Cooper (non S) Modifications specific to the MINI Cooper (R50).
Engine Support how?
Old Oct 16, 2012 | 10:07 AM
scottwrightF1's Avatar
scottwrightF1
Engine Support how?
Hi,
I was curious how otheres have support their engine when taking out the transmission.
How did you support it?
If you do have a support hoist to go on top of the engine. How did you attach it to the engine? Does it need a speical bracket to attach onto the engine?
Any pictures would help so that I can get an idea how to do the work on it before removing my transmission out.
Thanks.
Old Oct 16, 2012 | 01:29 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Have you seen these yet? http://www.minispares.com/Product.aspx?ty=pb&pid=41846
888.280.7799 | 6am - 5pm PST
Old Oct 16, 2012 | 02:47 PM
scottwrightF1
Originally Posted by PelicanParts.com
Thanks, I have not seen these. So how does it attach to the engine?
Old Oct 17, 2012 | 10:55 AM
PelicanParts.com
Vendor
I'm assuming they come with some sort of .pdf or instructions, try running a search on here for engine hoist brackets.
Old Oct 18, 2012 | 06:35 AM
scottwrightF1
Thanks, I have did some search, but not getting any luck on how to do it on a Mini.
Old Oct 18, 2012 | 09:58 AM
PelicanParts.com
Vendor
Found this: http://www.minifinity.co.uk/forum/vi...c.php?p=858642
Old Oct 19, 2012 | 01:29 PM
PelicanParts.com
Vendor
Did that link help?
Old Oct 19, 2012 | 05:56 PM
scottwrightF1
Did that link help?
Thanks, it did help a bit, but I am not sure what year model Minis they were talking about. It sounds like for an older model car and my is the 2002 R50. So I would have a hard time where exactly to mount the bracket on the engine with the hoist bar.
Old Oct 19, 2012 | 06:03 PM
ColinGreene's Avatar
ColinGreene
I just use a jack stand, or transmission jack with a block of wood in there.
Old Oct 19, 2012 | 06:05 PM
scottwrightF1
Was it difficult and do you have a picture how you did it? Would there be any problem when trying to take out the transmission while the jack being in the way?
Old Oct 19, 2012 | 06:18 PM
ColinGreene
its a pain in the butt if thats what you are asking.
I put the jack under the motor
Ive seen techs just let it hang off of the upper motor mount but i dont agree with that.
I just give the motor some down angle and pull the trans off.
pull it off and pop it out.
I dont usually take pictures when im working.
Old Oct 26, 2012 | 10:44 PM
Brandin Sharp's Avatar
Brandin Sharp
Sort of a mess since I was in a rush to leave that day. Just replaced the clutch in mine. I used a floor jack to lower the engine enough to comfortably pull off the bell housing. Once lowered, put a nice piece of wood with two jack stands and a hydraulic jack for safer measure.
Old Oct 27, 2012 | 07:47 AM
scottwrightF1
Wow, you are right it a mess. haha. Now, I get the idea how I can support the engine from the picture you have sent. Kind of scary.
I notices that you removed the two plastic inner fenders. Does it really need to be removed?
I just brought a Hoist Bar Support to go on top of the engine, but I dont see many people are using it, cause I cannot find how to attach it onto the engine where it located. So I guess, I will try and use the engine jacks.
Thanks.
Old Oct 27, 2012 | 07:52 AM
Brandin Sharp
Yeah, it definitely was scary just having the engine sit on 3 jacks. But if you place them well, you'll have enough support and stability. "These jacks hold up a whole car, they can hold an engine," I thought.
Technically, you don't have to remove the plastic fenders, but it'll be Hell in a hand basket to remove everything else. It only takes a couple of minutes to remove both, just a handful of fasteners.
Sep 17, 2015 09:27 AM
thebordella
Aug 31, 2015 01:37 PM
Zettinger
Aug 25, 2015 04:04 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
