Wheels problem (help) T-T
Old Apr 22, 2007 | 10:58 AM
kamikazy's Avatar
kamikazy
have 13X7 wheels
the problem is the wheels standing on the studs
the center of the wheel not touching the rotor
I'm afraid that the Studs will breakdown
any idea ?
please help me out
Old Apr 22, 2007 | 11:04 AM
elprofe's Avatar
elprofe
what are you talking about?
the only studs that should be there are the ones that hold the hub and those are flat, if not they should be.
pics would really hep in diagnosing your prob.
Old Apr 22, 2007 | 12:25 PM
Minimad's Avatar
Minimad
Rims can be hub-centric or not. That is, the weight carried by the center of the rim on the hub like new MINIs etc. Others, the weight is carried by the studs.
Do your rims take acorn nuts or bolts?
Acorn:
Bolts:
in either case the weight of a Mini is carried by the studs. You must have the proper nut/bolt for the wheel.
Old Apr 22, 2007 | 12:27 PM
Minimad's Avatar
Minimad
Or is your problem the offset is incorrect and the wheel will not seat at all on the hub?
What kind of rim do you have. The Mini is 4 bolt - 4" circle. Honda is close but won't work. You must get wheels made for the classic Mini.
Old Apr 22, 2007 | 12:58 PM
kamikazy's Avatar
kamikazy
i have the nuts
the wheels sit perfectly on the hub but its not carried by the center.
is there any problem if the the weight not carried by the center of the rim ?
Old Apr 22, 2007 | 05:36 PM
Minimad's Avatar
Minimad
Minis are lug-centric, the weight is carried by the lugs. I assume the wheel shown has the bolt type with washers? Make sure they don't tighten and hit the hub before the rim is snug. IE too long. When placed in the rim, they should not protrude on the inside of the rim.
Old Apr 22, 2007 | 09:00 PM
kamikazy's Avatar
kamikazy
Thank you for your help ^^
Old May 1, 2007 | 05:49 AM
pmustang's Avatar
pmustang
I am guessing here, do you perhaps have metro sourced 8.4 inch disk brakes, If so they normally have 4 curved lips on the hub face that needs to be ground off to fit mini wheels. They were for centering the metro wheels. If you have these brakes it will be evident from the 2 line brake lines per side, Mini ones have single lines running to each brake caliper.
Also, sometimes you have to just slightly flle the inside center hole on a rim to fit properly over the center of the mini hub.
Cheers. peter
rob&JCW
Feb 13, 2023 07:03 PM
Zettinger
Aug 25, 2015 04:04 PM
ki7hy
Aug 12, 2015 07:07 PM
Aug 12, 2015 01:24 PM
