Cooper (non S) Modifications specific to the MINI Cooper (R50).
5-speed getrag oil change??
Old Mar 12, 2008 | 05:30 AM
kenros's Avatar
kenros
I'm worried about when I need to change the transmission oil on my '05 MC, at this time I have 45k miles. I will appreciate any help.
Old Mar 12, 2008 | 06:42 AM
UKSUV's Avatar
UKSUV
I changed mine at 30K (the same time I did the Mini's second and only oil change...now at 75K....lol) ...doesnt hurt.
Old Mar 12, 2008 | 01:08 PM
turboexempt's Avatar
turboexempt
what oil do you guys use for you transmission. This is something I have never done before and may be due as well being at ~40,000 miles
Old Mar 12, 2008 | 07:52 PM
seigmann's Avatar
seigmann
Yeah I didn't even know I needed to change the transmission oil
Old Mar 12, 2008 | 08:11 PM
goaljnky's Avatar
goaljnky
x2
Old Mar 12, 2008 | 10:56 PM
Ancient Mariner's Avatar
Ancient Mariner
I did it the easy way: at 42k Mini changed my transmission...
-skip-
Old Mar 13, 2008 | 05:59 AM
IanF's Avatar
IanF
I've changed the oil in a few transmissions. Makes a bigger difference in some more than others, regardless of mileage... makes me think driving style is a big factor... for the older Midlands, it seems to make a BIG difference in shifting smoothness. We've been using Redline MTL.
You probably won't get a straight answer from BMW/MINI regarding this as according to them all of their transmission come with a "lifetime" fluid... ..but they fed us the same line of b.s. 5 years ago when I changed the fluid in our M3.
Changing the fluid is pretty easy. With the engine reasonably warm, undo the fill plug then the drain plug. I use a funnel with an extension hose from the top side of the engine fished down into the fill hole. Much easier/faster than any of the consumer-pump set-ups I've tried. Will take a little less than 2 quarts. IIRC, the Getrag uses a hex-wrench (10mm?) on the plugs.
Old Mar 13, 2008 | 12:06 PM
seigmann's Avatar
seigmann
Are all the five speeds getrag?
Old Mar 13, 2008 | 12:26 PM
03BRG's Avatar
03BRG
The older ones were Midlands not sure of the date change to Getrag
Old Mar 13, 2008 | 12:56 PM
UKSUV's Avatar
UKSUV
I think they changed in mid 04
Old Mar 14, 2008 | 04:55 AM
07BPB's Avatar
07BPB
Is there much off a difference in shifting with a different fluid?
Old Mar 14, 2008 | 05:08 AM
IanF's Avatar
IanF
It seems to really depend... I haven't had to change the fluid in a MC Getrag yet, but there have been varying degrees in improvement to the 6spds and 5 spd Midlands. The Midlands with a bit under 50K on it made quite a bit of difference... and there was also a a lot of mettalic debris attached to the magnetic drain plug.
Old May 1, 2008 | 01:22 PM
05Greenie's Avatar
05Greenie
How can I determine what type of transmission I have?
I have an 05 Mini (R50) with 75k miles on it and afte reading the posts I think I need to change it. Does Redline MTC wotk for either type of trannie?
Old May 1, 2008 | 01:34 PM
Crusoe's Avatar
Crusoe
You have a 5 speed Getrag Greenie but can't recommend a fluid.
Old May 1, 2008 | 01:40 PM
05Greenie's Avatar
05Greenie
Thanks Crusoe for the info.
Do all 05's have Getrag's or is their an indicator somewhere on the car?
Also on another different issue how can I tel if I have a Duelmass clutch?
Old May 2, 2008 | 09:46 AM
b0rkman's Avatar
b0rkman
Found the Answer
I have a 04 Mini R50, but I don't know if it is a Getrag or Midland. Can you tell from the VIN or do you need to call the dealer? I realized they changed from the Midline to the Getrag in 2004; therefore, the change only applies to the 2005 on models. My bad...
Old Mar 14, 2011 | 10:04 PM
nopistons's Avatar
nopistons
Anyone change the fluid on the Getrag 5 speed? The sticker on the transmission is a blue sticker and says LT-3?
According to Redline, that oil closely matched their D6 ATF, which is a pretty light oil. Anyone have any experience using this in their transmission?
Anyone try Redline MTL in the 5 speed Getrag? This oil is thicker, which seems like it would be better if you drive your car hard?
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
HaveATank
Aug 24, 2015 10:26 AM
