Cooper (non S) Modifications specific to the MINI Cooper (R50).
Cooper using Cooper S Exhaust
Old Jun 22, 2007 | 11:17 PM
jamestcs's Avatar
jamestcs
I would like to install Cooper S Body Kit to my Mini Cooper.
Mini Cooper S is using center exhaust pipe and Cooper is side pipe.
I have a set of original Cooper S Exhaust systems ( whole parts ), any comment on the side effect?
Old Jun 22, 2007 | 11:18 PM
ChrisW's Avatar
ChrisW
You'll have to lose your spare tire. other than that should work.
Old Jun 22, 2007 | 11:21 PM
Eric_Rowland's Avatar
Eric_Rowland
Will probably have to add a few hangers, too.
Old Jun 22, 2007 | 11:22 PM
xnotfunkylex's Avatar
xnotfunkylex
You could just put the valence from the cooper and leave your exhaust on the side. The twin mufflers may effect the efficiency of your car and lower power. I'm not totally sure though.
Old Jun 24, 2007 | 01:51 AM
jamestcs's Avatar
jamestcs
Thanks for the reply.
I have no problem with all fine the hanger and clips.
My only concern is will this slow down the car! fuel inefficiency.
Old Jun 24, 2007 | 12:45 PM
DragonSlayer's Avatar
DragonSlayer
Putting a Cooper S rear bumper on a Cooper is no promblem. All you need to do is remove the lower portion of the Cooper rear bumper and switch it out with the one on the Cooper S bumper.
Unless of course you are modifying your exhaust to a Cooper S exhaust.
That mod I have seen but haven't done. My Borla does me just fine and I like having a spare; so that I don't need to have runflat tires.
Old Jun 25, 2007 | 02:30 AM
jamestcs's Avatar
jamestcs
Maybe I should keep the original exhaust pipe, just "operate" a hole for side pipe.
Old Jun 29, 2007 | 03:29 PM
xnotfunkylex
You can put the cooper rear valence on instead of the cooper s valence. No surgery is needed.
Old Jun 29, 2007 | 04:08 PM
DragonSlayer
Unless of course its an aero rear bumber.
Old Jul 30, 2007 | 06:52 PM
jlucus245's Avatar
jlucus245
I have an MC and not an S and i put the S bumpers on my car i just used the lower rear valence off my cooper bumper. the front bumper needs some cutting of the bumper support to work and to move the foglights to a new location its not hard at all. pics in my gallery
Old Mar 14, 2008 | 12:15 PM
nickbmw's Avatar
nickbmw
Can i use a Cooper S valence on my stock 2002 Cooper bumper to put a centre exhaust?
Old Mar 14, 2008 | 03:45 PM
UKSUV's Avatar
UKSUV
Your question was answered in reply #8
Old Mar 14, 2008 | 03:47 PM
nickbmw's Avatar
nickbmw
It says "You can put the cooper rear valence on instead of the cooper s valence. No surgery is needed." Does this means the oposite is possible with no mods?
Old Mar 14, 2008 | 09:24 PM
vodka's Avatar
vodka
maybe you one ball the mcs exhaust so that the whole setup is similiar to ur cooper exhaust but its center exits
Old Mar 15, 2008 | 03:06 AM
Der Abt's Avatar
Der Abt
I would like to point one thing out here, installing a Cooper S exhaust on a Mini Cooper non S will cause a small loss in power from 3000-4000rpm.
Many owners here in Europe have done this conversion and found out that their car felt just a little bit slower (this was also proven on a dyno).
The reason why this is the case, is because the Cooper S exhaust (the rear part) causes more pressure compared to the stock exhaust on a Cooper non S.
The looks will improve, but you will experience a small loss in power/torque.
Nothing to get worried about, the loss is marginal.
Just letting you know.
Kind regards
Der Abt
Old Mar 15, 2008 | 12:04 PM
kurvhugr's Avatar
kurvhugr
A full 2-sided S exhaust will also weigh more. This is one of the reasons S owners sometimes do the one-ball surgery or switch to one of the 1-sided exhausts that have come out for the S.
Jan 4, 2019 12:51 PM
Trevor413WC50
Aug 18, 2015 10:38 AM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
