Cooper (non S) Modifications specific to the MINI Cooper (R50).
It can install injectors JCW in "MINI One 08/2005"?
Old Sep 21, 2008 | 01:30 AM
badmadlauren's Avatar
badmadlauren
It can install injectors JCW in "Mini One 08/2005"?
I need to know if he is compatible the injectors of "Mini Cooper S JCW" with "Mini ONE".
Old Sep 21, 2008 | 03:16 AM
1nf3rn0's Avatar
1nf3rn0
You probably don't need them... But I don;t see why they wouldn't work....
Old Sep 21, 2008 | 08:34 AM
OldRick's Avatar
OldRick
You are probably asking on the wrong site, as the Mini One was not imported to the US. Try asking the question at http://www.mini2.com/forum/ in the UK.
Old Sep 21, 2008 | 08:55 AM
badmadlauren
need to know if somebody has installed injectors JCW in MINI One/Cooper
Old Sep 21, 2008 | 09:05 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
I dont beleive anyone has installed the JCW's on a justacooper. maybe im wrong, i dont really see why you would need that much more fuel???
Old Sep 21, 2008 | 09:26 AM
badmadlauren
This serious one I complete it that I have left to install.
To greater volume of fuel flow greater increase of acelereación. I
have modified the CPU and filter air.
Old Sep 21, 2008 | 09:48 AM
OldRick's Avatar
OldRick
Lots of luck - probably a complete waste of money.
Again - you are asking the wrong group - try MINI2, where they actually sell the One.
Old Sep 21, 2008 | 10:05 AM
AliceCooperWA's Avatar
AliceCooperWA
Well, the MINI one is the same as the non-S, just a different ecu and slight other changes. If you are asking about the jcw injectors from the S...then it is complete overkill. If you want bigger injectors, then you would likely be better off going with stock S ones. I don't know if/how much bigger they are, but they can handle much more fuel than our cars are capable of putting out. They are cheaper and still total overkill. Check the market place periodically and maybe put a want to buy stock S injectors...you will save a lot of money and still get what you want.
What you have to understand is that you will not be pumping any more fuel with the JCW injectors. You will only increase the amount of fuel that they are capable of flowing. You will still be flowing the same amount of fuel...just with bigger injectors. It will have literally no effect on anything. You may want to have a dyno tuner check the duty cycle of your injectors...I don't know if it can even be done on a mini...
If you are flowing more fuel than your injectors can handle, then you are in danger of leaning out up top and blowing up your engine. If you are no where near the top of the duty cycle of your injectors, then you are just throwing money into the trash can.
Old Sep 21, 2008 | 10:11 AM
badmadlauren
Thanks for its explanation
Old Sep 21, 2008 | 10:14 AM
badmadlauren
I want to have more horses power and I not to obtain itself more
Old Sep 22, 2008 | 12:59 AM
xnotfunkylex's Avatar
xnotfunkylex
JCW injectors won't give you more horse power. For that you probably want to look into getting a new cylinder head way before new injectors.
OT, but does a MC or ONE need an oil catch can?
Old Sep 22, 2008 | 07:56 AM
CarterMD's Avatar
CarterMD
No, they dont fit on the electrical harness. The plugs are totally different, so... no way !
iggi
18
Feb 9, 2026 01:00 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
Mini'mon
Aug 26, 2015 01:02 PM
