Cooper (non S) Modifications specific to the MINI Cooper (R50).
Best bang for your buck.
Old Mar 25, 2008 | 01:27 PM
  #26
glnr13's Avatar
glnr13
Originally Posted by redlinedave
url
try this mod
NO RICK ROLLING!!
Old Mar 25, 2008 | 01:44 PM
  #27
redlinedave's Avatar
redlinedave
lol..
Old Mar 25, 2008 | 02:44 PM
  #28
rjtrout2000's Avatar
rjtrout2000
Wow
Old May 2, 2008 | 06:18 PM
  #29
LJMurphman's Avatar
LJMurphman
A question about the rear sway bar. I enjoy driving the twisties but I do not race or autocross. Bone stock 2004 MC. What's the best choice? 22mm set low but enabling me to stiffen or 19mm set high?
Opinions?
Old May 2, 2008 | 07:32 PM
  #30
Dr Obnxs's Avatar
Dr Obnxs
I'd do neither
I'd pick up a used bar from an S and go with that.... Real cheap!
Also, are you experiencing and bothered by the understeer?
How's your tire wear?
Matt
Old May 2, 2008 | 11:41 PM
  #31
rjtrout2000
I like the 19mm rear swaybar since my suspension and my car is relatively mild in mods. I also have TSW springs, UHPAS tires with Azenis Fallken on the wya, and some bracing by OMP. Overall, I am really happy with the suspension of the ride! A 22mm rear sway is overkill imho
Old May 2, 2008 | 11:55 PM
  #32
heyduard's Avatar
heyduard
from the other end. :)
Opinions?
fixed camber plates. Will improve grip through apex, with no additional NVH. Not expensive either. Will address the mushroomed strut tower issue as well. If NVH is not a problem, adjustable camber plates.
Old May 3, 2008 | 12:30 PM
  #33
Dr Obnxs's Avatar
Dr Obnxs
Really, watch the "just bolt it on" approach....
Both bracing and camber plates will reduce the understeer somewhat. I guess what I'm trying to say is that if you have an issue, address that. The quest for "better" is very ellusive when it comes to suspension.
Here's an example.... Some fixed plates, lower chassis stifining and playing with tire pressures will reduce or eliminate understeer, depending on exact implementation details, then adding more rear bar will just "overdo" it.
If you drive on lots of poor surfaces, stiffer bars can reduce grip at speed (as can stiffer springs). So it depends on what you drive on what the best change is.
If you have tons of crappy roads to drive on, you can reduce understeer by disconnecting the front bar (what's important is the relative bar strengths, not the absolute stiffness for understeer oversteer compansation) and not end up skipping over the tops of the bumps like a rock skips over water.
Just some stuff to think about.
Matt
Old May 3, 2008 | 06:57 PM
  #34
LJMurphman's Avatar
LJMurphman
Very helpful. Thanks folks.
Murph
tr3y003
33
Jun 5, 2020 05:00 AM
jennster
Sep 28, 2015 06:19 PM
Filmy
15
Sep 26, 2015 07:04 PM
Emnotek
Sep 11, 2015 04:16 PM
yukinoinu
Sep 1, 2015 09:28 AM
