Cooper (non S) Modifications specific to the MINI Cooper (R56).
Rear sway bar size
Old Oct 24, 2014 | 03:51 PM
TopLegion's Avatar
TopLegion
Rear sway bar size
I have a 2010 R56 and I think I went too big on my rear sway bar. I autocross the car and when I go hard into a corner the car tri-pods. It is a hotchkins competition bar. If I stiffen up the front end with a smaller sway bar will will that make more problems or would that help keep all wheels planted.
Old Oct 24, 2014 | 04:25 PM
mbwicz's Avatar
mbwicz
The tri-pod happens as a combination of stiff chassis and suspension setup. You need to balance what feels right and what is faster. Just because your car lifts the inside wheel does not meet there is anything wrong.
Do you like the feel of the car with the new rear bar, or is it too much rotation and oversteer for you? Have you adjusted the bar with the different end link holes?
Smaller front bar is going the wrong way. If anything, you would want to stiffen the front bar to match the rear.
Have fun,
Mike
Old Oct 24, 2014 | 09:41 PM
kyoo's Avatar
kyoo
sounds like it's doing what it's supposed tos
Old Oct 25, 2014 | 04:48 AM
danjreed's Avatar
danjreed
So adjust it down a notch or two.
Old Oct 25, 2014 | 08:17 AM
Fly'n Brick's Avatar
Fly'n Brick
No such thing as a too big RSB.
Old Mar 25, 2015 | 02:38 PM
Kimbo80's Avatar
Kimbo80
I know I am resurrecting an old thread, but does anyone know the stock sway bar size with non-sport suspension?
I bought a sway bar and stock bushings from a member with a Cooper S for dirt cheap, and when I measured it was 18mm. I am wondering if it would make a noticeable improvement and would be worth the project.
Old Mar 25, 2015 | 05:36 PM
Fly'n Brick
According to 'RealOEM.com', the stock RSB is 17MM for the '09 Clubman and Clubman S.
Old Mar 25, 2015 | 05:39 PM
Eddie07S's Avatar
Eddie07S
If you go to Penske part for MINIs you can find a lot of this information. This is what I have collected for MINI RSBs:
Justa 16mm
S 17mm
Sports 18mm
JCW 18.5mm
Don't forget that the sizes noted above are without the coating so what you probably have is the 17mm bar if you measured over the coating. That bar is about 27% stiffer than the Justa bar and should be noticeable but not dramatic.
Old Mar 25, 2015 | 05:46 PM
Eddie07S's Avatar
Eddie07S
You may need to measure the bar that is on your Clubman to know for sure. Penske lists both a 16mm and 17mm for the base model and 17mm for the S.
Old Mar 25, 2015 | 06:07 PM
Kimbo80's Avatar
Kimbo80
Thanks guys! I will have to measure the thickness of my sway bar on my car.
Old Mar 25, 2015 | 06:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With a Clubman you most likely have a 17mm bar stock. I wouldn't bother going through the work to upgrade just to an 18mm. Save your money and when your ready got to the Hsport Comp bar or at least a 19mm. We've installed just 18mm bars before and it just leaves you disappointed mid corner as the car starts to rotate then nothing happens.
Old Mar 25, 2015 | 06:48 PM
danjreed's Avatar
danjreed
I can verify that my factory "sport" sway bar was 18mm.
I upgraded to the Hcomp bar that Way sells. Im very pleased with it (still am a year later)..
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
