Cooper (non S) Modifications specific to the MINI Cooper (R50).
N00b question about turning my non-s into a faster non-s, lol.
Old Aug 3, 2008 | 08:16 PM
Cudda_Kine's Avatar
Cudda_Kine
http://www.google.com/product_url?q=...hl=en&sa=title
Could i replace my 2005 R50 Mini cooper engine with this one to successfully have a supercharge on it? or is there a "safe" supercharge kit for the r50?
Please let me know, i'm really considering this option, .
Old Aug 3, 2008 | 08:24 PM
hemiheaded18's Avatar
hemiheaded18
You could the swap but it requires the R53 ECU and related sensors. And the hood to clear the intercooler if you want to retain the OE design. And the Getrag to bolt to it. By that point, you're over $10k into a car that's gonna have no more power than a stock S would have to begin with for not much more. And that's just in parts, not including labor. For that much, you're better off, like 98% of these kind of endeavors, getting an R53 if you want a faster MINI. And as far as a "good" supercharger design, Jan at RMW has an R50 Rotrex kit in the works designed to deal with the high compression of the NA motor.
Old Aug 3, 2008 | 09:08 PM
UKSUV's Avatar
UKSUV
MCS SWAP-I found out that I will need an interior harness for sure including the fuse box. Cause I saw that the Cooper only has the bottom green (fuel pump relay) and an S has all 3....
Old Aug 4, 2008 | 05:54 AM
Rix's Avatar
Rix
Well imo i would just buy a bluefin superchip, instead of that. It will run you about 600$ instead of 6000, and you will feel the increase promptly.. i am so satisfied with mine.. :D, and thats just a re-map.. :d also do a new exhaust system, and a nice induction filther, that should give you the extra power.. atleast thats about what theres to be done in the power department with an r50, without blowing your wallet. Else as said before just buy an r53. :S:D
Old Aug 4, 2008 | 09:53 AM
AliceCooperWA's Avatar
AliceCooperWA
If you are REALLY considering an engine swap, then you may want to call Jan at RMW. I think you could get a much better engine from him with a standalone ecu and just drop it in for uhh...still like $10k, but you would have a crapload more power if the getrag 5spd could take it.
Old Aug 4, 2008 | 03:49 PM
07BPB's Avatar
07BPB
Its all dependent on how much money you want to spend:
Bolt on CAI intake, catback, ecu remap etc
- some gains in power and cheaper, but you still wont be making wat a MCS makes
R50 Rotrex Kit
- still in the making and will be costly, but it will really liven the R50 up. Apparently it should run with the stock internals as its only running 6 psi of boost
Engine swap from Jan
- he has a 2.0 Mini engine which will be insane, but also around $12,000.
Personally I am just going for the first two I mentioned, getting the R50 engine going crazy, then giving it a turbo once I am positive the engine can handle it.
Old Aug 4, 2008 | 11:33 PM
Cudda_Kine's Avatar
Cudda_Kine
How do i get this "R50 Rotrex kit"?
Old Aug 5, 2008 | 12:44 AM
07BPB's Avatar
07BPB
Its underdevelopment by a man named Jan from Revolution Mini Works. When it comes out I am sure you will hear of it.
thebordella
Aug 31, 2015 01:37 PM
polotska
Aug 23, 2015 09:10 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
Shelly Cooper
Aug 10, 2015 12:05 PM
nismo4life
Aug 5, 2015 08:31 AM
