Cooper (non S) Modifications specific to the MINI Cooper (R56).
[HELP] Forged Pistons in alternative to OEM Mahle
Old Mar 1, 2014 | 07:01 PM
Fabiop's Avatar
Fabiop
Hello,
I own a Countryman (R60) and I know I'm not exactly on the correct place in the forum, but since the R60 share the same pistons than the R55/R56/R57 NON S (realoem reference here)and there are more owners of R55, R56 and R57 than R60 thought you guys could help me. I really need a help here.
I've open a post there in the Countryman forum: https://www.northamericanmotoring.co...errerid=108550
However I replicate my problem here:
I have a 2011 Countryman Justa Cooper ( NON S ). I regret not having bought the turbo one... but now I have a NON S...
He suffered some minor modifications (intake , ECU remap , sport button , etc. ... ) that led him to 168hp .
Last week I lost 3 of my engine pistons in an error during an adjustment on the engine from my mechanic . When he took apart my engine it found that the pistons (MAHLE - Mini part number 11257589348) are terrible . I venture to say that the pistons are lowest quality I've ever seen in my life.
In a conversation with him I decided to get forged alternatiavas market . The problem is that I only find forged pistons for the S model, which are slightly different from mine.
The compression ratio of my engine is 11.0:1 while the Cooper S is 10.5:1, as I know. The difference is small and does not worry me , but it seems the pin Cooper is 18mm while the Cooper S has 20mm, besides other slightly differences. That's correct?
Do you know if it is possible to adapt these pistons in the NON S (N16) engine? Has anyone ever seen forged pistons for the NON S?
Do not bother with small adjustments, even rework the piston, because my mechanic is very experienced - with years preparing race engines - and able to do it.
Finally, I explain that I do not run (track or street) with the car . I am a father. But as I drive every day on the highway and I seek a more reliable car to make evasive maneuvers in traffic. The 122hp from the NON S was kiling me.
I would love a help because my car is disassembled awaiting parts and now I'm Miniless.
Thank you ,
Old Mar 1, 2014 | 10:11 PM
ZippyNH's Avatar
ZippyNH
The lower compression pistions will get you less hp....
Generally, folks looking for long life should go with stock pistons...
The alloy differences used in forged alloy pistons result in different expansion rates...can result in piston slap...and sometimes premature failure.
Old Mar 2, 2014 | 04:17 AM
Fabiop's Avatar
Fabiop
Thank you ZippyHN!
I know that lower compression will give lower hp, but I can handle it. But I didn't know about premature failure.
But I'm looking for the non s forged piston. Exactly like the own. Do you have any idea if it exists?
Regards,
Old Mar 2, 2014 | 05:41 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
ECU Remap on an N16 ? Good luck with that.
Mechanic messes with something he has no experience with, gets in over his head, blows up engine and blames the engine design...lol.
Old Mar 2, 2014 | 06:18 AM
Fabiop's Avatar
Fabiop
I already have my ecu remapped for almost 2 year and no problem at all. Actually a have better mpg than before.
He messed up the engine on a test, nothing to do with the ecu remaping. And he is paying for all the parts that messed up.
Old Mar 2, 2014 | 09:51 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
No one i know makes them. But get me a piston and i can have a local shop make what you need. We have a local Piston Maker that could duplicate it for you in a better materiel with OEM compression. Not sure how long it would take tho...
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Mar 2, 2014 | 10:01 AM
Fabiop's Avatar
Fabiop
Detroit Tuned,
Can you check the lead time to this?
Regards,
Old Mar 2, 2014 | 10:14 AM
Detroit Tuned
Vendor - 15 Years
i would make a guess 3-4 weeks
Old Mar 2, 2014 | 10:30 AM
Fabiop's Avatar
Fabiop
Maybe it's a good idea. It's your shop? If it is, send me a pm...
The problem about 3-4 weeks of course is that my car will be stopped for that long.
If anyone knows a stock solution, please help me. I don't want to go with the non reliable oem ones.
regards,
Old Mar 3, 2014 | 05:08 AM
v10climber's Avatar
v10climber
They're perfectly reliable in OEM form if your mechanic doesn't go breaking stuff.
I would just source some OEM replacements and call it a day. You said it yourself you're not looking for more power so why fix something that isn't broke? Just find a different mechanic next time.
Old Mar 3, 2014 | 05:23 AM
Fabiop's Avatar
Fabiop
You are right, but the justas has a know problem with a weak piston when you force it too much. Just a small search on the forum I found about 5 or 6 threads about 50k miles and broken pistons.
Since my engine is disassembled right now, and I need to buy new pistons I thought that's the right time to search pot better ones.
But I really couldn't find it. I think I'll order the oem today.
Regards
Old Mar 3, 2014 | 08:47 AM
v10climber's Avatar
v10climber
Now would definitely be the time for piston upgrades but unfortunately there just isn't a lot of aftermarket support for the mini.
Besides... I thought all Brazilians drove 800whp VWs
Old Mar 3, 2014 | 10:41 AM
Fabiop's Avatar
Fabiop
Yes, it would...
By the way, I never drove a VW...
rtk90
Aug 29, 2019 09:08 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
squawSkiBum
Sep 2, 2015 09:56 PM
