Cooper (non S) Modifications specific to the MINI Cooper (R56).
Highest mileage on a R56 Justa?
Old Dec 10, 2022 | 04:28 PM
  #76
gstilphen's Avatar
gstilphen
Oh no, what happened?
Originally Posted by Mini Devil
Dead today....
264k
Update on mine:
Just upgraded to bi-xenon headlights and put in new shift box, springs/struts, pads/rotors, braided steel brake lines, clutch master/slave, brake reservoir, front/rear sway bar bushings, and finally replaced the opaque foglights.
Now sitting at 279,000 miles and it drives like the day I bought it.
Old Dec 10, 2022 | 05:33 PM
  #77
Mini Devil's Avatar
Mini Devil
Originally Posted by gstilphen
Update on mine:
Lower radiator hose was torn. Drained the coolant, and blew a head gasket
Old Dec 10, 2022 | 06:41 PM
  #78
gstilphen's Avatar
gstilphen
That's not irreparable. I burned an intake valve and dropped the valve seat at around 200k. Had a local machine shop deck the head and put in a new valve seat. Went ahead and just put all new studs and replaced fasteners and gaskets on anything I could see while I was in there. Did the piston rings too. New exhaust studs and heat shield, along with repining any brittle connectors or wire loom covers. And a new valve cover. All in, maybe $1800 if memory serves. Still runs sweet as can be nearly 80k miles later.
Old Dec 12, 2022 | 06:20 AM
  #79
MrSurly's Avatar
MrSurly
Originally Posted by vballcoach
MrSurly
have 146K+ on mine
did you do the timing chain/valve seals yourself? if you did, was it hard?
I've done everything you've done sans the timing chain/valve seals.
Also replaced coolant tank/cap.
I also have a slight leak somewhere again as I'm losing coolant...ugh
Timing chain job is not bad at all; be sure to buy the cam lock tool kit.
The Valve Seal job, done in-car, is an absolute BE-otch and I would NOT recommend. I Would recommend removing the head to do the seals (might as well do a valve job) and while you're there, don't miss the opportunity to renew the filter mount gasket, replace the brittle (and critical) PCV hose and water pipe and thermostat housing and clean both VANOs screens.
See these threads:
https://www.northamericanmotoring.co...c-job-diy.html
https://www.northamericanmotoring.co...-surprise.html
https://www.northamericanmotoring.co...ance-must.html
rfbaerjr
Jan 11, 2022 09:59 AM
burley
Mar 20, 2018 06:48 AM
byron h
Jul 1, 2013 01:43 PM
yukoncornelius
Oct 4, 2012 02:10 PM
caprisun
Apr 7, 2012 08:30 AM
