Scuffed the plastic around my wheel well :(
Old Mar 27, 2008 | 10:38 AM
jburkman's Avatar
jburkman
Mannnnn, Rocinante is too young for this! I scuffed the plastic molding over my left rear wheel well backing into the garage. Scuffed like..just enough to smooth the tiny pebbling on the plastic. It is horribly visible though. Anyone actually fix this mar before?
Old Mar 27, 2008 | 10:52 AM
kenchan's Avatar
kenchan
i forget the part number, but those are reasy to replace...
or OG's BlackWow should blacken it.
lol... i just realized i put real and easy into one word.
Old Mar 27, 2008 | 01:06 PM
STLMINI's Avatar
STLMINI
Reasy and cheap. Or reaseap.
Old Mar 27, 2008 | 01:20 PM
kenchan's Avatar
kenchan
i think we're onto something. lol
Old Mar 27, 2008 | 05:58 PM
jburkman's Avatar
jburkman
Reasy? Awesome Thoughts on how to do it, the cost? That, btw, is an awesome word.
Old Mar 27, 2008 | 06:25 PM
kenchan's Avatar
kenchan
i would check with classic mini who is a vendor here.
Old Mar 28, 2008 | 12:04 PM
greengobln's Avatar
greengobln
it's like $35 plus the plastic clips. it just pulls off and the new one/with new clips just snaps in. there might be 2 screws on your year so check the instructions.
Old Mar 28, 2008 | 01:01 PM
Modnar's Avatar
Modnar
Reasy peasy.
Old Jan 28, 2009 | 04:20 PM
Blainestang's Avatar
Blainestang
OK... bringing this back from the dead for a similar question.
Some turd left a jagged piece of plywood on the highway today, so I've got a scuff on the dark plastic section of the front bumper. Pretty much just surface scuffs. Will something like BlackWow or Back-to-black do the trick? If I do just one section or piece will it look weird? For instance, more shiny than the areas I didn't do?
Old Jan 28, 2009 | 04:30 PM
MoxieMini's Avatar
MoxieMini
This is a good opportunity (okay an excuse) to paint them! If you're into that kind of thing.
Old Jan 28, 2009 | 04:36 PM
MLPearson79's Avatar
MLPearson79
If you're going to BW it, I'd do it all, or it will look goofy (plus, BW makes the trim look so good...so why not!).
However if it's actually a scuff that's scratched/marred the plastic, you might just want to replace the piece. They're pretty cheap.
Old Jan 28, 2009 | 04:45 PM
Blainestang
Hmm... well, maybe I'll use a tiny bit of the back-to-black I have sitting around and see how it works. Otherwise, I'll probably just buy a new one sometime. It's not THAT bad, it's just really annoying because it's so new. :(
Old Jan 29, 2009 | 10:48 AM
myminirox's Avatar
myminirox
I had a scuff on the right front plastic trim from a parking lot incident (I was backing out of a spot and turning to my left, lady in and SUV roared into the spot to my right and scuffed me with her wheel!!). It was pretty shiny and I was annoyed!
Black Wow did the trick, but it took a couple of applications. I started by giving the damaged area a "good drink" of BW, and then did the rest of the trim as directed. I repeated this procedure a couple of times and now cannot see the scuff at all!
Old Jan 29, 2009 | 10:50 AM
Blainestang
Thanks... I'll try a few coats of the stuff I have here. Otherwise, I'll either pick up a bottle of BW or just plan to get a new peice.
Old Jan 29, 2009 | 11:18 AM
kkcshipp's Avatar
kkcshipp
Was it so bad that you are thinking of replacing it because of a scuff? In my Jeep I call those battle scars, in the Mini I call them Character Stripes.
Old Jan 29, 2009 | 11:28 AM
Blainestang
Our MINI has enough character already... and I don't want any scars on it, either... It's just a baby!
Only 1 month since delivery!
Old Jan 29, 2009 | 01:11 PM
OctaneGuy's Avatar
OctaneGuy
Good to hear!!!
Richard
Old Mar 15, 2009 | 06:48 AM
ClubmanS's Avatar
ClubmanS
Anyone know how to remove and replace the front arch plastic trim in a R56 or R55? DIY job? Difficult?
Old Mar 15, 2009 | 01:06 PM
MLPearson79
I don't know, but you'll probably get more responses if you ask in the 2nd gen area...someone there should know for sure!
Old Mar 15, 2009 | 03:59 PM
IzzyG's Avatar
IzzyG
Pretty simple DIY ClubmanS. Start from the rear side of the arch. Even though there's a tab that's under the side skirt, you can easily pull it off. It's all clipped in, except for one tab that uses one of those pried in screw dividers thingamick-this is the front most part of the arch and it's attached to the bottom valence of the front bumper. You can remove this easily through the wheel well in front of your tires(just turn the tires to one side).
All in all, can be done in 2 minutes by someone who knows where to look and maybe 15 by a first timer.
Old Mar 15, 2009 | 04:10 PM
IzzyG's Avatar
IzzyG
Oh and someone made mention that the bottom valence of the front bumper is pretty cheap. Anyone have a price handy? I believe I have a little crack when I reinstalled it after having them painted.
And for those attempting to get that piece removed, beware... it's definitely a PITA!
Old Mar 15, 2009 | 04:41 PM
lhoboy's Avatar
lhoboy
The part costs $29.00. Here's how you look for and order OEM parts real cheap:
1. Look up the part at: http://www.realoem.com/bmw/select.do Full parts explosions.
2. Enter the part number at: http://www.pelicanparts.com/euro/cgi...r&Input_Make=Y
Old Mar 15, 2009 | 06:00 PM
IzzyG's Avatar
IzzyG
Where are you getting $29? My search is pulling up $72. I'm talking about the black trim on the bottom side of front bumper, not the arches.
Part number: 51112756495
Old Mar 15, 2009 | 07:45 PM
lhoboy's Avatar
lhoboy
Sorry, I was responding to jburkman.
Old Mar 16, 2009 | 06:05 AM
ClubmanS's Avatar
ClubmanS
Thank you IzzyG, I really appreciate your quick response
By the way, your Clubman looks fantastic.
