Cooper (non S) Modifications specific to the MINI Cooper (R50).
I deleted my rear seat and spare tire (WOW,WHAT A DIFFERENCE!)
Old Nov 20, 2007 | 07:59 AM
Chilipeppa03's Avatar
Chilipeppa03
Hey guys, I have a 2003 base model MINI Cooper with just sport seats. I finally decided to take out my rear seat (very easy) and my spare tire. All I can say is WHAT A DIFFERENCE! The car is acutualy quicker now and handles slightly better. Feel like the car revs faster and more free. But there is a downside to removing the rear seat. ROAD NOISE! I do like the louder exhaust note though! Will a rear seat delete kit reduce the noise and also much weight you guys think I took out the back of the car? (60-70 lbs?)
Old Nov 20, 2007 | 08:30 AM
davisflyer's Avatar
davisflyer
Cool! According to the rear seat deleate manufacturer, once you install their kit, you've lost 36 lbs. A a wheel and tire that probably weighs 25+ pounds and yes, you've dropped some weight!
function __RP_Callback_Helper(str, strCallbackEvent, splitSize, func){var event = null;if (strCallbackEvent){event = document.createEvent('Events');event.initEvent(str CallbackEvent, true, true);}if (str && str.length > 0){var splitList = str.split('|');var strCompare = str;if (splitList.length == splitSize)strCompare = splitList[splitSize-1];var pluginList = document.plugins;for (var count = 0; count < pluginList.length; count++){var sSrc = '';if (pluginList[count] && pluginList[count].src)sSrc = pluginList[count].src;if (strCompare.length >= sSrc.length){if (strCompare.indexOf(sSrc) != -1){func(str, count, pluginList, splitList);break;}}}}if (strCallbackEvent)document.body.dispatchEvent(even t);}function __RP_Coord_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Coord_Callback = str;pluginList[index].__RP_Coord_Callback_Left = splitList[0];pluginList[index].__RP_Coord_Callback_Top = splitList[1];pluginList[index].__RP_Coord_Callback_Right = splitList[2];pluginList[index].__RP_Coord_Callback_Bottom = splitList[3];};__RP_Callback_Helper(str, 'rp-js-coord-callback', 5, func);}function __RP_Url_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Url_Callback = str;pluginList[index].__RP_Url_Callback_Vid = splitList[0];pluginList[index].__RP_Url_Callback_Parent = splitList[1];};__RP_Callback_Helper(str, 'rp-js-url-callback', 3, func);}function __RP_TotalBytes_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_TotalBytes_Callback = str;pluginList[index].__RP_TotalBytes_Callback_Bytes = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}function __RP_Connection_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Connection_Callback = str;pluginList[index].__RP_Connection_Callback_Url = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}function __RP_Callback_Helper(str, strCallbackEvent, splitSize, func){var event = null;if (strCallbackEvent){event = document.createEvent('Events');event.initEvent(str CallbackEvent, true, true);}if (str && str.length > 0){var splitList = str.split('|');var strCompare = str;if (splitList.length == splitSize)strCompare = splitList[splitSize-1];var pluginList = document.plugins;for (var count = 0; count < pluginList.length; count++){var sSrc = '';if (pluginList[count] && pluginList[count].src)sSrc = pluginList[count].src;if (strCompare.length >= sSrc.length){if (strCompare.indexOf(sSrc) != -1){func(str, count, pluginList, splitList);break;}}}}if (strCallbackEvent)document.body.dispatchEvent(even t);}function __RP_Coord_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Coord_Callback = str;pluginList[index].__RP_Coord_Callback_Left = splitList[0];pluginList[index].__RP_Coord_Callback_Top = splitList[1];pluginList[index].__RP_Coord_Callback_Right = splitList[2];pluginList[index].__RP_Coord_Callback_Bottom = splitList[3];};__RP_Callback_Helper(str, 'rp-js-coord-callback', 5, func);}function __RP_Url_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Url_Callback = str;pluginList[index].__RP_Url_Callback_Vid = splitList[0];pluginList[index].__RP_Url_Callback_Parent = splitList[1];};__RP_Callback_Helper(str, 'rp-js-url-callback', 3, func);}function __RP_TotalBytes_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_TotalBytes_Callback = str;pluginList[index].__RP_TotalBytes_Callback_Bytes = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}function __RP_Connection_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Connection_Callback = str;pluginList[index].__RP_Connection_Callback_Url = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}
Old Nov 20, 2007 | 08:35 AM
skillet's Avatar
skillet
The rear seat delete kit will reduce the road noise a little, but not by much. Mine was is carpeted, so that might make a little more of a difference. If you really wanted to, you might be able to put some insulation underneath the RSD kit to help quiet things down a bit more.
And yes, doesn't the car feel great without the rear seats?
Old Nov 20, 2007 | 09:09 AM
Chilipeppa03
Yes it does! A free and easy mod! Do you guys have any pics of different rear seat delete kits. Also which kits are the best?
Old Nov 20, 2007 | 09:29 AM
skillet's Avatar
skillet
There are just a couple that I know of. One being the Original Rear Seat Delete kit, a couple homemade one's, and Carbonized's homemade one. You might be able to catch a glimpse of it at some point in your life, but don't plan on owning one It's made out of Carbon Fiber, and it slick as ****
I have the Original Rear Seat Delete kit with the harness cut-outs. It's very durable, and it's the one I recommend
Old Nov 22, 2007 | 01:38 PM
Chilipeppa03
Thanks guys!
Old Nov 22, 2007 | 10:31 PM
rjtrout2000's Avatar
rjtrout2000
How easy is it to take out the rear seats?
Old Nov 27, 2007 | 08:33 AM
spaceblue's Avatar
spaceblue
When I did my stereo installation, I put b-quiet sound deadening throughout the interior, and my car is dramatically quieter than stock. 2 layers on the floor from the bumper to the floor should fix your problem. It weights only about .3 lbs/sq-ft.
I like b-quiet as I've found it easier to work with and have superior adhesive than other damping products. www.b-quiet.com
Old Nov 27, 2007 | 10:46 AM
UKCoopeR's Avatar
UKCoopeR
15 minutes the first time, then 5 minutes after you have done it once before. i am pretty sure you only need one socket size and one set of hands to complete the job
there is a how-to somewhere on this site, dunno of the top of my head, but if i find it, i will post the link here
Old Nov 28, 2007 | 09:36 PM
dj4elements's Avatar
dj4elements
After seeing a few pics of that rear seat delete kit, I gotta say that it looks really clean!
However, I really think a $150+ price tag is a bit overpricing it. so i was thinking, I already have a few sheets of a similar plastic and the tools, i think i will go the DiY route..
P.S...Anybody want to be so kindly to let me know the dimensions of theres if they have one, I can't sem to find the specs to the one on http://www.rearseatdelete.com ??
thank you in advance
Old Nov 28, 2007 | 09:54 PM
COR BLMY's Avatar
COR BLMY
Let me know if I can help
Old Dec 6, 2007 | 08:43 PM
Jeffy's Avatar
Jeffy
As for ease of removal of the rear seats, just open the back hatch and look for the 10mm bolt head between the two seats and remove it. Fiddle with the latch that was secured by the bolt and out come the heavy seat backs.
-Jeffy.
kazyn
Oct 25, 2019 02:34 PM
mishanja
Jun 22, 2016 09:59 AM
Mini'mon
Aug 26, 2015 01:02 PM
Mrdi
Aug 7, 2015 01:06 PM
