Cooper (non S) Modifications specific to the MINI Cooper (R50).
Camshaft without ECU remap?
Old Mar 12, 2009 | 09:25 AM
nickbmw's Avatar
nickbmw
Hello to everyone. I am thinking to install a Schrick camshaft, and my concern is, will it work properly without recalibrating the ECU? Ok, i know that recalibrating the ECU will take the most from the camshaft, but for now i want to install it without an ECU remap.
Do you think i'll have any kind of problems? Will the factory ECU be able to compensate the A/F mixture, even a bit? I wouldn't want to run lean...
Just to give more info, other mods i have are a K&N panel filter and Supersprint cat back. (Unichip sold....) And the camshaft profile is not very agressive, it is 260 duration.
RMW, any advice...? Your opinion matters
Old Mar 12, 2009 | 09:41 AM
JIMINNI's Avatar
JIMINNI
Hmm... since RMW sells a different cam he might not respond to this. You could try Mynes or Johnnies Auto Clinic?
Old Mar 12, 2009 | 09:50 AM
nickbmw's Avatar
nickbmw
Maybe you are right, but it's not about one certain cam here, but a general question. I just supplied the cam brand and specs, to make it more clear to those who'd like to help
Old Mar 12, 2009 | 09:53 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Lots of folks are running the Shrick cam on stock tune..... since that camshaft was available long before widespread custom tuning was...
Old Mar 12, 2009 | 10:12 AM
nickbmw's Avatar
nickbmw
Thanks for your help Are you talking about an S (R53) or R50?
Old Mar 12, 2009 | 10:16 AM
BlimeyCabrio
Most I'm aware of are on MCS's.... but I don't know that it should matter in this case.
All that said... if it were my car, I'd do a dyno afterward with A/F to be sure...
Might be safer with JCW injectors...
pathill's Avatar
pathill
Go for Johnnies Auto clinic, they did an awesome job for me way back. So you get your money's worth.
Old Mar 12, 2009 | 04:29 PM
chadtoolio's Avatar
chadtoolio
Plus 1^....Just got to dyno with AF to be sure..
bahman
Feb 14, 2016 10:29 AM
mni928
Nov 9, 2015 07:38 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
Sep 25, 2015 12:32 PM
