Cooper (non S) Modifications specific to the MINI Cooper (R50).
How to install an Oil Pressure Sensor ?
Old Jan 30, 2011 | 08:45 AM
Walt's Avatar
Walt
OK, I have read many threads and posts here, possibly too many, and I am being left confused. There is a lot of info, some of which is contradictory.
What size is the factory oil pressure switch's threads? 1/8" ? 3/8” ? Some metric value? I have read several posts of others asking this question, but never saw an answer.
I believe I need some kind of "T", like the one shown in the pic below, that I am borrowing from one of the threads. This will allow the original factory oil pressure switch and the new oil pressure transducer to share the same attachment point.
Where can I get such a "T"? Does anyone have a PepBoys or AutoZone part number?
What is it made of, brass? Aluminum? Something else? I am reading the "cons" for both.
What size is it?
Should it be ridge or flexible?
Any other suggestions would be appreciated!
Old Feb 9, 2011 | 01:43 PM
minimadness's Avatar
minimadness
Good question, I was interested in installing one myself. I hope you get a reply.
Old Feb 9, 2011 | 05:08 PM
Vollgas's Avatar
Vollgas
http://www.cravenspeed.com/products/...-Adapters.html
The "T" is not a T. It is a Sending Unit Adapter.
It is sold by Craven Speed. Refer to link.
It will allow you to mount a oil pressure sending unit AND a oil temperture sending unit.
Old Feb 9, 2011 | 06:38 PM
ScottRiqui's Avatar
ScottRiqui
If you have a car with the "Chrono Kit", you get an oil pressure gauge and oil temperature gauge, and still have the low oil pressure idiot light. Where do all of the factory senders go? Does the factory use various adapters on a single threaded hole, are are there additional sender mounting locations that go unused on cars without the Chrono Kit (and therefore may be available for aftermarket gauges)?
Old Feb 9, 2011 | 06:43 PM
Vollgas's Avatar
Vollgas
Can't really ansewer that offhand.
Suggest you look at Bentley manual for that.
Old Feb 9, 2011 | 06:46 PM
ScottRiqui's Avatar
ScottRiqui
I already have the Chrono Kit, but if there are in fact unused sender holes from the factory, I just thought it might be another option for those looking to add aftermarket gauges.
Old Feb 10, 2011 | 04:23 AM
Walt's Avatar
Walt
Very interesting suggestion. Thanks for mentioning it.
Now if someone just knew the answer.
Old Feb 10, 2011 | 05:23 AM
Short Wait's Avatar
Short Wait
The adapter you need is shown on the Craven speed link as shown above. Just give them a call. You will have to disconnect the yellow clip thingy and unscrew the plug it is attached to (prevents the wire from being broken), then screw the new adapter into it's place. Place the original screw that you removed previously into the large (rear hole) of the new oil pressure adapter. The remaining 1/8 npt hole is for the sending unit that comes with the gauge you are using. I would use teflon tape on the threads. Models after year 06 use a different type of adapter but basically the same procedure is used. It looks like the pix already has an adapter installed.
Old Feb 10, 2011 | 06:06 AM
36rodder's Avatar
36rodder
From: I live in Webster, NY (just east of Rochester)
You can also mount it remotely
Mounting the oil pressure sender and the idiot light sensor in the stock location is a really tight fit. Not much room under the oil filter. I did a remote mount for both senders. Much easier to thread everything up and attach your wires. Did this 8 months ago and "no leaks"
Old Feb 10, 2011 | 06:15 AM
Walt's Avatar
Walt
What did you use for the "remote" tubing?
Old Feb 10, 2011 | 08:06 AM
36rodder's Avatar
36rodder
High Pressure steel braided line with 3/8" fittings on each end. You don't need anything quite this tough but I had this laying around my shop so I used it. Any line that is rated for ~100 psi will work since the oil pressure runs up to ~60 psi or so.
Old Feb 23, 2011 | 04:12 PM
FlynHawaiian's Avatar
FlynHawaiian
If you use the adapter and don't use the remote idea, can an electronic sender work? I’m going to be installing the nexus gauge.
Old Feb 24, 2011 | 04:21 AM
Walt's Avatar
Walt
I haven't done this yet, but I believe the answer is "yes". Using the remote hose or tube, is only to allow you to put the electronic sender a bit further away. That helps only because otherwise, it is a pretty cramped area to get your hands and tools into. Cramped, though, does not mean impossible.
Old Feb 25, 2011 | 01:20 AM
Checkmate_2006's Avatar
Checkmate_2006
I just installed an oil pressure gauge this past weekend. I bought the adapter from Cravenspeed. It was easy to install. I have the electronic sender coming off the adapter and then ran the wire into the cabin following my boost lines and water temp sensor lines.
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
squawSkiBum
Oct 2, 2015 09:21 AM
