Wax Tips....
Old Feb 28, 2008 | 06:31 PM
  #26
BlimeyCabrio's Avatar
BlimeyCabrio
Fantastic pics, Richard. And a fantastic job, as always (or maybe you only post the pictures of the ones you don't hopelessly screw up... jk, jk )
Old Feb 28, 2008 | 07:17 PM
  #27
matty125's Avatar
matty125
Originally Posted by OctaneGuy
First off, I would like to mention an important factor. Astro Black is a metallic and metallic paints tend to conceal flaws better than flat paints like Jet Black.
Given these constraints and everything that Heather mentioned, you really have two courses of action and it depends on your budget, and time available.
Are you working by hand? If so, then products with concealers/fillers is what you want and need--like Amigo and Hydro.
Have a PC or willing to buy one? The potential of achieving what you desire goes up a notch because you can get that flawless finish that reflects light beautifully and permits the paint and metallic flakes to react as they should when not obscured by a layer of scratched clear coat which causes reflections to be hazy and cloudy instead of crisp, clear, and deep.
Proper Prep (Wash, claybar, polishing) is going to get the results you want--no wax, regardless of cost, will give you these things without doing proper prep first.
Learning to maintain it once you've done that is another.
Just some things to keep in mind.
Richard
So if I use a electric buffer/ polisher, I would not need a concealer, filler?
Old Feb 28, 2008 | 08:09 PM
  #28
jimzbobs's Avatar
jimzbobs
prima looks good as far as zaino goes i like how it looks but the wet look is a good look for the mini i am going to order some as soon as i am done reading more threads on other stuff..
Old Feb 28, 2008 | 08:40 PM
  #29
RJKimbell's Avatar
RJKimbell
After Hubby oversprayed an area of our house WAY TO CLOSE to my Black '01 Durango I called in a detailing co. I was very happy with the results, but at $275 I could do with out the cost. Molly will be garaged, NO Brushless Carwashes and will either be hand washed and waxed or NOTHING at all. I'm using Meguire products as well as another brands Wax/Dry product. I'm thinking about NXT I've heard it is really good. I also have a co-worder who swears by Griots. Those results with Epic are amazing. Was an orbital used? Why not use White or Blue Terry Towels washed before each use??
Old Feb 28, 2008 | 08:56 PM
  #30
OctaneGuy's Avatar
OctaneGuy
Thanks! Hahah. Fortunately the only cars that I have screwed up--I can still count on one hand! But they weren't hopeless, lol. But yeah, why bore you guys with regular old cars? I mean next week I'll be doing a black Z4, it not quite the same as the DB9, lol.
Depends on your maintenance routine. I use a buffer for my Jet Black but because it's soft, and swirls easily, if I used it all the time I saw swirls, I wouldn't have much paint, so I balance my buffer use with Hydro and Amigo which act as concealers--and lengthen the time between polishes.
So using a polisher doesn't necessarily mean you don't need to use products with fillers, however if you are polishing paint, that's correct that you don't need to use concealers to hide defects.
Everyone should adopt a system of products. By that, if you're using Meguiar's products, it would do you well to use products they have designed to work well together. You don't always have to do that, but unless you're very familiar with what and how each product works, your best bet is to stick within a system.
Meguiar's makes thousands of products. Why one persons swears over another product is a personal choice. I teach people techniques. People value different qualities. I like ease of use and looks that don't diminish the hard work I put into restoring the paint.
Others want durability or one step applications. Once you understand the importance of prepping the paint using a thorough wash and claybar, then you'll know when and how much to polish, and you'll also know the importance of protecting all that using a wax.
Just my 2cents.
Richard
Old Feb 28, 2008 | 09:01 PM
  #31
MiniMaybee's Avatar
MiniMaybee
Well OG, your $0.02 is worth like $200.00!
Old Feb 29, 2008 | 12:13 AM
  #32
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
Originally Posted by Detailers Paradise
BTW, at first when I saw the "leg" photo I wondered what in the world you were doing taking a picture of someone's leg! Then I realized that it was really the reflection you were photographing and not the leg itself! I guess that illustrates the point quite well.
Nice pics all!
-Heather
Me too! amazing work!!!!
Old Mar 2, 2008 | 08:49 AM
  #33
whiteyanderson's Avatar
whiteyanderson
Originally Posted by DChap
has anyone ever tried using multiple waxes...
for instance, give it a coat of Prima Epic, buff it off, then give it a coat of Carnuba?
what would that do? any thoughts.
I know it wouldn't hurt, but would it help?
i do. well, i use the klasse twins. first the aio then the glaze. then i top with s100 carnauba. looks fantastic. if anyone doesn't know (sure most do) s100 is the same wax as the p21s (from all accounts i've read) except it is marketed for motorcycles. costs a lot less than the p21s though. i picked up a tub for $12 vs $30 or $40 for p21s.
the way i do it is a 4 weekend process with the klasse all by hand:
1st weekend: wash and clay, then i use som zaino pc for swirls and buff off. then i apply the klasse aio and buff off. then apply klasse sg and buff off. wipe on/wipe off method with the sg but i do a panel at a time.
2nd and 3rd weekend: wash, dry, klasse sg. for a grand total of 3 klasse sg coats.
4th weekend: wash, dry, s100 as a carnauba topper.
1st weekend is the only one that takes a long time. but, the results so far are crazy. the klasse gives a great shine on my indi blue. the s100 gives much more depth.
maintenance between klasse appplications is a coat of s100 every 4-6 weeks for about 5-6 months.
Old Mar 3, 2008 | 10:40 AM
  #34
Prima Car Care's Avatar
Prima Car Care
I like your process. I also enjoy the warmth of a carnauba and like to top with it!
Just as a clarification for those who like the wee details...
P21S Carnauba Wax and S100 Carnauba Wax are made by the same company and are VERY similar although are slightly different.
Yes, they are marketed to different crowds: the P21S to the car enthusiast and the S100 to the motorcycle enthusiast. As such, the composition is slightly different in each to address somewhat different needs/concerns of each crowd.
The P21S has slightly more carnauba in it (no carnauba waxes are actually 100% carnauba... they all contain oils and other chemicals as well) and almost nil cleaner. The S100 has more significant cleaner in it and slightly less carnauba. So, the S100 has the tiniest bit less depth but very slightly more durability.
At the end of the day though, they are so similar enough that it really doesn't matter much which one you use. They both provide a gorgeous depth that I think rivals many much more expensive carnauba waxes.
The S100 is usually less expensive than the P21S. We've been trying to carry both but they are a little wierd about allowing retailers to carry both lines... perhaps for this carnauba difference issue!
Anyway, the differences are so small that probably most of you don't care to even know. Yet I'm sure there are some of you who love these little details so there you go.
-Heather
Old Mar 3, 2008 | 10:49 AM
  #35
BlimeyCabrio
I'm glad I don't know as much about detailing as Heather.
Old Mar 3, 2008 | 10:52 AM
  #36
Prima Car Care
Indeed, it is a blessing and a curse!
-Heather
  #37
Modnar's Avatar
Modnar
She knows it like it's her job.
Old Mar 3, 2008 | 02:35 PM
  #38
whiteyanderson
thanks for the clarification on the s100 heather. i'm a loyal "klasse-ist" but, try to support vendors and/or members of this forum when i can. i picked up some of your white waffle weaves from octaneguy (and some black wow too!) so i supported both he and detailers paradise in one shot. i have to say they are the greatest towels i have EVER used! well, worth the price as it seems they will last a very long time. black wow is awesome too!
Old Mar 3, 2008 | 03:29 PM
  #39
MiniMaybee's Avatar
MiniMaybee
Is a "Klasse-ist" like a fascist?
Well they rhymed.
Actually whitey, DP sells Klasse too so you can get your fascism ... I mean Klassism fix there too.
Old Mar 3, 2008 | 09:53 PM
  #40
whiteyanderson
wow, never knew they carried klasse. cool.
no, no fascism here. i just like the klasse ...
Old Mar 4, 2008 | 03:23 PM
  #41
Prima Car Care
Thanks for the OG and DP support in one shot! And thanks in general for supporting NAM vendors.
Thanks also for your compliments for the Waffle Weave towels (and Black Wow too of course!). If you can believe it, I was once a skeptic of all this premium product mumbo-jumbo many years ago myself... the Waffle Weave we distribute was my first exposure to "the light." I realized then that there IS a difference between low-mid quality car care stuff and the premium stuff! And the rest is just history...
And yes, we carry Klasse products although we're having a hard time getting more All-In-One (AIO) right now. We do carry the Sealant Glaze (SG) though.
I'm an AIO fan but honestly don't care for the SG anymore. There are other synthetics that are much easier/quicker to use and that last just as long (and have a much better look on dark colors, IMO). Like I said, I do like the AIO quite alot though. It has a great cleanser in it, as well as significant filling/concealing properties. Together, they are a very powerful combo... just not the look I prefer nor do I care for the SG process relative to others for the same power.
-Heather
Old Mar 5, 2008 | 02:29 PM
  #42
Wolfgang80's Avatar
Wolfgang80
waxing tips
I read with much interest the ways to avoid swirls and appreciated your step by step approach; however, when you got to the waxing part, I didn't see any preferred techniques. Assuming I have Epic and applicators and a mf buffing towel, is there a right and wrong way to apply the wax and buff it off?
When applying, are long straight lines the best method or is a short back and forth scrubbing motion better? I assume circles are to be avoided.
When buffing, what is the best technique with the towel? Light fast back and forth movements?
Thanks.
Old Mar 5, 2008 | 02:37 PM
  #43
kenchan's Avatar
kenchan
waxing applicator pad?
Hydro + waffle weave towel is all you need.
Old Mar 5, 2008 | 02:44 PM
  #44
MiniMaybee's Avatar
MiniMaybee
Thanks.
I put Epic on using a combination of PC (black pad) and by hand using a thin blue pad. For removal nothing works better IMO then the DP Monster Fluffy. Removing Swirl is a little tougher so I use a DP gray microfiber.
As for applications - if you are using something that will impart swirls, you're using the wrong thing. If the right applicator is used it doesn't matter which direction you put it on.
Old Mar 5, 2008 | 07:11 PM
  #45
OctaneGuy's Avatar
OctaneGuy
Agreed, thanks for the support!!
I agree, but I've pretty much fallen in love with the Starfish MF Mitts for final wiping. I still use Monster Fluffies but the Starfish are equally as fantastic!
The DP gray MF aka Dual Pile or Platinum Microfiber is a very useful towel. One of the sides will be easier to wipe off the polish--so it's nice to have that option!
+1 on application method. Direction shouldn't matter. As long as you're putting it on evenly and overlapping and not too think, which direction you apply it won't have any impact.
Old Apr 6, 2008 | 10:53 AM
  #46
Goldilocks's Avatar
Goldilocks
Anyone know of a complete reputable MINI detailer in Northridge, CA? My MINI is 6 weeks old & I just had hand surgery but really want my baby to SHINE! She's BRG, JCW aero kit with the redwood lounge leather interior and the Invisishield.
Old Apr 6, 2008 | 11:27 AM
  #47
OctaneGuy's Avatar
OctaneGuy
Hmmm you want a complete reputable MINI detailer...that's asking a lot. lol. If I were you I would find the best detailer and not the one most convenient to your location. My last customer (yesterday)drove from Camarillo to have his 06 transformed and I've had MINI owners come from Morgan Hill and Las Vegas and other not so local places.
Richard
Old Apr 6, 2008 | 11:48 AM
  #48
MLPearson79's Avatar
MLPearson79
And totally worth the drive, I might add!
Old Apr 6, 2008 | 12:00 PM
  #49
Doesnotcompute's Avatar
Doesnotcompute
My last customer (yesterday)drove from Camarillo to have his 06 transformed.
82 miles each way and worth every mile and penny
<strike>I will sort through the photos later today and post accordingly.</strike> Here are the photos
Old Apr 7, 2008 | 10:10 AM
  #50
OctaneGuy's Avatar
OctaneGuy
Thanks for the support Melissa and Nick!!!
Btw, here are pics from an '06 BRG/Silver JCW
to this
See more pix and full writeup here
http://www.showcardetailing.com/foru...ead.php?t=1123
OutMotoring
Mar 3, 2017 06:29 AM
MiniChick82
Detailing 101
Nov 18, 2015 12:03 PM
kevinminict
Sep 8, 2015 04:13 AM
broncobuddha
Sep 1, 2015 06:32 PM
