Cooper (non S) Modifications specific to the MINI Cooper (R50).
Newman cam??
Old Jul 21, 2010 | 02:44 PM
davisflyer's Avatar
davisflyer
Newman cam??
Has anyone installed a Newman cam in their R50? My dad is looking for a bit more low to mid range power and the Newman 260/396 cam says it has "Good Increase of Low Mid Range Power Smooth Idle For Non Supercharged Engine"
Just wondering how much of a difference this would make in the R50....
Old Jul 21, 2010 | 04:35 PM
Dr Obnxs's Avatar
Dr Obnxs
Performance cams in NA motors are great!
and really, for pretty much all the cams out there for the MINI, they can all be run on both the cooper and the cooper s. Drag cams for blown motors have overlap that isn't good for N/A motors, but I have yet to see a cam for the Tritec MINI that is designed this way. Reason is that a lot of the time cams have to idle and run at part throttle, when the car is off boost. A true
"blower cam" would have problems with both of these issue.
Best way to go is to really think about how your dad drives his car. Choose any of the cams that are offered that are optimized for that RPM range and he'll be happy.
If you are new to the world of camshafts, talk to your mechanic about thier experience and use reccomendations.
Matt
Old Jul 21, 2010 | 04:46 PM
davisflyer's Avatar
davisflyer
My dad is 73. He doesn't redline the car, usually shifts by 5k rpm, but he'd like more oomph, particularly off the line.
Old Jul 22, 2010 | 06:35 AM
nickbmw's Avatar
nickbmw
There is no such camshaft on the market that will gain midrange on the R50, i higly suggest you stay with the stock camshaft.
Old Jul 22, 2010 | 02:54 PM
davisflyer's Avatar
davisflyer
According to Newmans literature, there's will increase low to mid-range power.
Old Jul 22, 2010 | 08:27 PM
Dr Obnxs's Avatar
Dr Obnxs
nickbmw
what do you define as mid range? there are cooper owners out there who are happily driving with cams.
Matt
Old Jul 23, 2010 | 06:05 AM
nickbmw's Avatar
nickbmw
If you think so, buy it... and let me know the results, it will be interesting.
Old Jul 23, 2010 | 06:07 AM
nickbmw's Avatar
nickbmw
Matt
Good question, for me midrange is 2500 to 4500, and this range is the weak spot of the R50 engine, especially the 2500 to 3500, it's a flat spot there.
Old Jul 23, 2010 | 06:11 AM
rjtrout2000's Avatar
rjtrout2000
Where did you find the Newman Cam to purchase?
Old Jul 23, 2010 | 07:22 AM
Dr Obnxs's Avatar
Dr Obnxs
It's on Newmans website...
They list 4 cams for the Tritec MINI.
Matt
Old Jul 23, 2010 | 07:27 AM
nickbmw's Avatar
nickbmw
Οnly one is a street R50 camshaft.
Old Jul 23, 2010 | 12:53 PM
davisflyer's Avatar
davisflyer
Well, I don't know, that's why I was asking for opinions from people who might have one. I see you have a Newman in your signiture. Is your car an R50?
Old Jul 23, 2010 | 05:45 PM
rjtrout2000
Matt
Can you purchase the cam directly from Newman?
Old Jul 23, 2010 | 06:21 PM
cct1's Avatar
cct1
No. You used to be able to, but Newman doesn't want to kill it's vendors--so in the U.S., it's RMW and it's distributors. You can buy it from other vendors accross the pond and have it shipped here, but that's the only way you'd be able to get a new one other than from RMW.
Old Jul 24, 2010 | 12:00 AM
nickbmw's Avatar
nickbmw
https://www.northamericanmotoring.co...ml#post3037474
You have subscribed to that thread
Old Aug 5, 2010 | 02:09 PM
ZlotyR50's Avatar
ZlotyR50
Where's the oomph
Hi Davis,
I am new to Minis but I was reading your thread and the question that came to mind for me was what RPM is your dad at off-the-line where you stated he wants more power?
The Newman cam which you are referring to is the PH1 cam and they state an RPM range of 2000-6500 RPM. I asked if NickBMW, in his cam thread, if he has a torque curve with and without the Newman PH1 and if we could see it. If we have the curves and we know what RPM your dad comes off the line we should have your answer. The most oomph will always be where the torque is the highest so if the torque is increased at the RPM your dad has as the target he will get an improvement. If the cam shifts the torque peak and by doing so the torque (despite being overall higher) is lower at the RPM range he is looking for then he will not be happy.
Hope that helps
gnhovis
Dec 14, 2015 05:31 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
WhinyR53
Sep 30, 2015 07:36 AM
donniedarko
Sep 29, 2015 01:16 PM
Nicefeet
Sep 24, 2015 06:53 PM
