wax buildup on clear bra edge
Old Jan 3, 2008 | 10:49 AM
going4speed's Avatar
going4speed
So I took pictures and noticed that the dealer, yes the dealer not me, must have waxed the car with some crap wax and got it along a few edges on the front of the car. I use blue painters tape on all seams and edges before waxing.
Any tips for removing wax buildup along edges of clear bras?
Old Jan 3, 2008 | 02:24 PM
kenchan's Avatar
kenchan
q-tips.
if that doesn't work, put a dab of the same wax on a MF towel and
run it down the caked wax until it dissolves. then remove it using q-tips.
Old Jan 3, 2008 | 02:39 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Or one of these...
Zymol horsehair detailing brush...
Or what I usually do - run along the edge with my fingernail inside a thin microfiber towel - usually works just fine...
Old Jan 3, 2008 | 03:26 PM
kenchan's Avatar
kenchan
Originally Posted by BlimeyCabrio
Or one of these...
is horse hair softer than boar's hair? if not or if the same, i dont
recommend it on paint cause it swirls it. i did my own experiment
under 500w halogen and i could see hazing.
the microfiber edge with fingernail trick works great just as long as
it's lubed with QD and dont go too fast. it generates heat and hazes the finish.
Old Jan 3, 2008 | 03:45 PM
going4speed
Just got my griots order with the micro fiber towel package
Forgot to order more speed shine
I need to try the towel first as I used q tips last car and ended up somehow pushing the wax under the edge of the clear bra...I can be a bit of a beast
Old Jan 3, 2008 | 04:04 PM
BlimeyCabrio
Like OctaneGuy said on an earlier thread - I'm not "brushing" the paint with the brush - I'm holding it at an angle and just brushing along the millimeter or so along the edge of the clearbra - if you can see swirls 1mm wide, you're better than me. Which we know is true, regardless.
Old Jan 3, 2008 | 06:20 PM
MLPearson79's Avatar
MLPearson79
I've used q-tips (soaked in alcohol if it's really stubborn), MF wrapped around my fingernail, and the toothbrush trick above. They all work.
If you're paranoid about the toothbrush, wrap it in a MF.
Old Jan 3, 2008 | 06:26 PM
kenchan's Avatar
kenchan
If you can see swirls 1mm wide, you're better than me. Which we know is true, regardless.
you mean 0.01mm, right? 1mm is HUGE and should pop right up when
you have any kind of light up against it.
Old Jan 3, 2008 | 06:28 PM
kenchan's Avatar
kenchan
i tried the q-tips and alcohol trick but the problem is, it removes wax
at the width of the q-tip. q-tip with QD is better, but q-tip with the
same wax works best..and cuts down the extra step of re-waxing.
Old Jan 3, 2008 | 06:29 PM
kenchan's Avatar
kenchan
dohh! SpeedShine is one of the requirements for the Griot's package. (not to be harsh).
Old Jan 3, 2008 | 06:44 PM
BlimeyCabrio
I mean the brush only touches a strip of paint about 1mm wide, running along the edge of the clearbra... so the swirls might be as long as the clearbra edge, but they'll be confined to a space 1mm wide - which even your OCD eyes are NOT gonna see...
Old Jan 3, 2008 | 06:49 PM
kenchan's Avatar
kenchan
huh, is that because im not suppose to look at it that close?
im pretty good a pretending not to see things.
Old Jan 3, 2008 | 07:06 PM
BlimeyCabrio
Sorry - for a minute there I forgot and treated you like a mere mortal... forgive me, great one.
Old Jan 3, 2008 | 07:07 PM
kenchan's Avatar
kenchan
who are you talking to?
navybsn
Oct 5, 2018 04:42 PM
OutMotoring
Mar 3, 2017 06:29 AM
Debi's Coop S
Nov 8, 2015 06:34 PM
penguinplf
Oct 11, 2015 07:36 PM
navybsn
Oct 4, 2015 03:27 PM
