Cooper (non S) Modifications specific to the MINI Cooper (R50).
MSD Ignition Coil
Old Jul 10, 2008 | 07:34 PM
  #26
JIMINNI's Avatar
JIMINNI
Originally Posted by El_Griton
I put my stock plug wires back on and I gained 10 hp. Jk. (but I did put the stockers back on! )
Some one in the "know" hinted at it!
pass that popcorn!
Wow, so you did a dyno before and after of installing both sets? What non OEM wires were you using?
Old Jul 10, 2008 | 07:49 PM
  #27
MiniMaybee's Avatar
MiniMaybee
I can definitely say without dispute that I have proof the MSD is red.
Old Jul 10, 2008 | 07:51 PM
  #28
hemiheaded18's Avatar
hemiheaded18
And, that it's an MSD product.
Old Jul 10, 2008 | 08:00 PM
  #29
El_Griton's Avatar
El_Griton
Sorry, the JK means Just Kidding. I need to remember not everyone plays online first person shooters.
I took the og wires off for a set of jackson racing wires. I then spit a plug out of my cylinder head, so I have been going back to mostly stock electrical equipment before my RMW tune.
Old Jul 10, 2008 | 08:50 PM
  #30
JIMINNI's Avatar
JIMINNI
Actually I do play a online first person shooter game, DFLW. But haven't seen that acro.
Old Jul 10, 2008 | 08:55 PM
  #31
ADAM244's Avatar
ADAM244
Ok...so no MSD for me. Thanks for the entertainment guys...
Old Jul 10, 2008 | 10:30 PM
  #32
AliceCooperWA's Avatar
AliceCooperWA
Originally Posted by Nitrominis
I suppose you would be the one that hasn't done it.
As I said for those that question " place an OEM and an MSD on an oscilloscope you can graphically see the difference".
And sure its a waste of a small amount of money to get a slight improvement . Spend lots of money to get small improvements
The voltage rating has very little to do with the performance of a coil by the way!
Maybe under laboratory conditions, the MSD will perform better, but you will not see ANY performance gains unless the stock one is not performing it's job correctly. The stock one is more than sufficient! It will make absolutely no power gain!
Old Jul 11, 2008 | 02:05 PM
  #33
Nitrominis's Avatar
Nitrominis
It your choice to use a product or not but get the information correct. And I did not mention power gain. What I said was a better-stabilized spark. So this by itself makes it an improvement over the OEM. I also gave a source to an expert in the field to contact to learn about coils and not necessarily MSD? And I also tried to illicit imperical proof by asking that the one(s) that claim it not to be an improvement to see the results of there claim on a scope. Which is were you would measure the difference NOT a DYNO as Data DYNO Jan tried to use as a reference to measure a coils capability. And I read the negatives on other posts and concluded that most were under a miss installed, other problems, bad choice of wires and generally not fully knowing what they were doing as a result of there less then good experience with MSD products. And this is my experience with using MSD products on my daily drivers, Flat Bottom Drag boat, my Super Gas Camaro and many other engines and vehicles over the last 30 years.
Old Jul 11, 2008 | 02:24 PM
  #34
Revolution Mini Works's Avatar
isn't this about the time someone throws up the fail boat picture?
Old Jul 11, 2008 | 03:04 PM
  #35
silversmoke06's Avatar
silversmoke06
  #36
hemiheaded18
Old Jul 11, 2008 | 03:05 PM
  #37
hemiheaded18
Old Jul 11, 2008 | 03:50 PM
  #38
silversmoke06
beat ya to it.
Old Jul 11, 2008 | 03:52 PM
  #39
silversmoke06
Old Jul 11, 2008 | 03:54 PM
  #40
hemiheaded18
Old Jul 11, 2008 | 06:36 PM
  #41
just landed in Chicago and I think the people next to me think I'm looney laughing
Old Jul 11, 2008 | 07:15 PM
  #42
silversmoke06
  #43
silversmoke06
Im done.
Old Jul 11, 2008 | 08:26 PM
  #44
Nitrominis's Avatar
Nitrominis
Most of you are why I have a rear veiw mirror. By the way the boat pictures are wrong, if you wanted to dis you show a boat (Flat bottom or Hydro) kiteing not pictures of ships?
Old Jul 11, 2008 | 08:28 PM
  #45
HighLife4136's Avatar
HighLife4136
Can I join the bandwagon?
Old Jul 11, 2008 | 08:34 PM
  #46
silversmoke06
Fine all abord the fail ship done being a smart ***?
and yes welcome to the bandwagon.
Old Jul 11, 2008 | 08:42 PM
  #47
Nitrominis's Avatar
Nitrominis
Hey Jan at least you got it right. BOAT. You would think if these guys were to really read instead of following you they might have posted an appropriate picture.
  #48
HighLife4136
Hello young man (boy)
Old Jul 11, 2008 | 08:46 PM
  #49
gnatster's Avatar
gnatster
The MSD unit may perform better on a scope but so far we've seen lots of examples where the tips corrode. How can we all be installing them incorrectly to have the same issue? I ran mine with Kingsborne wires with dielectric grease on the tips and saw corrosion to the point of misfire codes. Swapped the OEM wires and still had the same codes. Swapped out the MSD for a stock unit and codes went away. I did clean the tips on the MSD unit with emory cloth and still would get corrosion after about 1K miles or so. Oh yeah, it doesn't rain much here either and I tend to drive the Jeep when it does.
So while it may be a technically superior unit, in practice on a MINI they have proven to be problematic. Keep the MSD stuff for your big block, just not on my MINI.
Old Jul 11, 2008 | 08:47 PM
  #50
gnatster's Avatar
gnatster
BTW...I think we've had enough piling on with the FAIL stuff...
Make it stop
