Questions about a MKII Austin Mini
Old Nov 19, 2006 | 04:51 AM
jgrant's Avatar
jgrant
Hi,
I recentely purchased a 1968 Austin Mini MkII. I plan to restore the car, and yesterday I started to dismantle the car. I have the shell pretty much taken apart. I have several questions, and would be grateful for some info...
1. My Mini has a windshiled wiper on the rear window. I am pretty sure that is not original. Correct?
2. The rear window has the defogger heater. Was this an original option, or was this added on?
3. The rear quarter windows open. Was this an original item?
4. I have found the commission number plate. Is there a place on the web or does someone know how to corroborate that indeed this is a 68 Mini?
5. This car has two fuel tanks in the boot? Was this a common item on MKII's?
5. Last question: what is the history of MKII Minis in the USA? Were these cars sold at dealelrships or was this a 'gray market' car?
Sorry for so many questions. I have been doing my research, I just wanted to ask some specific questions.
thanks,
joe
Old Nov 19, 2006 | 06:08 AM
Minimad's Avatar
Minimad
Mini Chassis/VIN Numbers and Commission Numbers
Part 1: 1959 – 1980
Compiled by Chuck Heleker
(Revised April 29, 2004)
The information used to compile the following was taken from factory service parts lists and factory microfiche. Under close scrutiny, there appears to be some conflicts and mistakes in the factory number schemes, but, for the most part, the listings are accurate enough for car identification.
Please note that the Chassis (VIN) number and the Commission number are only one indication of the actual model and date of the car. The Chassis number plate is easily duplicated, especially on early cars, and it is not unusual for later cars not meeting US DOT and EPA standards to have earlier Chassis number plates attached to them to get them into the US illegally. Also, Chassis number plates have been known to be “faked” to turn a less valuable car into a more valuable one; e.g., a standard Saloon into a Cooper or Cooper S.
[SIZE=4]Part I: 1959 - 1980[/SIZE]
[SIZE=4]1959 Through September 1969 – English Built[/SIZE]
[SIZE=4]October 1969 to 1974 “Model Year” – English Built[/SIZE]
[SIZE=4]1974 “Model Year” To 1980 “Model Year” – English Built[/SIZE]
[SIZE=4]1980 “Model Year” – English Built[/SIZE]
[SIZE=4][/SIZE]
[SIZE=4]Part II: 1980 - 2000[/SIZE]
[SIZE=+0][SIZE=4]Oct 1980 to Nov 1985 – English Built[/SIZE][/SIZE]
[SIZE=4][SIZE=+0]Nov 1985 to Circa 1990?? – English Built[/SIZE] [/SIZE]
[FONT='Times New Roman'][SIZE=4]1990 XN-----010001 On (1300cc cars only) – English Built[/SIZE][/FONT]
The general format for these early cars is:
A-A2S7L-###A
First position (“A” in the above example):
A = Austin (other than Cooper and S)
C = Austin Cooper or Austin Cooper S
K = Morris Cooper or Cooper S
M =Morris
R = Riley
W = Wolseley
Second position (also “A” in the above example):
= A series engine. Any standard Mini engine for the period:
848cc
970cc Cooper S
997cc Cooper
998cc Cooper and non-Cooper
1071cc Cooper S
1275cc Cooper S
Third position(s) (“2S” in the above example):
= Body type:
2S = 2-door saloon/sedan. Caution: bureaucratic bungles often interpret this as 25 (twenty-five)
B = Moke (“Buckboard”!)
U = Pick-up. Caution: U and V can be mistaken one for the other.
V = Panel van. Caution: U and V can be mistaken one for the other.
W = Estate (with or without wood). Officially, “Dual-purpose”
Fourth position (“7” in the above example):
= Series of Austin, or Morris, etc.:
1 = Mk I Riley Elf, Wolseley Hornet, and Austin/Morris Moke
2 = Mk II Riley Elf or Wolseley Hornet
3 = Mk III Riley Elf or Wolseley Hornet
4 = Mk I Morris
6 = Mk II Morris
7 = Mk I Austin
B = Mk II Austin
Fifth position (“L” in the above example):
D = De-Luxe.
L = Left hand drive. Right hand drive was not designated
S = Super De-Luxe
Number positions (“###” in the above example):
= The sequential build number:
The first car at Longbridge was number 101, as was the first at Cowley. From then on, each factory continued with their own number sequence regardless of the model; e.g., Saloon, Van, etc. In other words, each model did not start at 101 and maintain its own sequence. Saloons and Vans, etc., are mixed in the number sequence along with the Cooper and Cooper S models.
The number sequence was into seven digits, #######, by the end of September 1969.
Last position (“A” in the above example):
= Assembly plant. Officially, “Internal Use Only”
This seems to be used inconsistently on English built cars and it is understood that the car was built at the “normal” factory if the letter is left off; e.g., an Austin, Riley or Wolseley at Longbridge may or may not have an A after the sequence number.
Yes, there were Austin Minis built at the Morris plant in Cowley and Morris Minis built at the Austin plant in Longbridge.
Note that all English built Cooper and Cooper S models (Austin and Morris) as well as Riley Elf and Wolseley Hornet models were built at the Longbridge, Austin plant.
A = Longbridge
M = Cowley
Examples:
A-A2S7-123456 (or A-A2S7-123456A)
A right hand drive, Mk I, Austin Mini Saloon built at Longbridge
M-A2S6-1234567 (or M-A2S6-1234567M)
A right hand drive, Mk II, Morris Mini Saloon built at Cowley
C-A2S7L-123456
A left hand drive, Mk I, Austin Cooper or Cooper S
R-A2S2-123456
A right hand drive, Mk II, Riley Elf
A-AB1L-123456
A left hand drive, Austin Moke
M-AU4-123456
A right hand drive, Mk I Morris Pick-up
During the previous months leading up to the cars in this time period, a Commission Number was introduced to go along with the Chassis Number/VIN. Both are helpful in identifying a car.
CHASSIS NUMBER/VIN
The general format for the Chassis Number/VIN for these cars is:
X-A2S1N-XXX-A
VIN, First Position (“X” in the above example):
This is simply dismissed by the factory as “non significant”!
VIN, Second Position (“A” in the above example):
= Engine type
848cc
998
1275cc Cooper S and 1275 GT
VIN, Third Position (“2S” in the above example):
= Body type
2S = 2-door saloon/sedan. (Except Mk III Copper S and 1275GT) Caution: bureaucratic bungles often interpret this as 25 (twenty-five)
2W = Estate (“2 Door Dual Purpose”)
D = 2 door saloon (Mk III Cooper S and 1275GT only)
VIN, Fourth Position (“1N” in the above example):
[Blank] = Mini 850. Produced only in the “round nose” style
1 = Round nose, traditional Mini body style. Includes: Mini 1000, Mk III Cooper S, Van, and Pick-up.
2 = Clubman, square nose style. Includes: Clubman saloon, Clubman Estate, and 1275GT.
VIN, Fifth Position (“N” in the above example):
N = Mini 1000
VIN, Number positions (“###” in the above example):
Unlike the earlier cars, each “type” started with number 101; e.g., the first Mini 850 in this range started with 101 as did the first Mini 1000, the first Mk III Cooper S, etc.
VIN, Last position (“A” in the above example):
If used at all, this would be “A” for English built cars. All English built Minis were now being built at Longbridge.
A = Longbridge
Commission Number
The general format for the Commission Number is:
N20S-XXX
Commission Number, First Positions (“N20S” in the above example):
= Car type
20U = Pick-up
20V = Van
20W = Clubman Estate
D20S = Mini 850
N20D = Mk III Cooper S
N20S = Mini 1000
S20D = 1275GT
S20S = Clubman
Commission Number positions (“###” in the above example):
Sequential number starting at 101 for each car type.
VIN
The general format for the VIN for these cars is:
X-K2S1N-XXX-A
VIN, Second Position (“K” in the above example):
= Engine type
A = [Unknown if this was used. If so, it indicated any of the A series engines still in production at that time]
C = 1098cc
E = 1275cc
K = 848cc
L = 998cc
= Body type
2D: The factory microfiche does not list a designator for the 1275GT. This would imply there wasn’t one; however, it is likely the 2D designator was still used. The microfiche shows 2D used for the 1980 model year. If no designator is listed, the Commission number must be used to identify the 1275GT.
2S = 2-door saloon/sedan. (Except 1275GT) Caution: bureaucratic bungles often interpret this as 25 (twenty-five)
VIN, Fourth Position (“1” in the above example):
1 = Round nose, traditional Mini body style. Includes: Mini 850, Mini 850 City, Mini 850 Special Deluxe, Mini 1000, Van (848cc and 998cc), Mini Special 1098cc, and Pick-up (850cc and 998cc).
2 = Clubman, square nose style. Includes: Clubman Saloon (998cc Automatic and 1098cc Manual), Clubman Estate (998cc Automatic and 1098cc Manual), and 1275GT.
N = Special Deluxe (Except for North America). Includes the Mini 850 Special Deluxe, the Mini 1000, and the Mini Special 1098cc.
North America:
A = 1970
B = 1971
C = 1972
D = 1973
E = 1974
F = 1975
G = 1976
H = 1977
J = 1978
L = 1979
Each “type” of car (with one exception) started with number 101; e.g., the first Mini 850 in this range started with 101 as did the first Mini 1000, the first 1275GT, etc.
The factory records list one exception: the export Mini Special 1098cc. The starting number, for some reason, is listed as 1012011
A = Longbridge
COMMISSION NUMBER
N20S-XXX
= Car type
20U = Pick-up
20V = Van
B20S = Mini City
D20S = Mini 850
J20S = Mini 1100 Special (UK only)
N20S = Mini 1000
S20D = 1275GT
S20S = Clubman
T20S = Mini 850 Super
Starting numbers are as follows:
20U = 13205L
20V = 84679L
20W = 77031A
B20S = 101
D20S = 83622L
J20S = 101
N20S = 20531L and 230547A
S20D = 19416A
S20S = 104632A
T20S = 101
[FONT='Times New Roman']Note that there is no listed explanation for the “A” and “L” endings. If these are intended to be the same as used for VIN numbers, the “A” would be Longbridge. Literature has suggested that “L” = Morocco! This has not been confirmed from factory microfiche.[/FONT]
Old Nov 19, 2006 | 06:17 AM
Minimad's Avatar
Minimad
Hi,
Possible option or aftermarket, not sure on this one tho have seen it mentioned.
Possible option
Original or added later
see other post
Option or added later was a option for Cooper S'
Minis imported & sold thru 1968
Also try
www.minimania.com message board
http://www.miniresource.com/mk1.php
http://www.austin-rover.co.uk/index....neaseriesf.htm
Can you post a photo? First thing is to determine the actual year of your car. There are many late model Minis in the US posing as earlier cars to get by fed regs. Look at this:
http://www.minimania.com/matrix/
Old Nov 19, 2006 | 08:23 AM
jgrant's Avatar
jgrant
Thank you for the help. Here is what my Mini looks like:
Old Nov 19, 2006 | 09:32 AM
classicfreq's Avatar
classicfreq
Can you also post whatever numbers you can find on your Mini? We'll be able to help you decode
Old Nov 19, 2006 | 02:16 PM
dr dave's Avatar
dr dave
From your pictures, it looks to definately be a MK2. It seems to have some nice period mods like the spotlights in the grill, cool wheels, twin tanks, and wing mirrors. The badge on the front is the correct Austin badge. Rear windows are supposed to open outwards and should not have the "piano" hinges-the one on the driver's side is correct- can't see the passenger one. Does the rear window defroster work, or is there a switch? It looks to be a factory window that came in the Mk4 cars and later (even though they are the same size).
If original, it should have the hydrolastic suspension, drum brakes on all 4 corners, have a gernerator dynamo, and be positive ground. The 2nd tank was an add on, and might be aftermarket. Though for a time genuine ones were much easier to source than now. The bumpers should have over riders on the front and rear as well.
The wipers park as though for a Right hand drive car. Perhaps this car was changed to Left hand drive at a later date?
You can find out the import/export history of the car by obtaining a "Heritage Certificate" to see if it is indeed a U.S. export.
Looks to be a nice car. MiniMad's reference for decifering the VIN # is very good as well.
good luck with it.
dr dave
Old Nov 19, 2006 | 02:27 PM
erickvonzipper's Avatar
erickvonzipper
Unless they did it backwards, the wipers appear to be parked for a left hand drive car. The wipers on all my sold in the U.S. cars are parked pointed toward the right just like this car.
Old Nov 19, 2006 | 05:00 PM
Minimad's Avatar
Minimad
I understand MkI & II all had the same scuttle panel. Not the latter scuttle with dual holes for LHD or RHD.
Old Nov 5, 2007 | 01:13 PM
bluehazard's Avatar
bluehazard
Decoding this Vin
I'm really an amateur to Minis. But I'm looking to purchase this one. It's a 1966 Mini.
Can someone help me decode this VIN:
2S137156N
Old Nov 5, 2007 | 03:37 PM
Mab01uk's Avatar
Mab01uk
Yes it was an after market add on now quite rare as a period 1960s/70s accessory.
Fitted to Mk3 cars but may have been on a few late Mk2.
Yes, except on basic 850s.
Only on the Cooper S.
Old Nov 6, 2007 | 07:29 AM
dimini's Avatar
dimini
Interesting thread...
Just noticed that the OP, jgrant, posted this a year ago. Any updates on this car? I would love to see more photos and hear a progress report.
Alkaidovich
Jan 30, 2021 01:35 AM
andrewjg1994
Jan 29, 2021 07:45 PM
Terry J
Aug 11, 2015 09:39 AM
nomar116
Aug 10, 2015 11:24 PM
jrezzo
Aug 9, 2015 10:32 PM
