Cooper (non S) Modifications specific to the MINI Cooper (R50).
R50 Clutch replacement
Old Jul 11, 2008 | 03:36 PM
hemiheaded18's Avatar
hemiheaded18
It doesn't need it now (knocks on wood) but sooner or later, it will. I know pretty much what I want clutch wise but have 2 questions. 1, does anyone have any reccomendations on who makes a good Stage 1 clutch? I don't need anything outrageous. It's a DDM and a Borla, thats it. And 2, what have you done with the flywheel? OE replacement? Gone to aluminum? Or just have the factory FW cut?
Old Jul 11, 2008 | 03:51 PM
UKSUV's Avatar
UKSUV
i have the fidanza 13lb flywheel and a clutchmaster clutch. its so easy but the subframe needs to be pulled....thats the only long part...and make sure you have a hoist to keep the trans level....
Old Jul 11, 2008 | 03:58 PM
hemiheaded18
Do you have any driveablility complaints about the Fidanza? The OE flywheel weighs, what, like 18lbs? So going to 13 shouldn't make too much of a difference right? I hear horror stories of a lightweight flywheel being a nightmare to drive but I think that's going from the DM on the R53 to a SM and dropping 20lbs off the flywheel.
Old Jul 11, 2008 | 07:16 PM
UKSUV's Avatar
UKSUV
As far as I know the OEM Cooper flywheel weighs like 34lbs. Im sure it was misquoted but not by much. The Fidanza flywheel and clutch isnt in my Midlands. Its waiting to be coupled with my 6-speed so I couldnt tell you how it drives. I just need 1/2 shafts...
Old Jul 11, 2008 | 07:41 PM
hemiheaded18
The R53 flywheel is a dual mass and weighs about 34lbs. The R50 flywheel weighs in at about 18-20 I believe. Am I wrong here, any takers?
Old Jul 12, 2008 | 10:06 PM
AliceCooperWA's Avatar
AliceCooperWA
Yeah, the r50 one is much lighter. It is not that much of a weight reduction, so there probably will not be too much difference over stock in performance or driveability. But from my research into this, I believe that most aftermarket lighter flywheels are actually similar in price to OEM if not cheaper. If the flywheel needs to be replaced, then you might as well get something better than oem.
Old Jul 13, 2008 | 09:17 AM
hemiheaded18
^^^That's what I thought. And I'm one of those people who believe if a clutch is swapped, then you either cut the flywheel or go new. Andif there's going to little weight change in OE to aftermarket Al, why not go aluminum? Yeah, to get one cut is maybe $100 compared to 350+ for a new Al one but it's kinda like cutting rotors. Which I don't do, either.
Old Jul 13, 2008 | 10:58 AM
silversmoke06's Avatar
silversmoke06
You want clutchmasters. They make good stuff.
eliseo1981
Jan 28, 2021 02:45 PM
robertcoyle
Aug 18, 2015 09:28 PM
PrimePower
Aug 16, 2015 06:29 PM
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
