What do you use to maintain the exterior black plastic trim?
Old Jun 23, 2008 | 03:01 PM
  #51
El_Jefe's Avatar
El_Jefe
303 is good if you want to spray and go.
Then you have griot's rubber and plastic stuff, thats spray and go too.
THey really dont last more than a few weeks.
Black wow lasts by far the longest, 3 months outdoors in bad climates. It cleans the rubber as well while you do it. Very good stuff. It is a bit more picky to apply than the other two. One tiny bottle lasts super long, like years.
Old Jun 24, 2008 | 08:25 AM
  #52
Mini2na's Avatar
Mini2na
Originally Posted by RJKimbell
What applicator are you guys using for your BW??
Hey RJ, I use a paint pad (thin foam/fiber pad that is used in trimming and applying latex paints and has a flexible plastic backing - from Home Depot). I cut it down to about an inch square. I've found that the foam can't hold too much BW and the fibers that cover the foam help it last through multiple applications.
Old Jun 25, 2008 | 04:47 AM
  #53
MINIFVR's Avatar
MINIFVR
Does BW take out or remove old wax res or does it hide it?
Old Jun 25, 2008 | 04:49 AM
  #54
BlimeyCabrio's Avatar
BlimeyCabrio
It will take it off with some scrubbing. But I think Richard has another product now (Black Prep or something like that) that's really designed as a cleaner that does it better and easier.
Old Jul 1, 2008 | 01:12 PM
  #55
kevinminict's Avatar
kevinminict
I just bought some Mothers Back to Black and it worked great. I kept my car very clean but it just gave it that extra bang and it looks great.
Old Jul 1, 2008 | 02:07 PM
  #56
cadfael_tex's Avatar
cadfael_tex
Question on applying black wow (haven't seemed to master it yet). When you start out with the dime/pea sized amount, how do you spread it around with out it getting alot in one place and not much in another. I tried dabbing around the skirt but that didn't seem to work to well.
Old Jul 1, 2008 | 02:19 PM
  #57
kenchan's Avatar
kenchan
yah, i used to use that before BW. nice greasey dust magnet.
(not meant to offend, just my experience).
you have to lick the pad first real well.
i take a pea sized and spread BW on my Kiwi foam pad. then
i make one slow stroke down the lip of the arch.
then i do small circles to spread the BW towards the top of the
arch.
i may/may not add more BW on the pad to get to the top edge
of the arch. then i gently work the product in (slowly) until
i see no smears. if i see smears i need to wipe it off with a
paper towel.
Old Jul 6, 2008 | 01:01 AM
  #58
seigmann's Avatar
seigmann
I just recently used a different product on some of my black trim. Its called Bumper Coating and its made by Duplicolor who makes fantastic aerosol products. It comes in an aerosol can so it's easy to apply (two light coats). Its a little bit of a pain to get some trim pieces off but if you're willing to do it the effect is great. My plastic was looking very dried since I live in New Mexico but since I've applied it the plastics stays a deep rich black and will never need to be sprayed again. But, that's only if you want to go the extra mile
Old Jul 6, 2008 | 10:51 AM
  #59
sil3ncer7's Avatar
sil3ncer7
I use Nero.. Maybe I wasnt using black wow right or something, but I found it collected dust like crazy and never got that small amount of wax off the trim..
For me its Nero all the way. I have the BW and Ill try it again, but I have had thee bst luck with Nero. Lasts long, low dust, looks hawt for a week, and I can just wipe the dust off the rocker w/o worrying about loosing the shine...
boostedhaze
Jan 2, 2018 07:26 PM
phrza81
Oct 10, 2015 11:37 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
