM
phrza81
Oct 10, 2015 11:37 PM
ltjpunk7
Sep 6, 2015 07:32 AM
StuRat
Aug 24, 2015 06:24 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
