Cooper (non S) Modifications specific to the MINI Cooper (R50).
MSD Ignition Coil
Old Jul 13, 2008 | 06:37 PM
  #101
Nitrominis's Avatar
Nitrominis
Originally Posted by AliceCooperWA
Ok, I'm done ranting
well I tried
I use MSD coils on my motorcycles also
Old Jul 13, 2008 | 06:56 PM
  #102
muladesigns1's Avatar
muladesigns1
[quote=AliceCooperWA;2360479]Ok, lets move this thread into more of a positive discussion type of direction...
Old Jul 13, 2008 | 07:00 PM
  #103
AliceCooperWA's Avatar
AliceCooperWA
Alcohol and boredom is an interesting combination.
Old Jul 13, 2008 | 07:43 PM
  #104
Longboard Mini's Avatar
Longboard Mini
Rum and coke on a Sunday night
LB
Old Jul 13, 2008 | 07:49 PM
  #105
big howe's Avatar
big howe
LB
I'm partial to Beam and Coke myself.
Old Jul 13, 2008 | 07:58 PM
  #106
MiniMaybee's Avatar
MiniMaybee
Has anyone pointed out that the MSD is red?
Old Jul 13, 2008 | 08:17 PM
  #107
Revolution Mini Works's Avatar
yes... I pointed that earlier... it's about the coils only saving grace
Old Jul 13, 2008 | 10:27 PM
  #108
AliceCooperWA
In my case, it was a couple of dogfishheads...and a rogue dead guy
Old Jul 13, 2008 | 10:38 PM
  #109
Nitrominis's Avatar
Nitrominis
Old Jul 15, 2008 | 10:49 PM
  #110
AliceCooperWA
Errr...why the quote?
Old Jul 16, 2008 | 10:42 AM
  #111
OldRick's Avatar
OldRick
Just another of my mis-informed posts...
Yesterday I replaced my stock coil with an MSD. To my great surprise, the car now runs noticeably smoother between 6K and 7200.
Note: I don't know that smoother has to equate to measurably more powerful, as it seems to me that a few milliseconds faster ignition in one cylinder at high rpm might be audible to my ear (which is well-trained), but not measurable on a dyno, which is an extremely crude instrument for an ignition analyzer.
Anyway, the point of this post is simply to state that the reason I replaced the stock coil is that one of the terminals was showing evidence of arcing. A small black spot - a bit smaller than a BB - was visually apparent, and that terminal looked a bit dusty.
IMHO, this is not evidence of any sort of chemical corrosion, but instead is the result on high-voltage arcing on a plated surface. At Mini-Madness, George showed me two other stock coils that he had replaced: one had a spot a bit larger than mine, and one had a whole terminal almost completely blackened. In all of these cases, I could not see any evidence of chemical corrosion, but of electrical "erosion". The dust that appears on a damaged terminal is almost certainly vaporized metal, not chemical residue, which would be whitish.
So the reason why I believe I am getting slightly better high-rpm ignition is that one terminal on the coil was not making a good connection. With luck, the brass terminals on the MSD will do better, as brass is a better conductor than nickel-plated steel.
So, the next issue is whether replacement with a stock coil would work as well, and my guess is that it probably would.
So bloody what?
The MSD, which looks like it was made on the exact same machine as the stock coil, cost less, and might work a hair better. Seems like enough justification for choosing the MSD-branded version to me...
Old Jul 16, 2008 | 10:45 AM
  #112
So the reason why I believe I am getting slightly better high-rpm ignition is that one terminal on the coil was not making a good connection. With luck, the brass terminals on the MSD will do better, as brass is a better conductor that nickel-plated steel.
So, the next issue is whether replacment with a stock coil would work as well, and my guess is that it probably would.
So bloody what?
any chance you dyno the car with both coils to show the difference?
Old Jul 16, 2008 | 10:46 AM
  #113
OldRick's Avatar
OldRick
Sure, if you're paying for the dyno time.
Old Jul 16, 2008 | 10:58 AM
  #114
thanks for the butt dyno result
Old Jul 16, 2008 | 11:00 AM
  #115
hemiheaded18's Avatar
hemiheaded18
Always dependable!
Old Jul 16, 2008 | 11:03 AM
  #116
Originally Posted by hemiheaded18
Always dependable!
I know many make a living off of them
Old Jul 16, 2008 | 11:06 AM
  #117
CFMINI's Avatar
CFMINI
Jan -
I heard you were going to put an MSD coil on your GP because it matches the mirror caps!!
Old Jul 16, 2008 | 11:10 AM
  #118
OldRick's Avatar
OldRick
Thanks for the inane comment. I didn't say a word about getting any more power. I replaced the coil with a different-brand because it was showing evidence of arcing. The new coil works better because it doesn't have scorched contacts. End of story.
But go ahead, respond and have the last word again - we know you've just gotta...
Old Jul 16, 2008 | 11:35 AM
  #119
jimz68's Avatar
jimz68
And then there's the "Screamin' Demon" coil..............
(Running away, ducking for cover)
Old Jul 16, 2008 | 12:08 PM
  #120
OldRick's Avatar
OldRick
And another thing - coil installation tip
Just got back from the car. It occurred to me that if an electrical connection is arcing, it will be spraying metal vapor all over the place, not just on one of the surfaces of the connection...
So I got out the Deoxit, cleaned the wire connectors at the coil end with Deoxit and a q-tip, and sure enough, the connector on the wire where the arcing had occurred was filthy with the same black stuff that had been on the coil connector.
Left in place, this vaporized metal and metal oxides would add to the resistance of the connection, and likely lead to future arcing, so there's an angle on the "they all fail again even after replacement" issue...
So, clean out these connectors or use new wires if you are replacing a coil.
The other three wire connectors were clean as a whistle, so I view all this as additional evidence that the issue is arcing, not chemical corrosion.
BTW, George M. tells me that it's almost always the cylinder #3 coil connector that fails first - the one nearest the (US) driver - so if you want to do a quick check on the condition of your coil, check that one for the dreaded black spot and dust.
Old Jul 16, 2008 | 12:55 PM
  #121
friuli's Avatar
friuli
after all of these comments, i..... dont think ill get one.
Old Jul 16, 2008 | 01:44 PM
  #122
newbs49's Avatar
newbs49
RED IS ALWAYS FASTER
Oh !!!!!!!!!!!!!!!!!!!!! Sorry he's not around anymore. :razz:
Old Jul 16, 2008 | 01:45 PM
  #123
checkmate2006's Avatar
checkmate2006
bwahhhhhhhhhhhhhhhhhhhhhhhh
Old Jul 22, 2008 | 05:22 PM
  #124
BoostyMINI's Avatar
BoostyMINI
SOMEONE PASS THE POPCORN
Old Jul 22, 2008 | 05:30 PM
  #125
andrewholmes's Avatar
andrewholmes
egads man...take mine already!
