Cooper (non S) Modifications specific to the MINI Cooper (R50).
Oxygen sensor problem
Old May 22, 2010 | 06:39 AM
nickbmw's Avatar
nickbmw
Hi guys, i bought off ebay a Bosch oxygen sensor recently, part number 13878, which is the part number i found when i was looking for the correct one. I tried to install it but it will not clip into the connector, because there is a slight difference. I am under the impression that the US models have a slightly different connector. Could someone take a pic please of the connector to see if it's different between Euro and US models?
Old Jun 4, 2010 | 03:57 PM
velopackrat's Avatar
velopackrat
O2 sensor??
Hi Nick,
Sorry, as I haven't checked the forum lately to see what you're up to. Did anyone get you a pic? I have an o2 sensor in the shop and can snap a pic of it if need be.
Regards,
cw
Old Jun 5, 2010 | 05:56 AM
nickbmw's Avatar
nickbmw
Hello buddy, unfortynately noone was able to help, if it's not a problem for you please take a pic of the inside of the o2 connector.
regards,
Nick
Old Jun 5, 2010 | 07:38 AM
ramjet77's Avatar
ramjet77
Something is odd. The 13878 sensor is identified in a couple of threads on this forum as an exact replacement. Amazon.com has a couple of reviews from Gen 1 owners that say this sensor is an exact replacement, one of whom identifies his location as California. I hope someone on this forum who participated in the original thread will speak up.
Old Jun 7, 2010 | 03:51 PM
velopackrat
Is this the pic you need?
Hey Nick,
See if this is the pic you're looking for.
cw
Old Jun 7, 2010 | 06:55 PM
chadtoolio's Avatar
chadtoolio
I've run into this problem....I had to swap the connector housing or modify it to work. And in the end the Bosch didn't work anyway( it cooled of at idle and started sweeping very erratically and set codes...
Old Nov 18, 2010 | 07:43 PM
gknorr's Avatar
gknorr
Were you using Bosch 13878? Thought that was supposed to be the exact replacement...?
What did you end up using?
Old Jan 4, 2011 | 06:19 AM
gknorr's Avatar
gknorr
The exact replacement O2 sensor in my '03 MINI is the NTK 25648. I tried the ACDelco and Bosch and both threw codes. I put the NTK in, everything is okay again.
I found out it was NTK when I pulled the original off. Although the MINI sensor has different numbers on it, NTK assured me that their aftermarket sensor is the exact same sensor as the original MINI one, and my experience certainly shows that to be true.
Old Jan 4, 2011 | 06:37 AM
nickbmw's Avatar
nickbmw
Ι also replaced mine with the NGK (NTK) one, my OEMs are also NTK, and it works ok.
Kimolaoha
Jul 5, 2023 01:04 PM
alistaircookie
Oct 8, 2015 10:52 AM
HaveATank
Sep 4, 2015 08:04 AM
Marktheman
Aug 23, 2015 11:45 AM
massmini03
Aug 12, 2015 11:19 AM
