Cooper (non S) Modifications specific to the MINI Cooper (R50).
Another Intake Question
Old Mar 3, 2006 | 09:53 PM
drg1138's Avatar
drg1138
Has anyone had any experience or opinion on the AFE Cold Air Intake?
http://www.autopartswarehouse.com/pe...2005&partid=15
Dean
Old Mar 3, 2006 | 10:59 PM
goldcountrymini's Avatar
goldcountrymini
Dean, I have not heard of this intake. Just get the ALTA intake and do yourself a favor.
I have the K&N intake and I am going to switch to the ALTA soon!
Old Mar 3, 2006 | 11:29 PM
blitz64's Avatar
blitz64
never heard of it. I also agree that it's not worth saving few dollars on a CAI. I recommend ALTA and it seems like the most popular CAI. I would pick it again if I got another mini.
Old Mar 4, 2006 | 04:52 AM
NMgokart's Avatar
NMgokart
As Alta doesn't make a CAI for the MC (yet), the AFE is one of very few choices available (another is offered by Mymini http://www.myminiparts.com/proddetai...d=CCAK4&cat=13)
Looks like the difference between these 2 is the filtering medium; AFE uses pleated and Mymini uses foam. There are debates (search) on the merits of both types.
Sorry, don't have either, but thought I would throw out another option.
Old Mar 4, 2006 | 05:07 AM
kurvhugr's Avatar
kurvhugr
Alta doesn't make an intake for the non-S.
I have one of these (AFE) and it's not bad. The ad says it "includes air box" but it's not really a box. The black metal part you can see in the pic provides a barrier of sort but isn't a 100% seal against under hood air. You remove the stock airbox and the barrier blocks the direct hot airflow from the radiator area, etc, and channels air from the stock intake snorkle to the filter. The "box" is less sealed on the side facing away from the engine and air can enter that way, but who knows how much or how hot it is.
It's not the only one that works this way though. If you check out the ProMINI intake you'll see a different approach that's also partially open. Each has pluses and minuses relative to the other, and you won't find good, independant numbers, so it seems like a matter of preference. Also check out the latest MyMINI version.
It uses the same heat shield but replaces the AEF filter with an ITG foam filter....is it better? Who knows?
Old Mar 4, 2006 | 06:36 AM
drg1138's Avatar
drg1138
I found this last night.
http://www.knfilters.com/search/prod...Prod=57-0331-1
It is a bit more expensive but it is a K&N.
Any recommendations?
Old Mar 4, 2006 | 11:34 AM
NMgokart's Avatar
NMgokart
Yeah, it's a K&N, but if you'll notice, it is more expensive than the AFE and doesn't include any sort of heat barrier.
If you just gotta have K&N, that's your only choice. There are better choices.
Old Mar 4, 2006 | 05:24 PM
scobib's Avatar
scobib
I'm running the aFe - IMHO, the fit is MUCH better than the BMP/Promini intake that I had before... I'm extremely pleased with it so far. It's a bit quieter than than Promini intake, but at WOT above 4K RPM's it sounds rathere glorious, IMHO.
It DOES seal off the filter from the engine compartment fairly well - comes with a rubber seal that goes all the way around the top and down the front bulkhead. After a bit of adjusting, I dusted the top of the seal with baby powder and shut the bonnet - upon re-opening it, there was a perfect imprint of the seal on the bonnet.
The OEM air intake pipe that feeds cold air still supplies the cool/cold air to this setup.
The other side is sealed in by the headlight housing...
I give it
Old Mar 4, 2006 | 05:28 PM
goaljnky's Avatar
goaljnky
I am sure you meant other choices. "Better choices" is highly debatable and extremely hard to prove.
Old Mar 4, 2006 | 05:36 PM
Dr Obnxs's Avatar
Dr Obnxs
But the K&N is CARB approved....
or you can get an HAI (K&N filter direct on the throttle body)..... But no CARB sticker...
Matt
And there are rumors that the K&N set up is actually a tuned system, meaning that the length was chosen to add some flow at peak HP....
Old Mar 4, 2006 | 09:23 PM
drg1138's Avatar
drg1138
Thanks for the input.
Still not sure where I am going to go with this. I still have a few more weeks until I make a purchase so I will keep on researching.
W0TM8
Dec 19, 2019 07:50 AM
The_Kid
Aug 28, 2015 04:50 AM
maniacalmorgan
Aug 19, 2015 08:44 AM
massmini03
Aug 12, 2015 11:19 AM
jrezzo
Aug 9, 2015 10:32 PM
