Cooper (non S) Modifications specific to the MINI Cooper (R50).
fitted my HKS filter today...
Old Oct 13, 2006 | 03:28 AM
mini_macky's Avatar
mini_macky
from the pic, you can see that the filter is almost connected to the throttle body itself the reason for that is so the air-feed tube will be closer to the filter
here you can see how near the air-feed is to the filter
whatya guys think?
took it out for a test and the engine definitely feels it can breathe better...in fact, A LOT better compared to my cheapo filter before the upgrade
Old Oct 13, 2006 | 03:54 AM
dickdavid's Avatar
dickdavid
Very cool. It looks like bee hive.
Old Oct 13, 2006 | 06:00 AM
Ords's Avatar
Ords
Very Nice....is the filter washable or is it throw away and replace?
Old Oct 13, 2006 | 06:28 AM
mini_macky's Avatar
mini_macky
Old Oct 13, 2006 | 07:45 AM
Ranzo's Avatar
Ranzo
Looks tight!
Old Oct 13, 2006 | 07:59 AM
ca$per's Avatar
ca$per
looks good, but wouldn't it be getting the hot air produced by the engine rather than the cold air from the outside?
Old Oct 13, 2006 | 08:04 AM
Bullfrog's Avatar
Bullfrog
Where did you get that filter? I haven't seen one like that before.
Old Oct 13, 2006 | 08:09 AM
goaljnky's Avatar
goaljnky
I have seen that one before. But keep an eye on it. The thread I recall, the person had a problem with the filter foam falling apart.
Old Oct 13, 2006 | 12:52 PM
illeagalhunter's Avatar
illeagalhunter
not for me looks like a gooseberry under the bonnet
Old Oct 13, 2006 | 12:53 PM
justintime's Avatar
justintime
that looks like its almost right over the throttle body ^__^ did you just fit it over? I wonder if it would fit the K&N tube
Old Oct 17, 2006 | 08:19 PM
mini_macky's Avatar
mini_macky
since it's positioned near the air feed, i hope this won't be an issue
Bullfrog: it's an HKS super power flow filter, usually found in Japanese cars
goaljnky: the foam falling apart? hmm. thanks for the heads up, will keep an eye on it
justintime: it's ALMOST fitted just over the throttle body
Old Oct 17, 2006 | 09:17 PM
Tüls's Avatar
Tüls
Turbius Maximus
NICE!! that's all we use... WOOT! well at least when we are using one...
Old Oct 17, 2006 | 09:57 PM
justintime's Avatar
justintime
hmm do you think it would fit/have clearance with the K&N? that looks alot cooler/smaller
Old Oct 20, 2006 | 01:00 AM
mini_macky's Avatar
mini_macky
which looks a lot cooler/smaller?
Old Oct 20, 2006 | 10:12 PM
justintime's Avatar
justintime
the HKS
Old Oct 21, 2006 | 07:11 AM
kurvhugr's Avatar
kurvhugr
Since it's open to air under the hood from all directions, it will always get all of its air from under the hood, but how much of it is hot air depends on whether (and how fast) the car is moving. When standing still, there's no pressure to push air through the snorkle so the majority of the air will likely come from elsewhere in the engine bay. When moving, the air forced in through the snorkle will increase with speed and this will lower the temp of the air surrounding and available to the filter.
Chasp
Aug 22, 2015 01:26 PM
Aug 21, 2015 08:44 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
