Cooper (non S) Modifications specific to the MINI Cooper (R50).
Tranny Swap
Old Sep 10, 2012 | 10:48 AM
robihlanfeldt's Avatar
robihlanfeldt
Tranny Swap
I own a 2002 Mini Cooper, it has a 1.6L 4 cylinder engine. It is time for a new transmission. I have a 5-speed manual transmission right now, and a 6-speed transmission is a tempting swap. How difficult would this be? And suggestions on whether or not I should..
Old Sep 10, 2012 | 11:35 AM
Miami's Avatar
Miami
if you google "site:northamericanmotoring.com five speed to six speed r50"
you will get your answers
Old Sep 13, 2012 | 09:55 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'm assuming you'd be having a shop do the swap? Or are you pretty handy with the wrench?
888.280.7799 | 6am - 5pm PST
Old Sep 13, 2012 | 10:15 AM
miles_miles7's Avatar
miles_miles7
Do some reading first and if you think you can do it after some research then do it. There is a DIY instruction somewhere here, i have a copy of it i just have to look for it.
Old Oct 5, 2012 | 06:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The 6spd will bolt directly in, but you will need axles, shift cables, mounts, new intake clutch/flywheel, starter. Then you won't have cruise either.
It's cheaper to just get a new 5spd and put it in.
Old Mar 3, 2013 | 08:26 PM
Densmini's Avatar
Densmini
Way, did you ever crack the cruise control problem?
Old Mar 3, 2013 | 08:32 PM
miles_miles7
Densmini
I did a swap from a preface to postface lift tranny and my cruise control is now working. Mynes is the company to consult on this.
Old Mar 25, 2013 | 03:39 PM
robihlanfeldt
Thanks for the help guys, I looked into purchasing a new transmission from a parts dealer in the south, but decided to get a rebuilt transmission from my local dealership. Cost about $1800 for the transmission, also bought a new clutch ($400ish) and then a starter and new struts ($400 a piece) and my baby is back on the road!
Old Mar 26, 2013 | 11:18 AM
Densmini's Avatar
Densmini
Good for you!
Old Apr 10, 2013 | 05:31 AM
lizandrooo's Avatar
lizandrooo
Is it possible to get a 6 speed getrag and still keep the cruise control (onto an 03 R50) ? What would it take to keep the Cruise Control (even if its a swap w/o the 6 speed but a 5 speed instead) ?
Old Apr 10, 2013 | 06:09 AM
Helix13mini's Avatar
Helix13mini
By the time you are done buying parts, solving little problems, and perhaps paying a mechanic, you're better off selling the R50 and buying a nice R53. I know that's a headache as well, but you'll end up saving time/money.
Old Apr 10, 2013 | 10:29 AM
PelicanParts.com
Vendor
Sounds like the right decision - glad you're back on the road!
Old Apr 10, 2013 | 12:23 PM
Densmini's Avatar
Densmini
As far as the Cruise question, some have had success, others still trying to crack that mystery. At a minimum, (after recoding your DME and all other modules to be Man. transmission), you will need a clutch switch and then do some wiring into your EWS and DME. The DME is the tricky part if you are converting from a CVT, because you will have to install a 'female' in the harness to connect to the clutch switch pin (can't remember the pin # at the mo). I am in the process of that now, and will let you know if I am successful.
Old Oct 12, 2022 | 08:29 AM
hokiejoey's Avatar
hokiejoey
Request for DIY instructions
Hello. I see from your post that you had DIY instructions for the R50 trans swap from Midlands to 6 speed. if you still have them, would you be able to send them to me?
Thanks, Joe
Old Oct 17, 2022 | 09:50 AM
Thinker2112's Avatar
Thinker2112
This may help.
https://www.motoringalliance.com/art...ini-cooper.56/
PsychoRallye
21
Feb 17, 2019 06:08 AM
NorthWestEuro
Oct 22, 2016 07:57 AM
NorthWestEuro
Oct 20, 2016 06:41 AM
mni928
Nov 9, 2015 07:38 PM
bahman
Sep 30, 2015 01:59 PM
