I need you to call TireRack & order a set of rims
All:
Tirerack.com won't have rims available until they have had a Countryman in their shop to measure its rims. Probably in the spring. However, if enough people call & request rims, they'll get with the program, find some rims & start selling them.
The 17's are 17x7 with a 50mm offset. Hub is 5x120.
If you will need rims for your Countryman, please call the Tirerack at 1-888-541-1777. The more calls they get, the sooner the rims will be available!
Call them now!
Thanks,
Paul.
Call them now!
Thanks,
Paul.
If you know what the Countryman takes 5x120 high off set just look up a BMW 1 or 3 Series and order rims based on that information and you will be fine... Just use the correct tire size for a Countryman in the respective tire size..
Other choice take your Countryman to Tire Rack !!
Correct, but I am reliably informed that BMW rims will NOT fit a Countryman.
I really wish they would- that way I'd have a set already!
Sounds like a BMW rim will fit. Les Schwab (big tire dealership in OR.) has aftermarket BMW rims in stock, so I will test fit one.
I'll let you know.
P.S. I think the axle hub size is the 5x120. There is something else (not the offset) that is 72mm.
I'll let you know.
The hub is the round part in the middle and it could but the 72mm in diameter, seems a hair big though (almost 3 inches). The 5x120 is a bolt pattern size.
Wheel fitment
Here is some information that I found.
A 1-series(and probably many other BMW's) are
Bolt Pattern 5x120 / Hub Center 72.5 (s11)
If the Countryman has the 72.5 Hub Center, then I would say we are good to go. If they are any larger,the above post says not, then they will not fit without custom spacers or boring out the wheel.
If the Countryman is smaller, then they will also fit no problems, but if you don't get hub centric rings to fill in the open space from having a smaller Hub, you will risk having alot of issues because you will be relying solely on the lugs to center the wheel.
Drivetrain RaceChip Ultimate install + review for b46
F55MidnightBlackCooperS
Jul 6, 2016 03:13 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
minipopkart
Aug 13, 2015 05:22 AM
